Old 10-07-2005, 08:21 PM   #1
xallenx
xallenx's Avatar
Default Change oil without removing drain plug...
...has anyone ever tried this...http://pics2.tdiclub.com/video/cinci...xtraction.html any comments..thanks!!
91 944 Turbo
300K+ miles, B230FT K-series engine, AW71 (G80) tranny, Mitsu TD04-13C(7 psi), K&N drop-in filter, Modified air box, Autolite wires and NGK plugs, Canistos with H&R 25mm wheel spacers.
xallenx is offline   Reply With Quote
Old 10-07-2005, 08:33 PM   #2
740Weapon
Traitor
740Weapon's Avatar
link doesnt work.
'90 744 16 Valve. 16.317@85.55. Sold.
'92 244. Sold. http://pbase.com/740weapon
Old 10-07-2005, 08:39 PM   #3
holtzboy
Back at it again
holtzboy's Avatar
Yeah, gotta remove the 'any' from the link so its
1. 86 244DL- 1st car & Owned for 15 years, 25mm sways, iPd springs/fronts cut 1 coil, HDs, 2.25" exhaust, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 93 945 Turbo - IPD sways, 3" turboback exhaust, intake, accumulator mod
My feedback thread
holtzboy is offline   Reply With Quote
Old 10-07-2005, 08:40 PM   #4
xallenx
xallenx's Avatar
Originally Posted by 740Weapon
link doesnt work.
oops!! try it now!!!
Old 10-07-2005, 09:03 PM   #5
ShadowofBob
Revived...
ShadowofBob's Avatar
I've used a vacum pump like that to take out some excess ATF fluid from my transmission last time I did a flush on it and overfilled it. I'm sure it would work, but it would be awfully slow. It's easier and faster to just drain it. And if you really don't want to take the plug out you could just use one of those valves you install where the plug goes(http://www.fumotovalve.com/), but on a volvo that's probably not the best idea since the pan is one of the lowest parts on the car.
1990 Audi Coupe quattro x3 - the eternal project car.
2000 Audi A4 Avant quattro 1.8T 5spd
ShadowofBob is offline   Reply With Quote
Old 10-07-2005, 09:14 PM   #6
CEHepp
FWDFTW
CEHepp's Avatar
I was told that manufactureres are going to this method!
Over a bay, there will be a few hoses for oil/coolant/brake fluid/etc, and you will not remove the drain plug unless there is a problem, everything will be sucked out. I was told they are going to do this to keep mess down, keep oils separated and whatnot.
DD: 2004 S60 on copper Pegs
Current project: 2004 V70 T5M
CEHepp is offline   Reply With Quote
Old 10-07-2005, 09:26 PM   #7
Carbuff2
Carbuff2's Avatar
Those extraction pumps work well. A friend who has used one for years, finally pulled the oil pan from his engine and found it to be perfectly clean (no sludge at all).
Notice that in the video, there was no rolling around on gravel or trying to fit under a car! It's the next best thing to having a lift in your garage.
Several outfits sell the oil extractors, no experience with the Pella personally, my friends all bought theirs from Griot's Garage. $65 for the hand pump, $99 for Pneumatic (sp?)
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
NFI of course.
Atwell Haines
1994 940 Wagon, non-turbo
NJ
Carbuff2 is offline   Reply With Quote
Old 10-07-2005, 09:39 PM   #8
ElPiloto
I built an aspirator from a refrigerator pump and a glass gallon jug. I use it to suck out differential lubricant, brake fluid, power steering fluid but not engine oil. You have to get under the car to get at the filter anyway.
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 10-08-2005, 02:22 AM   #9
Three Fat Tigers
Three Fat Tigers's Avatar
Location: ↓ Lynchburg, VA →| '89 740Ti | '90 760Ti | '92 240 | '94 940T | '96 960 | '96 M1
Not if you install a remote oil filter
Three Fat Tigers is offline   Reply With Quote
Old 10-08-2005, 09:53 AM   #10
Carbuff2
Carbuff2's Avatar
Why use an oil filter anyway?
Ditch the filter, they just clog up anyway and make a mess during replacement.
Use real thin oil too, it leaks out faster guaranteeing that you add fresh stuff periodically.
KIDDING.
Old 10-08-2005, 11:39 AM   #11
CEHepp
FWDFTW
CEHepp's Avatar
KIDDING.
How thin would you like? My teacher, who was an engine builder for NASCAR (wOOHOO!) said they were getting stupid low weights for qaulifying before they werent allowed to change the oil before the race. He said he got worried when they ran a 0 weight oil. He thought they all turned stupid when they had him pouring a 0000 weight oil into the engine. hha
I was trying to find some of this 0000 weight, but I cant find it,
Old 10-08-2005, 12:23 PM   #12
mikep
The MP
mikep's Avatar
Just pull the plug on the thing.
Originally Posted by 4x4_Welder View Post
You have some very specific issues.
I dunno, I mean, sometimes...Sometimes I miss Smokey.
Old 10-08-2005, 08:31 PM   #13
xallenx
xallenx's Avatar
Thanks for all the replies. I'm buying this pump for my mr2 since the filter is accessible on top of the car. So no need to go under the car at all. Since I'l have the pump I just want to go ahead and use it on my volvo too. Hmm...where can I get the remote oil filter relocation kit?? thanks!!
Also, anyone tried to this on tranny fluid change???
Old 10-08-2005, 08:44 PM   #14
740Weapon
Traitor
740Weapon's Avatar
i need to get a set of super shallow ramps that also dont slide on the garage floor so i can retire the floor jack.
that would make me happy.
