Hi All
I have a bit of a problem with my front suspension A bit of history on what has been done New lowered springs New shocks New rack ends May be new ball joints New poly bushes for the control rods bushes These mods have been done for around 40.000 to 50.000 Km The problem is I have a wobble in the front end under acceleration and the same wobble under braking. This wobble can be felt through the steering wheel The problem has been there from when I first fitted the spring shocks and other stuff. In this time I have had the 16 inch Geminis and lately I have fitted the 17 inch wheels it has got worse. I have worked out it can't be a bent wheels so it has to be something wrong with the suspension
George New toy/second car ![]() Old car gone but not forgotten(sold to my father) see link below ![]() http://www.cardomain.com/ride/2151948 |
Try swaping front and rear rims. See if that helps.
This is a dumb ? but are all the lug nuts tight?
2006 VW Passat 2.0t 6 Speed - Current 2005 Dodge Magnum R/T - Sold 2005 Dodge Ram 2500 - Sits in drive away back home 1998 Dodge Ram 1500 - Sold 1990 Volvo 760 Turbo - Sold |
#3 | |
could be you have had a wobble from before elsewhere in your suspension, but the new stiffer shocks, springs, and bushings have radiated it more (where the old softer, worn components damped this wobble)...just a thought
#4 | ||
Hi all
All the wheel nuts are new and tight Quote:
There isn't much it could be May be the ball joints (I can't remember if I replaced them) The top bearing plate or a aligment problem |
#5 |
Hi, I Sweden we have discovered that lowering a 740-940 does cause suspension malfunctions. This is due to lack of spring travel when using lowered springs. Why? it is a design issue. Even the folks racing in volvo-original cup arena has this to ponder about.
Some experience more some less but it is present at higher speeds and at braking - acc. I know of it since I have it on my 940 with a complete set of lowering stuff. spring, custom dampers, swaybars, polys. Solution according to racers are: lenghten the frontsuspension controlarms about 1.5inch will cure it more or less. ONLY if using metal arms, NOT the aluminum ones, enlarge the 2 holes that the topplate is attached to to get more ajustability. (mine is on the works to see results) Another thing one can do is to grind loose the bottom springplate and lowered it about 1 inch. Remember to watch for clearence everywhere and with steering arms. (lenghtwise) An idea for now go back to 15x7/8 rims and test. it should decrease the wobble a bit. |
#6 |
how about a bad strut bearing?? could have ****ed one while putting in teh springs
#7 |
Hi All
Hi petersvolvo Thank you for that info it's good to hear for a person for the land of volvo. I had worked out 700 series had a gentic problem when fitted with lowered springs. I found this info on another post this is the link for the post http://www.forums.turbobricks.com/sh...ad.php?t=51025 700/900 Series front suspension info. from VADIS: Control arm stay: 3530789(1359899) 6819079 LG 388.5mm *) Service version for cars with brake vibrations Control arm - steel Left - 1387682 Exc. Multi-Link Left - 1387682 Multi-Link (3530557) Right - 1387683 (3530558) Exc. Mulit-Link Control arm -aluminum Left -1330937 Repl. 1Pcs 1387682-6, 1Pcs 3530789-1 *) For cars without 16" rims. 1Pcs 3530790-9 *) For vehicles with 16" rims. Right -1330938 Repl. 1Pcs 138783-4, 1Pcs 3530789-1 *) For cars without 16" rims. 1Pcs 3530790-9 *) For vehicles with 16" rims. I notice the info on the alloy control arms. When did volvo first use the alloy front arms Would changing the length of the radius rod have any effect on this problem |
| Thread Tools | |
| Display Modes | |
