i have access to a penta crank with 55mm mains. this has to go into the 85-88 b230 block, correct? are there reliability issues with these blocks/cranks?
i'm used to the older blocks (b21/b23) so i'm not familiar with any differences in the newer ones.
harley His: 79 244DL 395K, 3.93 rear, upper chassis braces, turbo sways, lowered, B21F, P&P 405 w/B cam +4° Hers: 91 245SE 191K, upper chassis braces, IPD sways, 8.2mm thundervolt wires, Bilstein TC's, T cam. RIP: 83 245GLT minus T ~200K. terminal 11 (full throttle actuated), K cam +6º, 2.5" exhaust, dual turbo sways, e-fanned oil cooler, crunchified M46, spun bearings and rod knock from hell. |
None of the redblocks have had any block-related reliability problems that I'm aware of; I have heard the term "core shift" bandied about, but I think that was more an issue with the B21/B23 series. I don't know if it's particularly an issue unless you're boring it out, in any case?
The thing people talk about with the '85-'88 blocks (and I think they may have had some sitting around after 1988, I don't think it's safe to automatically assume a 1989 car has the bigger bearings) is the smaller bearings & rods. They're therefore weaker engines. However, I know of at least one person who was running lots of boost using a large turbo & through a huge custom intercooler; and using a 1986 B230FT. This car was punished for at least 3 years before I lost touch with him. So while they're not The Ultimate, these early engines are capable of coping with the sort of power your average +T attempts to put through them.
When I'm cruisin' in overdrive ... Don't have to listen to no run-of-the-mill talk jive. Shatner: The Colonel is breakdancing ... gimme a break!! Rollins: Credit terms raised! Shatner: I can't get behind any of that! Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ... Rollins: Well, I can't!! |
that set up will be fine, just upgrade the rods.
my cars (click me) I'm not here, Please leave a message after the tone........(or email me). |
#4 |
so is $400 too much for a 56mm mains crank?
#5 | |
The Sirius/Nova Police
Mike Lost my 2004 V40 GDI sport lux in local flooding last november, currently driving a Mercedes E430 avantgarde with prins LPG system (Sorry guys it is fun though) |
#6 |
no its not. one from sten is 650. just remember you're going to need a shorter piston or rod to go with it.
| Thread Tools | |
| Display Modes | |
