staring at my desk
After battling a few minor problems with the install, including wrestling with the downpipe studs, and tracing down mysterious oil leaks, it's all working great!
Let's start with some history, it's a TD04HL-15G from a 1995 850 T-5 with 104k on the clock, spins freely with very minimal play, got it off ebay for a very good price. ![]() I'm sure it's been documented on how to clock these things many times before, but for a quick recap you have to rotate both housings if you want it to all line up with the 13c's oil and water lines. After taking it apart (a socket set and a hammer come in handy) this is what needs to be dealt with ![]() The first locating pin, you can either cut this off or pull it out. WARNING! ACHTUNG! Don't hit it with a hammer, I did and it made the mating surface not quite so round Next bit to come off is the compressor housing, this is held on to the centre cartridge with a giant clip. Forget everything you've heard about these things, it's not easy, it's an absolute frickin bastard. You will swear. Lots. Your neighbours will think you've been posessed and will be calling an exorcist. "MITSUBISHI HEAVY INDUSTRIES SUCK COCKS IN HELL" I screamed as the pliers slipped off for the hundredth time. Anyway... . After you get over that slight inconvenience, you see another locating pin, and again you can cut it off or pull it out.![]() Once that's done, you can either put it all back together and have some fun, or start some porting work so you can have even more fun! For porting I used a big corded bosch drill and some carbide burrs, going slow and steady, porting the exhaust housing took me about 3 hours, plus another hour or so the next day when i decided to open up the wastegate hole some more. ![]() All finished . The studs also have to come out, and the threaded holes drilled out.Once all that's done, thoroughly make sure it's all nice and clean as you don't want metal shavings in your engine! Next up is to get it all back together with everything lined up how you want it. It's pretty much a reverse of the disassembly, the giant clip for the compressor housing is much easier to put back in than it is to take out, much to my relief. ![]() Getting it all perfect is a bit tricky without another turbo to compare it to, but it can be done, and you can always reclock it slightly when it's in the car if need be. Now that everything is clocked for a redblock application, you'll notice the actuator is in the wrong place, so a bracket needs to be made. This has been covered loads of times in many different ways, including Turborg's awesome way of mounting it on the manifold stud (http://forums.turbobricks.com/showthread.php?t=54545) but here's how I did it. ![]() Looks like crap, but it's solid. After fiddling with it for a while I ended up with 1/8" preload on the actuator arm, which seems to be perfect for 4psi. I stood back and looked over my work with glee, until later on when I tried to hook up the oil feed. ![]() Needed a last minute modification ![]() Next job was to begin porting the manifold, again using a big drill and carbide burrs. ![]() "It's all about da flowz, woo wooooo" ![]() Nearly there.... ![]() Yay! But that wasn't the end..... The 15g's CBV was well and truly bollocked, so on went the 13c's CBV and all was well. It's now all hooked up along with the EBC and I can get a massive 6psi before it starts to ping on 95 octane (was running 10psi on the 13c), time for some 98 octane and bigger injectors Oh and the noise.....WOOOOSSSSSSHHHHHHH ![]() Finally, the usual warnings apply... use eye protection, eyesight is more important than a stupid car, use ear protection if you have it, and don't stick your hand on the downpipe after driving ![]() |
Awesome job man, keep up the great work and the pics are schweet!
![]() H22 VX Hatch, LSD M2B4 Trans, CAI, DC Sports 4-2-1, Test Pipe, 3" Catback Exhaust With Vibrant Flat-Black Muffler, Skunk2 Cam Gears, Tuned on Crome Pro 187whp/148wtq All Motor 251whp/209wtq Nitrous Mustang Dyno |
staring at my desk
Oh and some useful Volvo part numbers if anyone needs them.
948645 - Downpipe Nut 977209 - Manifold to Turbo Nut 1357769 - Downpipe Stud 3514546 - Oil return gasket 1306264 - Oil return block seal |
#4 |
cutting, welding, bashing
Looking good Steve, well done!
Time for some more fuel and then a return to the strip. Do you have a shell garage near you? if so use optimax as it's significantly more detonation resistant, might help you out until you get bigger injector's and lets face it's only about £5 a tank more than 95. Laters Nick
Volvord Project Thread :http://forums.turbobricks.com/showthread.php?t=184497 1972 Mk1 Escort, B230, 16v, T5/4L60E, 8" Axle, KMS MD35, AIM EVO Datalogger "Volvord MK1 Escort Project" : http://www.jwbr29544.pwp.blueyonder.co.uk/escort |
#5 |
ooh nice , i feel a 25 litre drum of daves magic fuel for the strip comin on .
![]() muhahhahahhhahhaha !!!!!!!!!!!!!!!!! |
#6 |
I noticed that you listed your car as a LPT. My 1991 945T here in the US also has a td04H-13C, does that make it a light presure turbo.
Also, how's your car running with the 15G? Does it run at the same factory boost pressure (7.5psi)? Is it a lot quicker? Like you, I am also running a Greddy Profec B Spec 2. Hoping to follow in your footsteps with the 15G or might even go for a 16T. Great writeup on the install. I gather from the install that you did not need any new plumbing (downpipe, manifold, oil and coolant lines) in the change from a 13c to 15g. Last edited by yumling; 05-20-2006 at 03:07 PM.. |
#7 |
![]() Join Date: May 2004
Egad - the gratuitous mega-quote!!!
I guess you don't really need to replace those locating pins? Does the 15G bolt up to the 13C downpipe? Would a 16T?
#8 |
unbalanced chemical
![]() Join Date: Jun 2002
15g w/ a conical housing will bolt up to the 13c downpipe, a later 15g w/ the flat flange won't bolt up. be it that all 16t's are either flat or angled flanges neither will bolt rightup to the stock downpipe. tho if you use a 16t compressor/center and a 15g conical turbine housing they all bolt right up
and nice work on the install, i just find it funny because i've always found it 1000x easier to remove that snap ring than get it back on. removing it takes me like 20 seconds. its reinstalling that's always the pain for me |
#9 |
the 94-95 15G's will bolt up to the 13c conical exhaust housing, but in 96 they changed to a 3 bolt flange which would not work. the 16T's also use the 3 bolt flange. the 15G is nice but it doesnt really wake up to about 14psi and up. thats where it gets fun
#10 |
staring at my desk
Woah hello there forgotten thread.
Unfortunately for me the 15g started using oil quite heavily under boost. Although while it was running it was freaking great. The 15g at 8psi would quite frankly **** all over the 13c at 12psi. And just to confirm once again, YES it does bolt right up as long as it's clocked correctly - the coolant lines, oil lines, intercooler plumbing and intake plumbing are all the same. It's almost like replacing the 13c with another 13c. |
#11 | |
unbalanced chemical
no they will not, they will bolt up to the stock DOWNPIPE not the turbine/exhaust housing as the 94+ TD04's are all heavy industries turbos and there for use a larger turbine wheel than the 13c's |
#12 |
The Sirius/Nova Police
wouldn't happen to have the old 13C you wanna sell. my folks 97 turbo has started going bad, pumpiong alot o oil through the intake
Mike Lost my 2004 V40 GDI sport lux in local flooding last november, currently driving a Mercedes E430 avantgarde with prins LPG system (Sorry guys it is fun though) |
#13 | |
unbalanced chemical
that's y i warn everyone agaisn't buying ebay 15g's for cheap and they re better off finding one from someone on the boards who pulled them off a running car ... till tho if its just leaking oil the rebuild kits are only $100 |
#14 |
Ryan's spanner monkey
Highly amusing write-up. Good work
![]() cheers James
'05 V70 D5 '88 360 Turbo Intercooler '84 360 GLT '81 343 GLS R-Sport '80 343 DL '69 164 PM me if you're looking for Euro parts!
#15 |
ooooooooo nice pics, and amusing write up
1997 Volvo 944 2.3se TURBO |
#16 | |
#17 | |
unbalanced chemical
#18 |
Neither do the HPTs
cheers James |
#19 |
i dont know why i said housing's i ment downpipes
#20 |
Turbonormalizer
![]() Join Date: May 2003
threadjack!
![]() 15g thats been modded with a garrett t-3 super 60 compressor and opened up to match wheel size... ![]()
![]() 89 244tic- Ultimate sleeper - MZR/Duratec 2.3, Eagle rods, CP 8.5:1 jugs, GT3071R , 5R55E, Home-made turbo and intake manifolds, Electromotive TEC-GT, Tial BOV and WG, PCS Paddle shifters, Electronic gear select module 93 965- Daily driver 91 944se- Resto project 66 122s- Stock |
#21 |
unbalanced chemical
nice, how thick of metal is that WG bracket?
and what did the maching work cost on that housing? |
#22 | |
Turbonormalizer
I dont remember, it was in the ballpark of 600 with a new cartridge. it was pretty expensive for what it is. but I can get 8psi by 2500, so it's good down low and it makes power all the way to 6k. It's also ported a buttload on the exhaust side and I opened up the WG hole alot too. |
#23 |
Guest
that port job looks good! Ping = Bad, More Fuel + More Boost=
| Thread Tools | |
| Display Modes | |
