I know it can be done, I've seen lots of pictures. Did a search but haven't found a great deal of information about how to do the swap. What's the bare minimum that needs to be done to get this swap done. I know there's an issue with the b230 intake hitting the brake booster. I've heard you can use a b21ft intake (haven't seen pics), & seen old b21f? manifolds used. Can you use the OE turbo manifold or is it necessary to build a custom? What about the aftermarket headers used on 200/700/900 cars? I'd be willing to do some cutting of the fenders/hood if need be. Any issues doing the t5 swap along with the engine swap?
Any "experts" on this swap car to do a write up? Thanks Rob
http://www.pbase.com/242ti/root |
Better Red than Dead
Are ya gonna mount it straight up, or with the gangsta lean?
-Kevvie Hoikansanalainenen
Probably straight up. Found some pics where they used the oe turbo manifold on a motor mounted straight up.
I read a little about guys wanting to swap the whole 240 crossmember. Anyone try this? How would you mount the struts, aside from doing a tube chassis & making mounting points off that? Can anyone confirm that a m410 will bolt up to a b23/230/21 if mounted straight up? Would I still need to modify the tranny mount & need a custom driveshaft? Rob |
#4 |
I to would like to know that. I have a 142 that needs a good engine in it. Thinking of rebuilding the B20E, but also do a B230FT in it for the kicks and fun
Datsun 620 1.5 NA 1979 - oldtimers rally car Volvo 850R 2.0 T5 1996 - baby R - daily runner Volvo 850 2.5 20V 1992 - one winter beater - sold Volvo 480 Turbo 1994 - everyday track car - sold Volvo 744 TIC Haas tuning 1987 - got fixed and then killed - totaled by a BMW Mazda 626 coupe 1984 - rebuilt from scratch - sold Volvo 142 GL 1973 - got from grandfather - sold to turboES --------------------------------------------------- jag kör en Volvo för att kompensera för min enorma penis |
#5 |
SAAB defector
damnit, listening to this makes me want to make a 142 16v turbo vintage-style rally car
that would be the hottness incarnate
#6 |
![]() Join Date: May 2004
I've even seen a 5 banger 850 motor sitting pretty in a 140 engine bay.
#7 |
Yeah the 140 is probably the best candidate for an engine swap w/ regards to pre 75 volvos. I've seen pics of a 5 cyl (the silver one w/ widened steelies). That looks like a little too much work. I seriously think the b23 swap can be done for a reasonable cost.
Found this site. Has pics of a b230 install & 5cyl. Looks like the motor needs to be angled inorder to fit the intake: http://hem.bredband.net/b104371/ny_rova.htm But then.. would the stock turbo manifold fit? http://hem.bredband.net/b104371/mer_bilder.htm Looking at the top left pic of the turbo manifold it looks like you'd have just enough room for the stock exhaust manifold & turbo. Like I said, I have no problem with reshaping the inner fender wells. The only question is.. will it clear the suspension? A turbo header MIGHT also fit but I have no way of confirming that. Also found that someone suggest using a 1800E brake booster b/c it's a little shorter/smaller? I have a spare that I'll look @. If you use a kjet head & b21f intake you could install bosch style injectors in the k-jet holes & run ms. Otherwise you'd have to weld bungs onto the manifold. I'd probably go the later route. Honestly I'd rather have a supercharged b20, but if you need a new engine & are up for the challenge I'd go for it. Rob |
#8 | |
.... if the m410 came out of an 1800 and the 140 was an OD car, all will bolt up with no mods necessary.
Oskar 1972 Volvo 142e 16v 1983 Volvo 242 turbo 16v 1995 Volvo 850 T5R |
#9 | |
Measured the 1800 brake booster: ~6.5" wide & ~10" long. Looking at pics of 140's I estimate theirs to be 13-15" long & 8-10" wide. I don't know what it would take to do this swap. Might just be as easy as rebending the brake lines to match. Can anyone verify?? Don't 700 &/or 900's have the alternator on the driver side? Can you use the same bracket & stuff on a b23f? It looks like if you keep the engine @ a slant inorder to fit the b21 intake it might be necessary to move the alt to the other side or do a custom mount. Hot side IC piping would have to be a little creative but that's not too bad. Here's my list of necessary mods (tell me where I'm right/wrong): Relocate battery Modify motor mounts Weld bungs to b21f manifold Custom IC piping Tap into wiring harness for MS stuff Electric fan Mount for intercooler (stock) B20 oil pan & pickup Still not sure about: Swap to 'nspark or use OE ignition Use 140 radiator or swap to 240. Custom mount & lines if using 240 Custom downpipe or modify current Adapting throttle body for b21f manifold/ adding 850 tps to it's tb (don't know what it looks like) Throttle cable B20 oil pump? What am I forgetting? Rob Last edited by Super1800GTR; 11-22-2005 at 11:09 PM.. |
#10 |
#11 | |
holy crap, there is a lot more room between the head and brake booster than i thought... i was thinking that i was going to have too get a remote booster or something.
(\_/) (O.o) (> <)This is Bunny. Copy Bunny into your signature to help him on his way to world domination |
#12 |
#13 | |
#14 | |
Guest
Rob |
#15 | |
I'd think using a smaller 1800E/ES booster would be a lot simpler. Probably bolts right up, just takes up a lot less room as it is a smaller diameter. Would it give you enough room? No clue. A custome log intake manifold would help a lot, I'd guess. |
#16 |
are those heads in the first set of pics bolted to a stock 140 block? if so does anyone know where info is on the job?
#17 |
visst
There are remote brake boosters from i believe some toyota pickups that will work just fine in our volvo's. I have a few articles from a dutch volvo club where someone put a B23 in his amazon, engine vertical. he had a separate brake booster.
I can search for the article if you want...
240 | 1991 | 271 KKm | B230F+T | M90H | fuel:E85 Amazon/121 | 1968 | finished 2016+? |
#18 | |
Guest
JW240.. That would be great! Rob |
#19 | |
visst
I already searched, but haven't found it. But I keep searching until I've found it, I want to know it now! |
#20 | |
#21 | |
http://europeancarweb.com/events/041...vo/index1.html Last edited by Super1800GTR; 11-20-2005 at 06:55 PM.. |
#22 | |
BTW... that VIR link...the pic of the Blue and white 122- That's me in the grey shirt. and that 16v 1800 has a b234 r-sport engine, not a b20. i held that ver VPD supercharger, before I aquired my 16v's I was planning on SC-ing my b20 and talked to john there. Last edited by Billiam500; 11-20-2005 at 07:45 PM.. |
#23 | |
| Thread Tools | |
| Display Modes | |
