Go Back   Turbobricks Forums > Symposium > article composition
Old 12-21-2005, 12:01 PM   #1
RockVegas
Sport Mode
RockVegas's Avatar
Default Homemade MBC in the works...
The "D.I.Y. Manual Boost Controller"
....Home Depot™ style
Found at http://www.geocities.com/chmwatson/FAQs/mbc.html
This controller was conceived from deep within a tight pocket, along side the lint and gum wrappers. There are two reasons I made my own MBC. First, I was not going to spend money on an expensive MBC (though I did want something that would properly and effectively control boost). Second there was the challenge to build it and be able to think "heh.. see.. I didn't need to spend 50 or 100bux to buy a pre-made one!"
Since a fellow Club DSM Canada member shared the basic idea behind this controller with me, thanx Steve I'm sharing it with you... If you have even the slightest bit of mechanical ability you can make one of these; building this MBC won't cost you more than about $12 in parts from the local hardware store and an hour or two of your time...
NOTE: Before making and installing a MBC you MUST have a Boost Gauge installed to monitor the changes you will be making while adjusting your boost. Failing to do so may result in nasty engine destroying demons attacking your engine. I would also highly recommend doing the fuel pump rewire mod if you plan on increasing boost beyond 15 pounds
the parts:
all of the following parts should be available at the local hardware store, in my case, it was Home Depot in the air tool section.
  • 1/4" NPT Tee (I'll refer to it as the 'Body')
  • 1/4" Male NPT coupling
  • 1/4" Female NPT x 3/16" hose barb
  • 1/4" Male NPT x 3/16" hose barb
  • 5/16"-18 x 1 1/2" SHCS (I'll refer to it as a 'Bolt')
  • 5/16-18 Jam Nut
  • 1/4" dia ball bearing (I actually purchased mine from a bicycle shop)
  • Spring ~ 1.69" lg x 3/16" dia
  • Straight thru 3/16" plastic hose barb coupling (commonly used in windshield wiper systems)
  • length of 3/16" I.D. vacuum hose to connect MBC
the tools:
  • drill
  • 1/32" drill bit (to drill vent hole in plastic straight thru coupling)
  • 5/16"-18 UNC tap
  • hack saw
  • teflon tape
the procedure:
1. Cut the top part off the coupling using a hacksaw as shown.
I will refer to this piece as the "Cap"
2. This is what the Cap will look like after being cut. Discard the piece you cut off.
3. Since the hole thru the fitting is already slightly over .257" (required taps size for a 5/16-18UNC thread) drilling to the correct size to tap is not necessary. Tap the Cap all the way thru. Make sure the hole is tapped straight (concentric to the hole)
4. Take the jam nut and thread it part way up the Bolt. Wrap the Bolt with Teflon tape, to prevent air leaking between the threads, and thread the Bolt and nut into the Cap, place aside for now. I will refer to this as the 'Cap Assembly'.
5. Use some teflon tape when threading the following together... take the male hose barb and thread it onto one end of the tee. Take the female hose barb fitting and thread it onto the middle part of the tee.
6. Place the ball bearing into the tee, so that it is now sitting at the bottom against the Base. Gently follow with placing the spring down on top of the bearing. Now take the Cap assembly and using some teflon tape thread it into the tee.
Note: The dimensions I have given for the spring are what worked for me. Your spring will have a different 'rate' and therefore will act differently, a little experimentation for length and compression is required to find what works for you. MAKE SURE the compression on the spring (from the Bolt) is completely released and increase compression on it, which increases boost, gradually.
6.1 Here is a basic cutaway view of what the internals will look like once the controller is completely assembled. Because the spring is sized closely to the inside of the Body, there is no need to modify the Body or spring to eliminate any lateral deflection that might occur if the clearance between the two components been greater.
As a side note, a second ball bearing can be added between the spring and the Bolt. I've found though, that due to the spring's size, it seats fairly well on the Bolt without binding (which could cause problems with adjustment accuracy) and doesn't require it.
7. Carefully drill a small (1/32") hole into the body of the MBC as shown by the arrow in the cut away aside. With the bleeder hole in this position the same end result is achieved as with the coupling, but it reduces the number of parts required to fabricate and install the MBC.
The bleeder hole is not large enough to affect the signal to the Waste Gate but it is necessary to gently vent off excess vacuum or pressure in the line which causes a type of signal lock. If the hole wasn't put in, the controller would have difficulty controlling boost above about 15 pounds.
8. Attach this 'bleeder' to the fitting on the side of the MBC with silicone hose. Attach a piece of silicon hose to the other side of the 'bleeder' this line now goes to the waste gate.
9. Take another piece of silicone hose and attach one end to the Base of the MBC and the other will tee into the signal line between the BOV and the manifold.
Refer to the above Schematic for a visual layout of what I have just explained
the result:
You can now begin to adjust your boost by turning the Bolt in or out of the Cap (turning the Bolt in, will increase boost; turning it out will decrease it). This places resistance, thru the spring, onto ball bearing which will reduce or increase the signal that the waste gate sees (thus controlling the boost). Once you find the 'sweet spot' of the controller, you will notice that it should only take minor adjustments to the Bolt to increase or decrease boost. Once you have achieved the desired boost setting, snug the Jam Nut against the Cap to lock the position of the Bolt.
Additional installation and adjustment
You will require:
  • length of 1/8" I.D. vacuum hose [or equivalent]
  • (1) 1/8" plastic tee [or equivalent]
  • (2) 1/8" rubber cap [or equivalent, a piece of vacuum hose with a bolt will work too)
  • zip ties
Procedure:
1. Determine where you wish to mount the MBC. Find an area that is easily accessible, so it can be adjusted without difficulty. Mounting to the radiator cooling fan shroud as seen in the aside picture, for example, is convenient.
2. Before connecting the boost controller you must disconnect the BCS (Boost Control Solenoid) plumbing from the waste gate, air can and turbo outlet.
Note: If you have the Knock LED mod installed in your car you likely have the resistor1 installed inline with the LED circuit and must leave the BCS connected electrically. If you do not have the Knock LED mod, or wish to remove the resistor1 from it’s ‘inline’ position, you can install the resistor1 into the connector for the BCS after removing it.
-For information on the Knock LED mod see the following url http://members.home.net/dsmweb/ledmod/ courtesy of Damian Sigman
-resistor1 is the appropriate resistor value for the LED used in the above mod, either as described in the mod, or calculated for your specific LED
3. Using the below plumbing schematic, cut the vacuum hose to an appropriate length and connect to the MBC. Secure all connections with zip ties and the MBC in it’s mounting position.
4. Cap off the nipple on the air can and the turbo outlet with the rubber caps. Secure them with a zip tie as the example in the aside picture depicts for the turbo outlet.
NOTE: due to minor revisions to the MBC it is no longer necessary to install a straight through coupling with a small hole, described as the ‘Bleeder’ in my FAQ. The bleed feature has now been incorporated into the body of the MBC (small hole drilled into the body)
Adjusting the MBC:
It is critical that the MBC be adjusted before you drive your car under sustained boosted conditions; Failing to do so could result in boost levels higher than the engine maybe capable of maintaining, leading to possible engine damage. I have preset the MBC at approximately 15psi of boost to provide a basic adjustment starting point. This may be slightly higher or lower on your car.
After you have installed the MBC, gently drive your car in a controlled environment (ie. empty parking lot or unused country road) gradually ease on the accelerator building boost and noting maximum pressure on the boost gauge. Under any circumstance DO NOT operate your car over the maximum known sustainable boost pressure according to other modifications completed. If you are not sure what the maximum sustainable boost pressure for your DSM is, do not exceed 13psi.
To Increase boost:
Loosen the jam nut off gently and turn the bolt in (clockwise). Adjustments are very minute, so do them in small increments, adjust, test, adjust, test…etc. failing to do so could result in generating extremely high boost levels and damaging your engine.
To Decrease boost:
Loosen the jam nut off gently and turn the bolt out (anti-clockwise). Adjustments are very minute, so do them in small increments.
Once you have achieved your desired boost level setting, tighten the jam nut down against the body of the MBC. This will lock the bolt into place.
Failing to tighten the jam nut could result in the bolt backing itself out which would create higher than desired boost levels. The worst case would be loss of the bolt and internal components, resulting in complete loss of control over boost.
1995 855 Turbo
RockVegas is offline   Reply With Quote
Old 12-21-2005, 02:22 PM   #2
RockVegas
Sport Mode
RockVegas's Avatar
I didnt read the submission guide. Dont think I'm doing this correctly. Any ideas where I should throw this? I've never built one, so cannot verify functionality, but dont see any reasons it shouldent work like all the others. Should I just make this a thread in the Performance forum?
Suggestions?
Old 12-21-2005, 06:58 PM   #3
89740ti
89740ti's Avatar
Looks like you put it in the right place. After feedback, according to the submission guide, submit to dana@turbobricks.com.
Nice clean write up, though. Very sharp. I might attempt it if I didn't already have one installed. Maybe for my Father in law for his van for Christmas......."No, really, it works really simple, I'll show you...."
Bob
89740ti is offline   Reply With Quote
Old 12-21-2005, 10:15 PM   #4
RockVegas
Sport Mode
RockVegas's Avatar
Lol, yeah, it's the best writeup I've seen so far. It's a direct copy off the website I mentioned in the title. The original page said it was ok to repost on another site, so I hosted the images and converted it to forum language.
It would even be better if you couldent buy the things off Ebay for $15. But, it does allow you to really see what's going on inside them.
Old 12-22-2005, 06:45 PM   #5
ovlov760
ovlov760's Avatar
I've used that type of MBC but I think the type found on Gus Mahons website works better. It's a bit harder to make because you have to order the parts off the Mcmastercarr website.
1988 760 Turbo - Sold
http://www.flickr.com/photos/33412421@N08/
Old 12-25-2005, 08:27 PM   #6
volvo-slyder
volvo-slyder's Avatar
i made 1 using those instructions , its currently on my brick. no creep or nothing and i didnt drill the little hole like it says and it still works perfect
15psi and no problems
i think t cost me like 12$ all together
and i have enough left over parts to make another 1
volvo-slyder is offline   Reply With Quote
Old 01-31-2008, 03:53 PM   #7
nosajnil
how can you make one that's adjustable from inside the cabin?
what would be the theory and complication of making such device?
nosajnil is offline   Reply With Quote
Old 01-31-2008, 04:12 PM   #8
ovlov760
ovlov760's Avatar
1. Run the MBC inside the cabin by using really long hoses. That would probably hurt performance.
2. Make a really long flexible metal shaft that runs through the firewall and let you turn the mbc adjustment screw from inside. This would probably be pretty difficult.
3. Mount a slow turning motors shaft to the screw of the mbc and use a switch to control the motor. I have actually tried this. It would work if you can bond the adjustment screw to the motors shaft securely. Glue wont work, you need to weld it. You still risk backing the screw all the way out if you adjust too far.
4. Get EBC or buy a MS1 box+GMC boost control solenoid and try to wire up just the EBC portion of it. EBC is the simplest and most effective way of controlling boost from the cabin that I know of. It's also much nicer to use than a mbc. I have nothing but praise for the ms1 box+GMC boost solenoid setup.
Old 01-31-2008, 08:27 PM   #9
jamin01
jamin01's Avatar
Thanks for your effort, I might try this.
Cheers
245 ti - ipd springs, billy hd's, 25mm sways, poly, A cam, b230 mani swap, 2.5" turbo back, 10psi, 3" intercooler, E-fan, AC deleted, M46 with stage 1 PP and 6 puck clutchnet - more mods to come? LH 2.2 convert, ported 90+, LPG once EFI.
Selling any LH2.2 shiz? let me know.
Fap Fap
jamin01 is offline   Reply With Quote
Old 02-02-2008, 10:37 PM   #10
nosajnil
will that cause slow response or boost spike?
Old 06-30-2008, 03:45 PM   #11
spdracr
I did mine differently, I fed the controller from the turbo compressor housing and not inline with the BOV. Would that hurt me in anyway ??
'09 Nissan Versa (Daily Driver)
'00 Mitsubishi Galant ES 4g64 (Project #1)
'91 Volvo 740 Turbo B230FT (Project #2)
spdracr is offline   Reply With Quote
Old 06-30-2008, 04:34 PM   #12
MrT_VolvoDestroyer
MrT_VolvoDestroyer's Avatar
You know what's nearly free, takes about 2mins to make and also works?!?!?
Ingredients...
1> 1 y-shaped OR t-shaped piece of plastic tubing, correct size for hosing to squeeze over
2> 3 pieces of hose
3> Mini clamp with bolts either side
Instructions...
fit hose to all three parts of y-shaped plastic
run one bit of hose to turbo
run one bit to the actuator
place clamp over 'open' end of hose
Adjust clamp to fuel cut or spark blow out
Thrash car around till you can afford proper MBC
Result - pikey Boost Control
Thanks. Ta ta!
T.
Originally Posted by Marvelous3 View Post
Sometimes, you gotta knock a bitch out.
Mcleod makes an awesome twin disc. It will help you find the weak parts in your drivetrain
Originally Posted by slow240 View Post
shaWEET!
man i wish i had some cash.
id be on this like stickers on a civic
P.S. Boost is for life, not just for clickety clickety BOOM
P.P.S. Sex wee http://www.ttvracing.com/
I like balls on my forehead
MrT_VolvoDestroyer is offline   Reply With Quote
Old 07-05-2008, 11:47 PM   #13
derosa
derosa's Avatar
Where at home depot do you buy the spring or does that come from something else?
98 v70xc soon to be running
98 v70 5spd for the wife
91 240 +T
79 262c, currently under construction.
Needless to say I spend way too much time working on cars.
Cuius testiculos habes, habeas cardia et cerebellum.
derosa is offline   Reply With Quote
Old 07-05-2008, 11:57 PM   #14
crazy0000
Hug it Out?
crazy0000's Avatar
a pen.
crazy0000 is offline   Reply With Quote
Old 09-20-2008, 11:05 AM   #15
Quattro
Quattro's Avatar
Sorry to bump this lol.But ehh im gonna be making one of these soon.I was wondering do we just plug it into the line coming from the turbo housing to the actuator?Thats what i think we do as we have a different set up compared to the dsm guys.
In the market for another 4 square 740Ti!
Quattro is offline   Reply With Quote
Old 09-20-2008, 03:29 PM   #16
Janspeed
Janspeed's Avatar
Yes. But personally i don't see the point in making one yourself when you can actually buy a very similar on for a very reasonable price.
http://www.3barracing.com/products.htm
Old 09-21-2008, 06:55 PM   #17
trevorcrowell
trevorcrowell's Avatar
QUIT SUGGESTING THIS!! You are going to get some idiot to try it and they are going to blow their engine apart. A MBC is quite cheap. If you don't do it right in the first place, don't do it. Yeah, I know its like the Turbo+ system. Its still STUPID!
Ingredients...
2> 3 pieces of hose
Instructions...
trevorcrowell is offline   Reply With Quote
Old 11-27-2008, 06:51 PM   #18
Volvolcano
Volvolcano's Avatar
One could have two or more MBCs in place, set at different boost levels, plumbed in parallel with each other.
Plumb a 12-volt solenoid valve in-line on each one.
Have switches in the cabin that turn on the different solenoid valves/MBCs.
Kinda clunky -- you're still only hitting set levels, not fully adjustable -- but plenty cheap enough to do (the Turbobricks way )
'00 S70 GLT SE -- waiting for a head gasket...
'98 S70 GLT -- $250 sight unseen: whoa! nice car!
'91 940t -- the Wifemobile: stock motor / IPD + poly suspension
'89 745t -- 280k / daily driver / the haulmobile
'87 760t -- $250 project car -- runs, but...
'89 760t -- $200 project car -- doesn't run, but...
Volvolcano is offline   Reply With Quote
Old 09-28-2009, 02:54 PM   #19
MrT_VolvoDestroyer
wuss
Old 09-30-2009, 12:16 PM   #20
DrvSfly
Board Clown
DrvSfly's Avatar
Thumbs down
You must be a rich bastard. $40 vs. the $5 it takes to make one.
Just make one and be done. If you need a shiny chrome one, buy it, if you need a MBC, just make it.
Of course if you watch your boost gauge, you won't blow it up unless you're an idiot.
thats a late abortion turbo right there...
780 Owner's Group
DrvSfly is offline   Reply With Quote
Old 09-30-2009, 12:59 PM   #21
Quattro
Quattro's Avatar
Mrt i did the same open T boost controller damn thing worked great.Just wasn't very steady on boost levels.Such as if the temperature outside was to drop it'd effect my boost hold out at WOT.I had it go to 28psi when it was set to 20psi during the day.
I'm just going to the hardware store to make my own.The NSX controllers are the same damn thing you can make for $5-$8 and doesn't take 3-4 days to get here and doesn't cost $25.
Just saying.
Old 10-01-2009, 01:13 PM   #22
MrT_VolvoDestroyer
hey just a word of advice. 28 psi = Fail (motor goes pop gearbox falls to pieces and clutch brakes into many, many pieces kinda fail)
I think anything above 16 psi= fail without spending on stage 0. (hoses pop off, things go wrong, and 1st-2nd gear makes rattles, clutch discentigrates if you're pulling 2ms gear changes, etc)
Really can't recommend going beyond 15 / 16 psi, especially as you wont spend dollar on something simple like mbc :p
Old 10-01-2009, 02:28 PM   #23
Magnum TE
Formerly Infector 944
Magnum TE's Avatar
I ran this setup for a while with a pair of g-valve boost controllers. It's fairly simple using a dodge 12v vacuum solenoid valve. 2$ with pic-and-pull pocket discount +10$ at Grainger to make 2 G-valves.
^ that's why I don't run the 2 boost controllers anymore, I had one at 15 psi and the other at 25... there was a lot of ping ping ping, boom! one night.
B230F+T...
Just bolt it on and.......... PAH!!!!!! AWESOME WILL HAPPEN
doug loves me
Magnum TE is offline   Reply With Quote
Old 10-01-2009, 02:38 PM   #24
Quattro
Quattro's Avatar
Well that motor did stay together till 35psi and that was a weak K block.I didn't skimp on anything on either of these cars still using common sense lol.
20+ is a whole new world of power and i cannot get enough.
Old 10-01-2009, 03:04 PM   #25
MrT_VolvoDestroyer
so what fails on a sloppy redblock 8 valve at 20psi?
I'm scared.
Obviously i'm only running a cruddy m46 with o/d yum for all your favourite box clunks. So i'm guessing to go beyond 15 psi i *SHOULD* m90.
I was destroyed by an audi rs 6 (or 8) estate.
It was very sexy and i was clearly holding him up dawdling at 90 ish on motorway. I moved in to let him by and he musta been going at least 20mph quicker than me when he passed my wing mirror!! This thing was fast.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
