Old 01-13-2006, 09:21 AM   #1
Steve C
Steve C's Avatar
Default wide band O2 sensor controller/gauge/output - what to buy
I want a wideband O2 sensor and some type of readout/gauge to monitor mixture. I have read about a build it yourself kit but can't find it.
If the wideband sensor outputs a certain voltage for a certain mixture couldn't I just use a digital multimeter to monitor the mixture?
91 940 Turbo, MBC, cut fronts, more to do...
89 765 Turbo, fresh B230FT, hybrid TD05@14#s, intake, exhaust, cut fronts, 250# rears, dual f sways, rear bar
Steve C is offline   Reply With Quote
Old 01-13-2006, 11:27 AM   #2
Patrick
www.wbo2.com - I have the ready built kit though. Very happy with the meter.
member of Team AP-Turbo Racing
1984 Volvo 245T 303 RWHP@16 PSI but now @20 + mods -> 396 (Theoretical) RWHP
1979 Porsche 931 ~400 hp
Patrick is offline   Reply With Quote
Old 01-13-2006, 12:04 PM   #3
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
i love my lc1, i have had zero problems, you can change the outputs to whatever your gauge needs, you can have a liner 1-0v to use w/ a nb02 gauge but since it is linear it is much more usefull
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 01-13-2006, 01:03 PM   #4
kyle242gt
Building a 5.044, slowly
kyle242gt's Avatar
The Tech Edge kit is a big assembly job; be sure you know what you're getting into beforehand.
The gauge component is not that expensive and is nice to have.
If you're running MS or other EMS, though, it may not be necessary... depends on how much you want to monitor AFR after you're done tuning.
Either way, I've been running my TE kit for two years and change, and it's been dynamite. I ran for many months without the gauge and didn't really miss it.
Originally Posted by Husky42 View Post
I also do not really get the hippie car comment.. since when do ****ing hippies drive old volvos?
Originally Posted by stickbuilder View Post
You don't grow wealthy by working your ass off.
Originally Posted by vBulletin Message
You have been banned for the following reason: Trolling
I have lost my bloomin mind!
kyle242gt is offline   Reply With Quote
Old 01-13-2006, 01:46 PM   #5
ovlov760
Daddy. Coma.
ovlov760's Avatar
Innovate now offers a $200 RTR wideband setup that looks pretty good. I have a Techedge unit but I would have bought this instead had it been available at the time.
http://www.innovatemotorsports.com/products/lc1.php
1997 850 200k
1997 850 T5 125k ARD white tune
1988 760 Turbo - Sold
Old 01-13-2006, 02:59 PM   #6
The Aspirator
It's a girl!
The Aspirator's Avatar
I love my Tech Edge. I've got the display too, and like Kyle for a few months I was running without the WB (cause it was in my brothers car) and I didn't really miss it, but when I put it back in MAN did I ever love it again. I've been running mine nonstop for nearly two years now and haven't had a single problem. Building it yourself IS quite a task, since it has about 4x as many parts as a megasquirt board, but I had a good time doing it. And at the time when I bought it worked out to be only $230 for the DIY WB, display, and sensor.
http://www.vipinfoservices.com/john/...wideband02.jpg
http://www.vipinfoservices.com/john/...wideband03.jpg
Though if you don't want the display and have MS, the $200 innovate one sounds schweet. And no you can't just get a $30 WB02 sensor and monitor the mixture with a multimeter, these sensors need to be heated to an exact certain temperature and kept there all the time. I think the heater part takes up most of the board and the signal decoder is much simpler.
John
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 01-13-2006, 05:57 PM   #7
ovlov760
Daddy. Coma.
ovlov760's Avatar
John
I love my techedge too, it's just the DIY part of it that was a drag. I've had some harness problems with it that i've had to fix, but since that it has worked perfectly.
Old 01-13-2006, 06:29 PM   #8
Renny_D
Renny_D's Avatar
+1 for overall ease.
Renny
90 740 T with a dented S90 exterior and interior, front mount fleabay 24x12x3 almost bumper cooler, 3"inch exhaust, IPD springs, Bilstien HD, KG2T cam, LSD, MSD 6A, CFIs @ 46psi, 960 amm, SSautochrome flipped header and Holset hy35 goodness and extra hp in a gymbag.. - MS coming - never track run this year so no idea about the combo's power - dyno day to come.
Renny_D is offline   Reply With Quote
Old 01-13-2006, 07:20 PM   #9
foggyjames
Ryan's spanner monkey
foggyjames's Avatar
I bought the Innovate LC-1 and the XD-1 52mm gauge. Pricey, but very damn nice!
cheers
James
'05 V70 D5
'88 360 Turbo Intercooler
'84 360 GLT
'81 343 GLS R-Sport
'80 343 DL
'69 164
PM me if you're looking for Euro parts!
foggyjames is offline   Reply With Quote
Old 01-13-2006, 07:40 PM   #10
olov
doing something stupid
olov's Avatar
damnit!
88 244 - m47 - on the bumpstops - 366k on the clock
83 245t - m46 - the green monster - 130k - 260whp/280tq with a lot on the table
94 z28 - t56 - pull me over red - 100k
Old 01-13-2006, 09:08 PM   #11
NeoSpeed740ti
the phat mechanic
NeoSpeed740ti's Avatar
I run a PLX M300 wideband, and I'm very happy with it. The plastic box that has the display and that controls the o2 sensor feels a little cheap (I just opened it up took out the guts and mounted them in a small brushed aluminum box) but it has both wideband (0 - 5) and narrowband outputs. Just remove your stock o2 and replaced it with the wideband and feed lh2.2 the narrowband output. If the box bothers you plx also sells a 2 1/4 " gauge that runs off the wideband output (looks a lot like the AEM widband) and then you can hide the box.
NeoSpeed740ti is offline   Reply With Quote
Old 01-13-2006, 09:29 PM   #12
740ATL
Guest
I just finished soldering up my TE 2A0 and cable kit about 10 minutes ago. It took me about... forever. It wasn't hard per se, just a whole crap load of components... John's 2nd pic says it all. Surprisingly, I had the hardest time with the cable... hopefully will have it running tomorrow.
Did you guys who have the TE go through the 17 page debugging procedure? didja find any booboos?
I'm having a beer.
Mike
Old 01-13-2006, 11:46 PM   #13
Steve C
Steve C's Avatar
Wow, you guys are great. When I have time I'll look into your suggestions
Thanks
Steve C
Old 01-14-2006, 12:02 AM   #14
The Aspirator
It's a girl!
No I didn't debug mine, but I did end up having ONE resistor in the wrong place. It was a really high ohm resistor when it was supposed to be a really low one, took me weeks before I finally broke down and went to each one with a multimeter and found the culprit. It was obvious that something was wrong though because it would only read between 14.5-14.9.
Old 01-14-2006, 05:29 AM   #15
Nebor
I've got an Innovate LM-1 with the XD-1 gauge. Great for monitoring AFR on the fly and logging your AFRs, as well as RPM and boost levels!
Nebor is offline   Reply With Quote
