Old 01-14-2006, 09:18 PM   #1
VolvoTurbooooo
Default T25???
Hi.
I wondering witch engine have a manifold with T25 flange??
Need too bye one, so I need to kniw where to look.
Thanks.....
VolvoTurbooooo is offline   Reply With Quote
Old 01-15-2006, 12:24 AM   #2
Originally Posted by VolvoTurbooooo
Hi.
Thanks.....
Listen n00b you need to learn how to type, That is pretty harsh coming from Bne....
becareful if your looking for witch engines because they could put a spell on you
Dont let the witches get bye you!
try a 91 940 se.
blkaplan is online now   Reply With Quote
Old 01-15-2006, 12:41 AM   #3
945ti
Devoid of Luxury
try a 91 940 se.
hahahahahahah
ro tyr a '90 + 740 trubo manuel trany car.
Also, all 90+ turbo exh mani flanges are the same, T25 or mitsu.
Originally Posted by adrianpike View Post
Sounds like your solder-fu is weak, much like my crimp-shwartz.
945ti is offline   Reply With Quote
Old 01-15-2006, 07:03 AM   #4
suterman
suterman's Avatar
What engine is it for? A B21?
suterman is offline   Reply With Quote
Old 01-15-2006, 04:42 PM   #5
riseosiris
Modem Killa
riseosiris's Avatar
Having had a T25 equipped '91 B230FT 745, I can say that there is no such thing as a "T25 Manifold." The T25 that came on the volvo has the same bolt pattern as the Mitsu 13/15 types, which is also the same as the T3. There was only one manifold for 90+, just two different turbos. Of course, the Volvo manifold has that funky "lip" or "mount" that goes around the mouth of the flange. So, depending on why you are asking, a standard JDM-type T25/T28 off a Nissan will NOT bolt on, the flanges are smaller. Let me know if you have any questions.
-Lloyd
(And yes, I miss my Volvo, I'm trying to convince myself to get back into the game....Maybe I'll wait and see how The Poi gets along with his project =o)
Freya: 1991 745ti M46: Ported 15G, V15, Getrag 265, Clutchnet 6 Puck Disc & 100% over PP, IPD Sways, Solid Endlinks, Koni Yellows, B&G Springs, Adj Panhard, Blitz Dual SBC, Greddy TT, VDO Gauges, K&N Cone, 3" DP & Magnaflow Exh, "Brown Top" Injectors, Walbro 255lph HP pump, Zimmerman X-Drilled Rotors, EBC Greenstuff Pads, 17" Borbet T's, F 225/45 - R 245/40 Pilot Sports, V90 Tails, Recaro Orthopeds, Water Injection
riseosiris is offline   Reply With Quote
Old 01-15-2006, 05:27 PM   #6
suterman
suterman's Avatar
Default t25
apparantly, the 90+ manifold will fit any redblock, (ie. your b21)
but now i learn the b21 will not run a t25 as it has no oil feed or return and the t25 need these.
Old 01-15-2006, 05:47 PM   #7
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
haha suterman sent me here to explain this....
you'll to make up an oil feed pipe. best place to attach this to the block is the plug at the end of the oil gallery ( i think it's 1.4"npt) and you'll need to have a stainless braided hose with the correct fittings for hte block and turbo made to fit. for return you can ether drill through the block and thread it for a fitting of your choice (i think folk are using about 3/4") then run some flexible hose upto a shortened stock turbo drain pipe or weld a fitting to the top of the sump and run up to a shortened pipe the same as the block fitting.
Mike
Lost my 2004 V40 GDI sport lux in local flooding last november, currently driving a Mercedes E430 avantgarde with prins LPG system (Sorry guys it is fun though)
MikeHardy is offline   Reply With Quote
Old 01-17-2006, 01:35 AM   #8
volvo944ti
you need the turbine housing for teh t35 ro an exhaust manifold that fits the t25.
any 90 plus manifold will fit the t25 turbo as thats what it came on. there is no difference from the 13c and t25 exhaust manifold.
volvo944ti is offline   Reply With Quote
Old 01-17-2006, 04:23 AM   #9
towerymt
the real Towery
towerymt's Avatar
Do it.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Originally Posted by amargill19? View Post
I've always wanted to work in a potato salad factory!
Old 01-17-2006, 04:40 AM   #10
the poi
On a mission
the poi's Avatar
Originally Posted by towerymt
Do it.
I agree. Also, haven't you recently returned from teh coast guard or something? i remember you disappearing many a month ago, and now you're back!
edit:// not you towery.
Old 01-17-2006, 11:00 AM   #11
riseosiris
Modem Killa
riseosiris's Avatar
Actually I'm still in the CG, but I got out of Officer Candidate School about 6 mos ago. I'm stationed in Key West aboard the mighty Cutter Mohawk. We're somewhere in the Caribbean right now terrorizing drug-smuggling "go-fasts." It's great to see their reaction on camera when their outboards disentegrate into bits of metal after a direct hit from a .50 cal rifle =o)
Anyway, I don't really have storage for a project car, but then again, that's never really stopped me b/f. I think I may do the 960 thing, figure out a way to go manual and follow in your footsteps Chris. Of course, I'm sure Towery would get all excited if I came over to the dark side and found a 242 or 245 to play with =o) We'll see. If y'all come across any $500-1000 solid bodies, let me know!
-Lloyd
Old 01-17-2006, 12:32 PM   #12
go the 240 route, it is the true DC metro region tuner choice.
Old 01-17-2006, 02:42 PM   #13
towerymt
the real Towery
towerymt's Avatar
Anyway, I don't really have storage for a project car, but then again, that's never really stopped me b/f. I think I may do the 960 thing...
Helllllllllooooooooo project car. Get a decent '90+ LH2.4 240 and add a turbo. Plug 'n play turbo computers, big rods, cheap & easy. Unless you want 400hp from a delicate, temperamental I6...
Old 01-17-2006, 02:46 PM   #14
acbarnett
SAAB defector
acbarnett's Avatar
hey, I love my I6 like it was my child. Though the more and more I think about it the more I just want to buy a 700 turbo and get it over with.
then there is the $1000 1993 940 turbo wagon I found if you're interested, it's in a great color and I'd love to see it go to someone here. That car already has a turbo, but also has LH2.4, big rods, AND squirters. All it needs is a real turbo and a t5/getrag and you could have yourself one hell of a car. Charcoal gray 940's look hot as hell...
acbarnett is offline   Reply With Quote
