#26 | |
the big 3 0
wow, i totally missed this thread
that car's gonna be the ****. good luck pimping it out before SE so we can all ruin the paint with drool
fix one thing break another Quote:
#27 |
body work hell
whats up with the rear quarter panel?
#28 |
Rob this car has been an inspiration to me since the begining. Keep up the good work. i want a ride in that beast one day.
#29 |
Deep dish gold wheels FTW! What's the specs on tires?
Rob
http://www.pbase.com/242ti/root |
#30 |
what all did you have to cut to get 17x9.5's and 17x8's to fit?
Jonathan |
#31 |
wow, so this is what you had in mind.
![]() hot. waaaaaaaaaaaaayyyy hot. |
#32 |
what did those wheels cost you?
power is nothing without control - a wise man |
#33 |
Yeah who makes those rims? Those are insane.
#34 | |
Has a Built Trans!
![]() Join Date: Nov 2002
The wheels cost roughly $500 a piece, after anondizing and shipping, etc. I bought six, 2 front and 4 rears. Not cheap, but definetly built solidly, and nice and light.
They're made by Kodiak Racing, as stated earlier in the thread. www.kodiakracingwheels.com And the LR quarter was full of bondo, so I cut it off at the trim line and welded another one on. I'm not very good at welding, and didn't prime it yet, so it looks like hell. Body work is coming, I promise I had to do a ton of work to fit the 9.5" wheels. The rear quarters took quite a beating. But it looks good, and will look awesome after the paint gets done. The low rear shot is just crazy, because they stick out so far and have nice meats on them. For tires, I will use 225/45 17 Falken Azenis RT-615s in the front, and will try both 255/40 17 Falken ST-115s and some 235/45 17 Dunlops I have. Not sure if the current power level will allow easy drifting on the 255s. I will have them mounted for the next event, which is coming up on the 11th of March. So stay tuned After that it will get the serious body work done and then off to paint. Thanks for all the compliments everyone!
Rob 1981 242 - tuned by Heebspeed (11.8 @ 114) 1999 Dodge Ram 2500 CTD how psi a stock can support? Quote:
#35 |
i have that same intercooler! "Mishimoto GY30" right? hahaha!
1997 854 GLT - Nougat on the inside boysenberry on the outside Dreaming of a 20B... I also have Bridgette still too |
#36 | |
Wants u 2 use your brain.
#37 |
Is it safe?
Video from the first event this year. VIR Patriot course.
Start: Middle: can't see from the pits End: |
#38 |
I SEE YOU!!!!
do ya drive it back anf forth from the track???
#39 |
Very nice. I'm eagerly awaiting pics and info on how you finnished fitting the 255s. I can't figure out the BEST way to pull the front half of the rear fender out & brace the outer skin.
Rob |
#40 |
Has a Built Trans!
Well, to fit the 255s took quite a bit of work. What I did was drill out all of the spot welds around the fender lip. Then I separated the outer quarter panel from the inner part. I cut the edge off of the inner, where it comes down and bends back in towards the car. I then used a porta-power to push the inner part out, which in turn pushed the quarter panel itself out. Once I had it out far enough, I folded the quarter panel lip up over the inner panel, and welded it up. I will try and get some pictures this week of the work I've done.
Finally got the R brakes on the front on Friday as well, so I will get pics of that too. |
#41 |
Ryan's spanner monkey
Now I'm rather confused...I was under the impression that the breathed on B21 NA was making big power, and ran a seriously quick 1/4 time (for an NA redblock in the US)....like a 14 or something. According to what you've written there (and assuming a figure quoted at the crank), it's making less power than mine
If it did run a 14 with that power, I REALLY need to get a shorter diff and a lightened flywheel in mine and go run something that isn't a 17...Awesome project. That car is lusted over on both sides of the atlantic. Just the other week someone posted a pic of it on V3M. Be sure to keep us posted cheers James
'98 V70R '88 360 Turbo Intercooler '84 360 GLT '81 343 GLS R-Sport '80 343 DL '69 164 PM me if you're looking for Euro parts!
#42 | |
Angrychopstick
![]() Join Date: Dec 2004
Location: Receiving Transmission from David Bowie nipple antenna
#43 |
That's what I thought. Presumably that power pull was with the giggle-gas off, and the 1/4 time was with it on.
cheers James |
#44 |
I think I still have it..
![]() Join Date: May 2003
The 136 was wheel horsepower, and the fastest 1/4 was 15.7 @ 85 or so. The car never ran the 1/4 in the 14s or on nitrous.
Chris GT Spec Turd GLT Spec Gramps
#45 |
Fabricatin'
The dyno reading was off also, the carbs were messed up.
The nitrous was never run at the track. And actually, Rob never really used the nitrous himself I don't think. |
#46 |
Is it safe?
Dyno was just days after a major reassembly, so the tuning and preperation was not quite there. A carb issue also led to what occurred during the runs, as seen below...
136/148 was pretty good considering...but I think we had all expected ~180whp. Yes, it was loud. ![]() But it sounded oh so good. ![]() Hmm, sparks from the side pipe on decel at 6500rpm? ![]() ![]() |
#47 |
Nice work! I was going to ask what RPM it made it at. I'm aiming for upwards of 150 crank with minimal extra work (exhaust, efan, maybe stronger ignition).
cheers James |
#48 | |
Rob |
#49 | |
Section 9
![]() Join Date: Nov 2003
Late to the love fest as usual.
Absolutely awesome ride! I sware 240's rule! ![]()
#50 |
The Sirius/Nova Police
what happened to the carb setup rob
Mike 1998 V40 2.0T CD |
| Thread Tools | |
| Display Modes | |
