Go Back   Turbobricks Forums > Mechanical > performance & suspension > aftermarket engine management
Old 03-12-2006, 12:42 PM   #1
Sinbad the Sailor
Master Destructor
Sinbad the Sailor's Avatar
Default MS knocksense
Is anyone running this yet? I just got a MS v3 and want to know that I'm not killing my engine. What does this do? Does it pull fuel or timing or what? On his website it says that it is superimposed on the CLT signal to MS. But what does a high CLT signal do? Thanks for the help. Also how can you tell if a knock sensor is good off of the car? I would assume hooking up a DMM and tapping the bolt that runs through it with a metal hammer. Thanks again.
Spencer
'85 244 DL - R.I.P
'82 244 TIC - MS/13c/Crane Hi-6/Jacobs Coil/Full 3 in exh/3 Row Nissens/E-Fan
'63 p1800 - Gone to a better place
Originally Posted by tedium
The standard rule of engineering: If you make something idiot-proof, they will just make better idiots.
More often stated: Nothing is foolproof to a sufficiently talented fool.
tim
Sinbad the Sailor is offline   Reply With Quote
Old 03-12-2006, 02:06 PM   #2
ovlov760
Daddy. Coma.
ovlov760's Avatar
I believe it pulls timing based on how much you tell it to. I have been wanting to implement it but I never got around to it.
1997 850 200k
1997 850 T5 125k ARD white tune
1988 760 Turbo - Sold
Old 03-12-2006, 11:09 PM   #3
Boris740
Broad Member
Boris740's Avatar
Spencer
Quite a few people are using it
Along with the LED it has two additional outputs. One goes directly to MS board for timing retard when knock occurs
http://megasquirt.sourceforge.net/extra/knock.html
The circuitry shown on
Is no longer necessary. KnocksenseMS takes its place.
You have to use MS&S - Extra software
The CLT output is optional for dataloging knock events. It is constructed so that it superimposes a short negative going spike on coolant sensor line which is being logged by MS. Under no knock conditions the CLT line from Megasquirt measures the coolant temperature.
Got knock? Got Megasquirt? Check out Knocksense knock indicator and KnocksenseMS indicating Megasquirt interface.http://www.viatrack.ca/
Boris740 is offline   Reply With Quote
