Old 04-05-2006, 12:24 AM   #1
Johnny Lau
Default boost loss diagnoses??...
I was hoping that someone with 10 times the volvo turbo knowledge (that's most of you) could give me some sage advice. I apologize in advance for my fwd-ass....
My '97 850R (mods listed in signature) has lost boost over the past year. I can't recall a specific date, I figure it has just petered out over time. The interesting part (at least to me) is that is has only lost it in first gear - lower speeds. I used to get 2/3rds to 3/4ths into the white of the stock boost guage. Now, from a standing start it hits half, then drops to a third until it shifts into second (auto). It kicks back up to "normal" R boosting after that and almost seems to gain boost the faster I go. Boost hits 85 to 90% of the white at the top end of second gear. I might sound like I'm whining because it still gets up and goes but not nearly like it used to. I had a hard time keeping traction last year even with good 215 width yokohamas on dry asphalt. I'd like to do some minor upgrades (remap and exhaust) but I'm hesitant if these symptoms indicate a turbo on its way out. I've got 130k+ so its no spring chicken. I just had the 120k volvo service done (not at a stealership, I'm not that clueless) and no improvement. The only cheap hope I have left is to clean the aftermarket intake filter and pray that it's just been starved for air at lower speeds. Please share with me your thoughts and advice. Keep in mind that I'm a numbnuts with rusty craftsman tools that I got as a graduation present 15 years ago... thanks
Johnny Lau
'97 850 R - Black and Bad
EST intake
IPD aluminum strut brace
Bilstein struts
17" "Canisto" wheels (anthracite)
Yokohama (summer) / Gislaved Nordfrost II (winter)
relocated horn
Johnny Lau is offline   Reply With Quote
Old 04-05-2006, 12:51 AM   #2
Brickster151
LH 2.2'ing it up
Brickster151's Avatar
Checked for cracked intercooler hoses?....common issue.
Get some Samco Silicone hoses to replace those crap rubber ones. Also might as well replace the vac lines with silicone ones too before you dive in and get an ECU upgrade.
- Patrick
1983 244ti SCCA ITE road race car [94' B230FT, gt3071r, t5, funstuff galore]
1979 Chevy Camaro Hobby Stock dirt track race car
1998 Dodge Ram 3500 Cummins Dually to haul ^^
1996 850R m56 daily driver
1973 1800es restomod project I am building for my mom [b230ft, lh 2.2, 16t, t5 trans]
never forget Doug Williams, Peter Gray & Matthew Dionne.
Brickster151 is offline   Reply With Quote
Old 04-05-2006, 01:30 AM   #3
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Pat nailed it. The BCS's (boost controllers) for some reason like to crap out too. If you do all fresh hoses, and no change just go straight to an MBC.
History: Car 1 | Car 2 | Car 3
Old 04-05-2006, 01:51 AM   #4
Johnny Lau
I did have a slight oil drip from some "minor hose" near the intercooler a while back that the shop supposedly fixed. It had been dripping for quite a while. They had said it wasn't a big deal but something that I should get fixed at some point so I fixed it.
Would restricted flow from the intake dimminish boost only at lower speed. Higher speeds would create higher air flow into the engine compartment and intake so boost returns to normal?..
