Old 04-24-2006, 02:58 AM   #1
the poi
Has been
the poi's Avatar
Default The b6304/t6 hybrid thread!
So I guess I'll start a thread for this whole project. So I have my new T6 motor, or rather, a heinous lump of aluminum and steel:
Sweet mother of god
Thats not an optical illusion. that turbo inlet is seriously only slightly bigger than my oil drain nut
Anyway, I digress,
Bunny! Oh **** I did it again
So after a couple days at the wrenchs, you'll have three equal size piles. The engine, the transmission, and all the crap previously bolted to the engine. There's seriously a lot of crap.
(its 8t88! anyone get the reference?)
Oh, and this can really ruin your day:
THAT was annoying. Always feels like the headbolts are about to snap when taking the head off but I guess that one actually did. Ended up wrapping tape around drill bit to center the bit, drilled it, filled the bolt hole with liquid wrench, and then backed it out with an EZout (first time I actually got one of those things to work, weird...). Everything looks good, scared the hell out of me though at first...
So here's where I'm at: blocks stripped down
Rear drain is tapped for 3/4"NPT
Front drain is plugged with a penny and some JBweld
And I cleaned up the pistons! The sleeves are in fantastic shape: the crosshatch is very clear and there aren't any scrapes. And no cracks in them either.
Tune in next time, where I guess I'll get more stuff done. I'll probably prep the head--I'm using my b6304 head so i can use the PC cams. I'll beadblast it, and swap the t6 exh valves in (assuming they fit and stuff) as they are sodium filled. I'll smooth the ports and polish the chambers too.
One question:
A few of the the 8mm bolt holes on my b6304 head are stripped. I'm planning on drilling and helicoiling them...any reason why I shouldn't? I'd assume the existing hole ought the keep the drill and tap centered and straight right?
Old 04-24-2006, 03:11 AM   #2
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Chris, http://www.volvotechinfo.com/index.c...m.serviceparts order the blue books for the 960 and S80 engine overhaul manuals.
They are cheap and worth their weight in gold. Even tell you for each bolt if they are stripped what helicoils to use ect ect. VeryVERY good info.
otherwise looks great!
Old 04-24-2006, 03:11 AM   #3
mrbman7
meowing daily
mrbman7's Avatar
mmmmm tasty! looking good man!
Project skitstövel underway...
Originally Posted by John V, outside agitator
The actual unit of measure we are trying to increase is the Dollar/laugh ratio
Originally Posted by 405Mi16 View Post
there's a tree to your left. it looks lonely. i think it wants a hug.
mrbman7 is offline   Reply With Quote
Old 04-24-2006, 03:42 AM   #4
PWRPUFF
narf!
So small I can imagine a quad turbo setup ...
(So who's gonna be the first benchracer doing this? )
Cheapest plug you can get, really! It's sorta like how the vintage crowd plugs the FI ports on the B20 engines with nickels. 20 cents doesn't even buy one freeze plug, let alone a penny!
-- Kane ... oh, and JB weld for teh win!
 crankcase ventilation mod! -- 500dollar744ti
 Eh - you've still got three good rods, just up the boost a little more to compensate for the missing rod. -- JohnMc
PWRPUFF is offline   Reply With Quote
Old 04-24-2006, 04:08 AM   #5
DaButcher
Do a Burnout!
DaButcher's Avatar
Hi,
Will you run this on MegaSquirt?
DaButcher is offline   Reply With Quote
Old 04-24-2006, 04:21 AM   #6
blarf
blarf's Avatar
I think the only do not repair threads are in the block and/or intermediate section. Doug's right, the manuals have all the thread specs and **** that you'd want to know.
http://blarf.homeip.net/greenbook/album/TP2103201/p043
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 04-24-2006, 04:24 AM   #7
adrianpike
adrianpike's Avatar
Originally Posted by DaButcher
Hi,
Most likely.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 04-24-2006, 04:26 AM   #8
MikeHardy
The Sirius/Nova Police
MikeHardy's Avatar
nice thick walls on that one.
MikeHardy is offline   Reply With Quote
Old 04-24-2006, 07:54 AM   #9
olov
doing something stupid
your skills > my skills
i'd be so scared to tackle a job like that, mad props
Old 04-24-2006, 08:51 AM   #10
phillazenby740t
Snorting coca cola
phillazenby740t's Avatar
seriously, props on the courage to swap everything out, but dude, I learned, by my own error, than when you swap, keep your parts well organized and labelled. I think you might be cursing when trying to find which bolt goes where and which parts went where. Im not too worried tho, you'll figure it out, just might curse a little more than necessary.
Good luck, cant wait to see it
"Some drink from the fountain of knowledge, others just gargle"
phillazenby740t is offline   Reply With Quote
Old 04-24-2006, 09:38 AM   #11
BDKR
Section 9
BDKR's Avatar
Holy crap Chris, that post was hilarious.
Yep! Just as ugly.
For all you Dijkstra fanboys:
Old 04-24-2006, 10:31 AM   #12
VQ
Not such a PRVert Anymore
VQ's Avatar
That transmission realy is massivly tiny!!!
Old 04-24-2006, 12:51 PM   #13
the poi
Has been
the poi's Avatar
http://blarf.homeip.net/greenbook/al...43?size=medium
sweet jeebus, nice! And all the cam aligning info too... gonna need it, the cam and crank marks are in different places on the t6 and 6304 stuff. hopefully the crank mark is the same...
Old 04-24-2006, 12:59 PM   #14
acbarnett
SAAB defector
acbarnett's Avatar
get some pictures of the doofy mechanical lifter head if you can...
acbarnett is offline   Reply With Quote
Old 04-24-2006, 01:01 PM   #15
JW240
All idiot, no savant
i have a volvo tech manaul about the 960 engine. torque specs, alignments, everuthing IIRC. A big pdf file... wanna have it?
edit: I'm uploading it on my server right now...
240 | 1991 | 345K Km | B230F+T | Cosworth T3 60/63 | M90 | TrueTrack (parked for a few months)
dd: 940 | 1992 | B230FB
Old 04-24-2006, 01:07 PM   #16
Hank Scorpio
should be. Straight up theres a lump on the oil pump to match
Old 04-24-2006, 01:08 PM   #17
JohnLane
Chris DO use Time-Serts for your thread repairs. They can be had in any length you like for holes of different depths......Much stronger and more reliable then Heli-Coil.
Thems a pair of teeny-tiny turbos. Small wonder the 'Twin-charged' six is such a slug.
Make it exciting Chris!!
Old 04-24-2006, 01:17 PM   #18
JW240
(hosting expired)
23 mb pdf file, 68 pages, loots of things.
Old 04-24-2006, 03:59 PM   #19
Unregistered
Guest
this man speaks the truth, i would recommend them as well i use them for big brake kits i design and they hold up great. although they do not come in any length which sucks, i have a time-sert chart and manual i work off of and theres just a few different sizes for each thread pitch. so yea use of time-serts is highly recommended from experience.
Old 04-24-2006, 05:51 PM   #20
Series #8217
Series #8217's Avatar
Timeserts = expensive
Chris = has money + smart
Chris + money +smart = get timeserts, do it right
They sell a special TimeSert kit for "when the helicoil pulls out". That should tell you something .
1988 Fiero Track Toy, 2001 Subaru Apocalypse Wagon, 2005 BMW M3
Series #8217 is offline   Reply With Quote
Old 04-24-2006, 06:56 PM   #21
the poi
Has been
the poi's Avatar
I can't find a timesert distributor online that lists a price for the set I need...anyone know where I can get one? And like, 20 inserts?
Old 04-24-2006, 07:11 PM   #22
blarf
blarf's Avatar
Originally Posted by JW240
here is is
You're welcome.
The "original" copy is also available from my site (along with some other manuals and such).
Old 04-24-2006, 07:27 PM   #23
Volvorules
Has a Built Trans!
Volvorules's Avatar
Hey Chris, that was nice But volvo makes a nice little metal plug to go in there, as the later n/a blocks came with return line holes, just plugged I know it's too late, but thought you should know.
Rob
Now with 1 Volvo (hers)
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 04-24-2006, 08:25 PM   #24
the poi
Has been
the poi's Avatar
Ya, but if I'm ever buying a soda and I'm a cent short, I know where to get one. Can't say that 'bout your fancy blockoff plates now can ya?!
blarf: downloaded the full manual from you earlier. gonna be helpful.
Old 04-24-2006, 08:30 PM   #25
olov
<-has $.40 in his intake :P
