Old 05-16-2006, 01:43 PM   #1
volvoluvin
WWD for a while
volvoluvin's Avatar
Default Ordered Centerforce DF...any advice on installation?
Things to look out for?
Besides spline tool, any other special tools to look for?
Experience installing this clutch and PP?
(BTW the application is as it would be on a 240 Turbo, i.e. No step flywheel, 8.5" clutch)
Thanks!
Install to happen in two weeks...gunna get my hands dirty...about time I know!
Cheers,
"Yarth" - 18t, r-mani, 3" Captain Bondo DP, who am I kidding...AND IT'S MANUAL!!
02 Subaru WRX Winter bomber...225whp
volvoluvin is offline   Reply With Quote
Old 05-16-2006, 02:31 PM   #2
kyle242gt
Building a 5.044, slowly
kyle242gt's Avatar
Have you ever had the joy of dropping the trans?
You'll need a REALLY long extension. I made it happen with 17mm|3"ext|universal|2'ext|3/8"->1/2" adapter|6"ext|1/2" ratchet. That's to reach the two bolts at the top of the engine/bellhousing.
A block of wood and cinderblock under the oil pan will keep it from dropping too far when you remove the rear crossmember.
Disconnecting/reconnecting the clutch cable will be way easier if you remove the bolt the clutch pedal rests on at rest (take a look, you'll see it 10mm head, about three or four inches long with a rubber sheath).
You'll also need to address the OD wiring, I think it unplugs under the carpeting.
Originally Posted by Husky42 View Post
I also do not really get the hippie car comment.. since when do ****ing hippies drive old volvos?
Originally Posted by stickbuilder View Post
You don't grow wealthy by working your ass off.
Originally Posted by vBulletin Message
You have been banned for the following reason: Trolling
I have lost my bloomin mind!
kyle242gt is offline   Reply With Quote
