So without going to camber plates - though that is a good option - how can we add more caster to 740s. I was just looking under the hood and it doesn't look like you could redrill the holes further back as they are already pretty far back. Could the struts be rotated and then drill new holes? I haven't looked at how the spring seats up there so that may not be possible. I've heard of people shimming the lower arm forward? I don't auto cross so I can deal with having more steering effort and I'd really like to get more high speed stability and a little more grip in the corners. So what have people done or what can be done?
Thanks Renny
90 740 T with a dented S90 exterior and interior, front mount fleabay 24x12x3 almost bumper cooler, 3"inch exhaust, IPD springs, Bilstien HD, KG2T cam, LSD, MSD 6A, CFIs @ 46psi, 960 amm, SSautochrome flipped header and Holset hy35 goodness and extra hp in a gymbag.. |
There are different lengths of the lower control arm. I think the longest was on 940's with 16" wheels from factory, but since you got a 90 740T I thing you should have got Hydras on it, and maybe you got them too??
I hope someone with VADIS can help you out on this one.
Black car: --142 ´68-- Yellow car: --142 GL ´72-- 70's rally-car wannabe White car: --744 GLE ´88-- Polishing object Blue car: --S70 GLT ´00-- Daily driver |
Is it possible to shim the control arm forward? If so how do you do that? Bkdr wanna make adjustable arms?
Renny |
#4 |
Also, bigger bushings. I believe IPD redesigned their strut rod bushings to be a bit closer to normal size within the past few years. OTOH, the other places like FCP Groton may still sell the oversized strut rod bushings.
#5 |
I shimmed them by putting 2 concave rings (like a 5mm shimstack) behind the (in my case IPD-)control-arm bushing.
You need to completely remove the reaction-arm in order to be able to place the rings. Volvo also supplied OEM-Taxi-reaction-arms which are a bit longer (don't know the VADIS-number though) The have the same increased caster-effect. For the 240 Volvo had a similar OEM-mod available. It looks a bit iffy because the wheel is pushed forward and is no longer located exactly in the centre of the wheelwell but the benefits in cornering are well worth it.
DD: Volvo V70-T5-LPi geartronic, my2001|BMW e9| Kawasaki ZR1100 Zephyr |
#6 | |
Thanks Renny |
#7 |
Membro
I have heard it is possible to pound out the 2 strut top mount studs and move the strut top to where you want it then drill holes in the mount via the existing holes in the strut tower.
#8 |
Those rings I used are very common in chassisapplications where they are used to retain rubber bushings. They are shaped like dish. I just picked them up at a local garage.
I have to admit that making the adjustements on top is technically the better option (no messing up of the ackerman-geometry when adjustments of caster and camber are made on top.) but much harder to do too. |
#9 |
I checked with my local dealer today, there are an acessory control arm that are 396mm. costs ~500SEK =~$70 each.
Stock ones are 385mm, or 388,5 or 390 depending on version, if the car have had problems with unstability during braking and so on... |
#10 |
I am the anti-bling
Don't know about the 740 but on both my 760'a the 2 bolts on top of the strut aren't symetrical, so I unbolted the top rotated the seat and bolted it back, hey presto an eyeballed increase of about 5deg of castor, wheel is very close to the same place and I can feel the difference through the steeringwheel.
Ahhhh. I see the screw-up fairy has visited us again. 760Turbo - with filthy great big 60trim T3/T4, sitting on my bench that is.... |
#11 | |
Thanks Renny |
#12 | |
To change the camber, you'd want to drill the strut tower and/or mount. Are you looking for more camber or caster? |
#13 |
Now for the excuse
#14 | |
Thanks Renny Last edited by Renny_D; 05-25-2006 at 11:38 AM.. |
#15 |
Looking at my struts rotating the top will give you less caster. Positive caster is when the top is trailing the bottom. To give more caster you want to move the top of the strut rearward, or the bottom of the strut forward.
#16 | |
Thanks Renny |
#17 |
Now it makes sence It could work. Go to a bone yard and try it on a junker. I think getting the longer arm would be a better rout. My .02
#18 | |
Guest
There is an issue strut towers moving with age making alignment more of PITA. Suggest, when you get the alignment where you want it, brace everything even if you have to fabricate your own braces. |
| Thread Tools | |
| Display Modes | |
