Old 03-13-2007, 04:01 AM   #101
Ruben
Ruben's Avatar
Ok Thanks
yeah I knew but don't think I'll be running ethanol before the summer....
Ruben is offline   Reply With Quote
Old 03-13-2007, 01:30 PM   #102
Ruben
Ruben's Avatar
Do you know where to get injectors for a reasonable price....I've been searching ebay, the 750 cc injectors I've found are all in the pricerange of $350+
Old 03-13-2007, 04:40 PM   #103
frpe82
Guest
These are very good:
600cc/min (57lb/hr): http://www.racetronix.com/3102FM.html
788cc/min (75lb/hr): http://www.racetronix.com/3145FM.html
Or you can try to get a set of 490cc/min (46lb/hr) CFIs or larger. Some people on the forum can get them pretty cheap, and I think that some are for sale now too.
Old 03-14-2007, 03:58 AM   #104
Ruben
Ruben's Avatar
That price is a lot better than the ebay stuff I've found, Thanks!
Just another question, What do you think about a grooved head and running ethanol?
Old 03-14-2007, 08:19 AM   #105
frpe82
Guest
Only positive results IMO.
Bump the compression a lot as well.
Old 03-14-2007, 07:02 PM   #106
Ruben
Ruben's Avatar
so maybe wit grooving I could raise CR or boost even a bit more? Do you know of anyone running ethanol with a grooved head?
Old 03-14-2007, 07:05 PM   #107
frpe82
Guest
No, I dont know anyone who uses a grooved head.
But you can still run the same amount of boost even though you go from 8.7 to ~10:1 CR. That is one great benefit of ethanol.
Oh, and running 12.5:1 CR is almost standard on the Swedish forums when it comes to converting NA B230s to ethanol fuel.
Old 03-27-2007, 03:27 PM   #108
SteveMD
Membro
SteveMD's Avatar
Is E85 clean-burning enough for me to dump my catalytic converter on my 'race' 240? I have to keep it road-legal and we do have emissions tests every 2 years or so. They don't look under the car though.
Delaware. Out guido-ing north Jersey since 1787.
Old 03-27-2007, 05:07 PM   #109
frpe82
Guest
Yes it is. I think you will be alright at the test without a cat.
I actually had to dilute the E85 in my tank with some gasoline to get the wideband at the testing station to show some normal levels. Haha... The values were so low that they thought something was broken. It was with a very new race-cat on the other hand, but still.
Old 04-08-2007, 11:50 PM   #110
jeff440sc
Default Mass Air meters
You guys are switching to bigger injectors but no one has addressed mass air meters, Mass air meters are calibraited to injector flow rates . If you switch to bigger injectors than mass air meters should be calibraited to the right size injector with the proper voltage scale for the type of fuel being burned in order for Air fuel raitios to be right. Or does everyone here have speed density cars ?
jeff440sc is offline   Reply With Quote
Old 04-09-2007, 07:45 AM   #111
frpe82
Guest
When switching to E85, the AMM will still be correctly calibrated since E85 requires larger injectors.
Stock AMM + gasoline = 31lb/hr injectors.
Stock AMM + E85 = 44lb/hr injectors.
Old 04-15-2007, 02:59 PM   #112
m4ff3w
m4ff3w's Avatar
How is your fuel economy compared to regular gasoline?
m4ff3w is offline   Reply With Quote
Old 04-15-2007, 06:12 PM   #113
frpe82
Guest
This is what I wrote in the first post, and it is still true even though I have done a lot of mods:
E85 has a higher density than gasoline. The change in AFR from 14.7 (lambda=1 for gasoline) to 9.765 (lambda=1 for E85) is 50.5%. But the resulting flow needed is only 42% greater.
Explanations to this: E85 will need a fuel flow that is 42% greater than the flow needed for gasoline. However, it will not use 42% more fuel since it will actually be more efficient. Generally, the engine will consume ~30% more fuel.
My car usually use 12.5L (average) of gasoline per 100km of driving (mixed, pretty normal driving). E85 is supposed to use up 30% more fuel, so my consumption should be 16.25L of E85 per 100km of normal driving.
I have driven the car a lot on E85, and I am going through 65L of E85 in 400km. WOW! That is exactly 16.25L per 100km, just like calculated.
Old 04-18-2007, 11:34 AM   #114
swiftjustice44
Central Coast Brickyard
swiftjustice44's Avatar
It's an old post, but a good one. I'd like to add that I've purchased three of the Holley HLY-512-503-5 from summit and all three regulators had diaphrams that failed! I don't know if they're a bad batch or just old...but at a hundred bucks a pop...I'd look elsewhere. All three failed long before max. fuel pressure was realized.
________________________________
Used to have a few old Volvos...a couple even ran...
feedback thread
http://forums.turbobricks.com/showth...swiftjustice44
swiftjustice44 is online now   Reply With Quote
Old 04-23-2007, 03:43 PM   #115
SteveMD
Membro
SteveMD's Avatar
I was about to get one so that is good news, however bad. Thanks for the warning.
Old 04-23-2007, 03:46 PM   #116
SteveMD
Membro
SteveMD's Avatar
Fred,
How does using E85 affect N/A performance camshaft selection? I am looking at KGT cams and I will be running 12:1 or more CR in a car that will see mostly autocross use. I am also willing to gear it down from the stock 3.31 rear to 3.73. (240 series)
Thanks, steve
Old 04-23-2007, 06:17 PM   #117
frpe82
Guest
Fred,
Thanks, steve
In an NA car you can run a very high CR. What people usually prefer when running E85 is 12:1-12.5:1 actually.
With that kind of CR you can run a very wild cam if you want to.
Old 04-25-2007, 03:48 PM   #118
apfelschorle
Guest
if i run my car on about 40% e85 an 60% 95 octane fuel without converting, because converting Is not worth the effort, the only e85 station i know is about 30 km away and so i'll be there once a month or so. And i just want to know if this ratio would work and could it damage the engine?
thanks in advance
Old 04-25-2007, 04:53 PM   #119
frpe82
Guest
thanks in advance
It depends on the car and type of engine.
What do you have?
Old 04-25-2007, 05:11 PM   #120
apfelschorle
Guest
it's a 1998 peugeot 306 1.4 wooohooo :(
Old 04-25-2007, 05:20 PM   #121
frpe82
Guest
Then I am 95% sure that the mix of 40/60 will work.
It is naturally aspirated (no turbo), right?
If the Lambda-light or engine malfunction light turns on, then the blend of E85 is too high. I am most definitely sure that it will not be harmful to try it.
Old 04-25-2007, 06:12 PM   #122
apfelschorle
Guest
nice, i'll try it next time and yes, no turbo
thanks
Old 05-08-2007, 06:49 AM   #123
JW240
All idiot, no savant
JW240's Avatar
Another happy E85 user:
1991 240 B230F LH 2.4 (pink label 561), greentops from late turbo model 940 + resistors, stock n/a 2.5 bar fpr, timing advanced a bit with the selector-pins of EZK.
The greentops flow about 280 cc/min at 2.5 bar, the stock yellowtops flow 176 cc/min, so thats a 60% increase...
car ran rich on petrol with those injectors and shaked violently (so hard that the mechanical fan hit the shroud), but smoothed out after a few minutes. had to re-learn after every longer re-start (the next day eg). Engine had a slight knocking sound, like slapping pistons, but it went away i think.
I wired the resistors in the green-white cable at the ecu (pin 18 from LH), in parallel, works great.
With E85 in the tank it doesn't need to re-learn anymore and runs strong. i didn't check the mileage or the plugs yet, but the first impression (100 km of driving) is very good.
Fred, thanks for the article and support via msn etc!
240 | 1991 | 330 KKm | B230F+T | Cossie T3 60/63 | M90 | TrueTrack
Husaberg FE450 '12 supermoto swapped
Old 05-14-2007, 06:51 AM   #124
Ruben
Ruben's Avatar
@fredrik:
Any news concerning chips for E85?
Old 05-14-2007, 05:36 PM   #125
frpe82
Guest
@fredrik:
Coming this summer...
