Old 07-13-2006, 06:38 PM   #1
UsmcScott
UsmcScott's Avatar
Default Muffler Exhaust Repair Cement
My axle pipe busted off my muffler (rust). I just want to use one of those little 3 inch adapters to put the two back together (no welding). Has anyone had any success with muffler repair kit glues or cements ? What brand ?
UsmcScott is offline   Reply With Quote
Old 07-13-2006, 06:39 PM   #2
PWRPUFF
narf!
The repair kits are OK for a hole, not for when a pipe actually rusted through and splitted.
Time to replace the exhaust.
-- Kane
 crankcase ventilation mod! -- 500dollar744ti
 Eh - you've still got three good rods, just up the boost a little more to compensate for the missing rod. -- JohnMc
PWRPUFF is offline   Reply With Quote
Old 07-13-2006, 06:40 PM   #3
Slowcars4life
Broken Brick
Slowcars4life's Avatar
I used one of those patches on my girls civic. I used it with an extra clamp in the middle for extra security. Its been on there for about 5 months now and still holding. I can't remember the brand though.
03 Sentra SER Spec V(much slower than the 940)
Slowcars4life is offline   Reply With Quote
Old 07-13-2006, 06:46 PM   #4
UsmcScott
UsmcScott's Avatar
Thanks guys, I can get the pipe to stick in the muffler with the adapter. I can wire it to the muffler to prevent it from ever blowing off, but I would like a good cement that will seal it too.
Old 07-13-2006, 07:01 PM   #5
neptune
2.1L 2.3L 2.8L 2.8L
neptune's Avatar
It will not last forever. They do a decent job though.
I used one on the downpipe of the diesel for about three weeks, until I could get the cash and parts together to replace it. Its better than having an exhaust hole and the associated noises and stinks in the cabin, but it wasn't as good as the fixed downpipe is now. It still made a bit of extra noise, and it is very hard to walk the fine line between "not clamped enough to stay on" and "overtightened and crushed the rusty pipe".
www.neptune242.com
1981 242 Turbo |1996 850R |1980 Coupé (Project)
neptune is offline   Reply With Quote
Old 07-13-2006, 07:06 PM   #6
ovlov760
ovlov760's Avatar
I have never had any luck with the stuff.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 07-14-2006, 09:37 AM   #7
jwernerny
jwernerny's Avatar
It works fine until it gets wet. The best success I have had [when I have needed it] is to put it one then put a water proof barrier on the outside [read: aluminum can with hose clamps].
- John
John Werner
* 1993 965 * 1994 964 * 2004 Honda Odyssey *
jwernerny is offline   Reply With Quote
Old 07-14-2006, 11:04 AM   #8
UsmcScott
UsmcScott's Avatar
Hi John, what works fine ? brand name ?
Old 07-14-2006, 01:26 PM   #9
adobe_brick
adobe_brick's Avatar
Default RTV Silicone High Heat
The perfect solution.. I have used this for patching mufflers, wood stove ... $1.99 cheap!!
Specially fomulated for high temperature applications to 700°F (370°C).
* Safe for all car models
* Won't foul computer sensors
* Resists high pressures to 5,000 PSI
* Stands up to oil, antifreeze, grease, and transmission fluids
* Remains flexible when dry
* Resists shrinking and cracking
http://www.harborfreight.com/cpi/cta...emnumber=90026
adobe_brick is offline   Reply With Quote
Old 07-15-2006, 08:07 AM   #10
UsmcScott
UsmcScott's Avatar
Thanks Adobe, that's a different approach. I would have never considered gasket goo !
Old 07-15-2006, 02:32 PM   #11
adobe_brick
Default Larger holes
For larger holes, I used metal sheathing applied gasket goo with couple three metal screws.
