Old 08-31-2006, 08:20 PM   #1
imorgan202
Default My 144 sits really crooked. Help?
I tried searching around first, but I couldn't find anything related to a car on stock springs.
So, I just bought a '74 144 last weekend, and it's great! I've never had so much fun with an older vehicle. The engine is rebuilt, and can cruise at 75 all day long.
The car does sit rather crooked though. The passenger's side is probably about 1" higher than the driver's side. I can find no signs of an accident, and the ride is fine--the shocks aren't blown. The car does pull to the left though. I don't really know where to start with this, and hoped for suggestions. Is it a simple case of saggy springs? Any help would be great. I'm enjoying her anyway. In the mean time, a couple pictures of her current state.
imorgan202 is offline   Reply With Quote
Old 08-31-2006, 08:22 PM   #2
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
sounds like a spring has given up the ghost, mine sags in the back, it did i put 16s in the back and it is level now
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 08-31-2006, 09:33 PM   #3
ElPiloto
You could replace the springs. Stockers from the junkyard don't cost too much.
Or you could put it on a frame machine. It shouldn't cost too much just to make the measurements that would tell you if the whole chassis/body is tweaked or true.
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 09-01-2006, 10:50 AM   #4
gsellstr
gsellstr's Avatar
I too would vote for a weak spring. Time to throw on some 15x6 or 16x6's and a set of springs.
Fronts are 140-specific, but being a 74 you can use any 240 spring in the rear.
RIP Doug "Mr. Doug" Williams, 4/15/2009
74 144 B20
90 745Ti, AW71L, IPD bars/springs, Koni SA's, JVAB B230FT, Big Valved 531 head, IPD Turbo cam, GT2871R @ 18psi, TLAO chips, E85, NPR, 3.5" DP, 3" DP-back, MSD, TruTrac, Wilwood BBK
If you need Superpro bushings PM me or check the current GB, running until 3/31/13 at http://forums.turbobricks.com/showthread.php?p=4493644).
Old 09-01-2006, 11:48 AM   #5
imorgan202
Thanks for the replies everyone. That's a good idea about the frame machine. I was/am hoping it's just a spring though, for it would be great to "have to" lower it. You say "any" 240 rears will work. Is this so I can choose a stiffer spring? What would you choose?
Since you mentioned 16" wheels...anyone have any good resources for wheels in this size? I read that the bolt pattern is 5x108, and that's just odd. TireRack doesn't have anything, and IPD's wheels (which I really like), only come in 15s. I'm not really a fan of other OEM wheels because if I'm spending money to replace something, it's going to be lighter.
Trying to gain as much knowledge as I can. Thanks!
Old 09-01-2006, 11:51 AM   #6
gsellstr
gsellstr's Avatar
If you want stiffer, find a good set of wagon springs. Otherwise any lowering spring should fit. Kinda personal preference on that.
Old 09-01-2006, 12:06 PM   #7
fivealive
fivealive's Avatar
there are only a few 16" OEM Volvo wheels that come in 16" sizes.
Galaxy (EU only I think)
Hydra (pretty common, found on some 740 turbos)
Otherwise Ronal www.ronalusa.com makes a lot of nice wheels in 5x108. They don't have pics of them on a 140-series, but anything that fits a 240 should fit your car. Also, IPD sells Eikers, which are 17" and could be made to fit your car with some fender "adjustments"
fivealive is offline   Reply With Quote
Old 09-01-2006, 04:17 PM   #8
JE Jr
JE Jr's Avatar
Volvo are selling out the Galaxy now in Sweden. 1495 SEK each (~200USD) including Tire!!!
You should have a spring spacer left front! Probably that one is missing.
Check out the parts catalogues at www.gcp.se and you will see what piece I mean.
Black car: --142 ´68--
Yellow car: --142 GL ´72-- 70's rally-car wannabe
White car: --744 GLE ´88-- Polishing object
Blue car: --S70 GLT ´00-- Daily driver
JE Jr is offline   Reply With Quote
Old 09-01-2006, 05:27 PM   #9
imorgan202
Cool info on the wheels. I'll have to check on that spacer. It's great how helpful you all have been. Not often do I find a forum where people are truly nice.
Ian
Old 09-01-2006, 05:44 PM   #10
gsellstr
gsellstr's Avatar
Even if the spacer is missing it shouldn't be much more than a half-inch or so. It's more of a cap than a spacer. Unless you've got one side that's not seated and the other is. You might take a look with the shocks out up front and make sure both front springs are seated at the top. If the ball joints were replaced they have to pull things which allow the spring to move usually. Installing everything again and a lack of attention may allow the spring to get compressed without being in the upper seat correctly, which MAY cause the difference in height.
Hope that made sense.
Old 09-01-2006, 07:42 PM   #11
ElPiloto
The first thing you should have done is stick your head under the car and looked at the springs. Sometimes they break. Sometimes they just sag from age. (like me ) If you check them all out and don't see any difference. Move on to the other suggestions in this thread.
Oh, the price for all this good advice is that you have to let us know what the problem was when you get it sorted out.
Old 09-02-2006, 08:31 PM   #12
1 riktig svensk
1 riktig svensk's Avatar
Really fat previous owner????
My gallery
....no Volvo in my driveway anymore....
1 riktig svensk is offline   Reply With Quote
Old 09-02-2006, 11:13 PM   #13
Dauntless
No braptraps here.
Dauntless's Avatar
More info on this!?!?!?!
http://zyrex.org/gallery/Cars/DauntsVolvo/
http://www.youtube.com/user/Dauntless244
Originally Posted by Angus242164
Mad Max style road-jousting is still a popular sport among us crazy Aussies.
Dauntless is offline   Reply With Quote
Old 09-04-2006, 09:04 PM   #14
imorgan202
Haha. My friend said that's what I looked like from behind when I was driving it. I'll have to wait a couple weeks to really figure out that happened--low on cash. As it is, this weekend the top alternator bolt sheered off inside the alternator! At least I was able to drill it a tad bigger and put an nut on the other end. All's fun with old cars, right?
Ian
