Took the engine and gearbox out of the 940 today. split the gearbox off and found this...
![]() ![]() ![]() Its greasy, gritty, grey and got all over me! What is it? should I worry?
back from the dead
Rear seal leaking + clutch dust = gunk?
or perhaps your car has created a new lifeform?
__________ MARK i AN Hello. My name is Inigo Montoya. You killed my father. Prepare to die. |
#4 |
Location: England, that little island that everyone fled except me.
Yeah 2nd that, lots of gunk and a pressure washer cleans it back to new.
& & @ ![]() 87 745 Turbo & 88 744 Turbo & 96 945 Sport Turbo 1 RIP, 1 mutating and 1 Daily Driver!!!! |
#5 |
is falling apart.........
looks unusuall to me dont look like oil and brake dust to grey or is that the cameras fault??
Project: 88' 744RS Tic16V Daily Beater: Purple Murple (blackberry purple )940 CD HPT SE SPORT....15G@16PSI Rising rate FPR@4bar K'cam with 3 degree advance and De-cat (soon to be RSI Stg2 cam! |
#6 |
that is the colour, I guess considering the history that this engine has had where containing its oil is concerned I shouldnt be surprised really.
#7 |
I got loads of gunk in the bellhousing of my M90. On mine it is because the dual mass flywheel is busted, and sillicone? from the damping unit between the two masses was thrown all over the place... If you have a dual mass flywheel, check if you can rotate the clutchassembly part relative to the part fixed top the flywheel. On mine there are considerable play.
Stein Ove Vikeboe Norway '80 244 DL USA (Currently under reconstruction) '86 740 Turbo Intercooler (Rusting in peace) '97 940 LPT Wagon (Daily Ride) 240 Turbo by R-sport (Norwegian page) volvo@vikeboe.com |
#8 | |
lol fwd wtf
Quoted from another post....
1998 Volvo S90 1996 Volvo 850R |
#9 | |
#10 |
visst
how much torque is possible with that setup... i guess i need to upgrade the B230FK+M90 combo's clutch/flywheel that i have lying around...
240 | 1991 | 257 KKm | B230F+T | M90H | fuel:E85 Amazon | 1968 | bare chassis | rust fixed | finished 2015+?.... My Gallery, Volvo and other stuff... |
#11 |
mmmm, perhaps I should think about a better clutch.
#12 |
Haxxed?
what does it taste like?
- from Brandon 1988 Volvo 244 DL Da Yellow Parting out the 240 Da Yellos' build thread RIP 8/15/10 |
#13 | |
Guest
Something I posted in another thread a while back:
#14 |
Ill bear that in mind
#15 |
Guest
did you find out what this stuff is yet?
mail some to me... seriously... I need about a half gram to analyze. PM me if you're game. Mike |
#16 |
Does this look familiar???
![]() ![]() Decided it was time to swap the busted dualmass flywheel today. ![]() Gunk probably comes from the busted damper unit between the two parts of the flywheel. ![]() Nicked a LH 2.4 M4X flywheel from an engine standing outside a local garage. ![]() Was a little bit rusty on the contact surface, but came out nice with a little work with a steelbrush on the anglegrinder. Had a clutchdisc and pressureplate for M90 + M4x flywheel lying around. Source unknown. ![]() ![]() From the volvo pn, the disc appears to be a standard 240/740 turbo disc??? The center has M90 splines though. Probably some custom job... The pressure plate appears to be a LUK unit. According to my left foot, it appears to be a strengthened unit, I can feel the muscles in my foot growing by the mile ![]() |
| Thread Tools | |
| Display Modes | |
