Old 09-02-2006, 05:39 PM   #1
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Default blown turbo seals vs blown headgasket
So I need to bounce something off everyone, see if my logic holds up.
I was working on the car today in the shop and it sat basically idling (and the occasional rev) for about 10-20 minutes. Water temp, AFR, oil pressure and temps were fine.
then it started smoking like na SOB around the downpipe and out the exhaust and leaving watery soot on the ground and some oil at the back side of the motor under the turbo.
Now, the car STILL runs perfect, water, oil pressure and temp is perfect. Makes 20" of vac at an idle (norm is 19-20"). I need to let it cool enough to pull the plugs (I JUST put fresh ones in before starting it today) to see what they show.
When it sits for 20 minutes or so then you start it, it smokes bad for a while then as the water temps come up to running temp it damn near stops smoking.
Sounds like blown turbo seals doesn't it?
Old 09-02-2006, 05:45 PM   #2
n xntrx volvo
n xntrx volvo's Avatar
could be, leadown test #'s?
my cars (click me)
I'm not here, Please leave a message after the tone........(or email me).
n xntrx volvo is offline   Reply With Quote
Old 09-02-2006, 06:26 PM   #3
holtzboy
Back at it again
holtzboy's Avatar
Kind of sounds like my 84 242 turbo. Ocasionally it will smoke while idling and it definately shoots crap out of the exhaust. My friend was parked behind me and I covered his bumper with wet crap just from idling and no revving at all. It runs fine and pulls pretty well through each gear, although it does stink because when it spools a lot of oil gets by the turbo seals I imagine and is burning out the exhaust. The exhaust is chopped off by the right rear tire and the fumes covered the paint and part of the bumper. Guess I will find out if its the turbo soon because I am putting on a rebuilt 60/63 and NPR soon.
1. 86 244DL- 1st car & Owned for 15 years, 25mm sways, iPd springs/fronts cut 1 coil, HDs, 2.25" exhaust, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 93 945 Turbo - IPD sways, 3" turboback exhaust, intake, accumulator mod
My feedback thread
holtzboy is offline   Reply With Quote
Old 09-02-2006, 08:20 PM   #4
JonnyScorch
JonnyScorch's Avatar
I'm curious about this one too.. whole different car, but but similar symptoms..my 89 744ti stock garret T3, has similar issues.. I took it off the road last winter due to both a lack of snow tires but most importantly a disapearance of coolant.. Also the coolant seemed to disapear more on quick runs around the block to give the car a run once every week or two.. i had previously driven 2hrs and there was hardly any coolant loss.. this was also on a warmer day(5-10 degrees C) last winter.. so it seems that heat seals up the problem..
It doesn't blow billows of white smoke out like a headgasket should, runs fine, idles smoothly but there's lots of moisture comming out the tail pipe(no cat) and around the wastegate there's moisture that can even squirt(not huge amounts, but enough for drops to form and get propelled by escaping gases) until it heats up to a point where it gets instantly vaporized.. The car also seems to heat up quicker then our other turbo cars, but does not overheat.. Plugs show a touch rich, but no white crap anywhere.. just brown sooty with a touch of black as you get further away from the center... Boost is only set at 10ish, but the car does tend to sit a lot between spirited drives..
JonnyScorch is offline   Reply With Quote
Old 09-02-2006, 08:32 PM   #5
suterman
suterman's Avatar
This is what it looked like when my turbo broke.
1985 Bedford cf. B230e aw71L
1990 240 turbo. b230ft m47 chips
suterman is offline   Reply With Quote
Old 09-02-2006, 08:35 PM   #6
keesue
San Francisco Native
keesue's Avatar
That's exactly what it is - blown Turbo seals...I know...I had that problem just as you describe...exactly
It's just an old Volvo...
Even a crappy old volvo....
'81 Black 242 GLT Turbo bought new, now with over 365K. Installed Factory Intercooler . K-Jet and a/c working righteous. Bilstein HDs; IPD springs, 25/25 sway bars and bottom X-brace; CravingBoost adjustable tower brace with Yoshifab top and bottom chasis braces; Crandandall adjustable poly torque rods and panhard bar; Fred Goeske 25mm rear wheel spacers; Redwood Chair window scrapers; Kenwood/ARC sound system.
keesue is offline   Reply With Quote
Old 09-02-2006, 08:38 PM   #7
Hank Scorpio
LOL thats exactly what mine looks like.
Time to call ATP. I guess I'll have the thing off the car tomorrow.
Old 09-02-2006, 11:38 PM   #8
The Aspirator
It's a girl!
The Aspirator's Avatar
You back in Sac now?
Sucks about the turbo! Brand new, that shouldn't happen. I mean that's why you spend good money for good parts in the first place, they're supposed last! Ohh well, I'm sure ATP will hook you up.
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 09-03-2006, 12:45 AM   #9
Can play the blues
Default turbo smoking
Before you convict the turbo be sure your oil return path from the turbo is clear. While I agree the turbo seals could be marginal. You will also get alot of smoke when the oil return is slow to return the oil to the sump and it backs up into the turbo. It forces it's way out of the seals making it smoke.
The other thought I had is that if you are idling in a shop. Are you using an exhaust fume removal system? You know one of the systems that sucks the exhaust fumes from your tailpipe out of the shop. If you are be aware that the vacuum from those systems can be strong enough to pull oil past turbo seals. That is a lot of smoke, too.
1982 242 turbo. 339k miles. Lots of good changes.
1993 245 Classic, 415k miles, enem V15. 5spd. IPD bars and chassis braces. Simons sport exhaust from Scandix. chipped ezk. Been a good road warrior.
Old 09-03-2006, 12:49 AM   #10
Hank Scorpio
I hope so. i've been doing buisness with those guys for a long time so hopefully they will take care of me. since I have all of 22 dollars to my name right now, Im praying
It was an OEM steel return line, .55" ID iirc. PLENTY large (plus you figure that GT series has a restrictor on the oil line anyways).
I've ALWAYS given it plenty of cool down time and has never seen 20+psi boost before ever.
Old 09-03-2006, 01:14 AM   #11
The Aspirator
It's a girl!
It was running right around 20psi when Carson took me for a ride...
Have you determined if it's oil smoke or coolant smoke???
Old 09-03-2006, 03:21 AM   #12
blarf
blarf's Avatar
Any chance you could pull the o2 sensor and look for coolant contamination, pull the downpipe to eye for an oily mess, check the engine oil level, or do a leakdown test?
Manuals moved here: http://gaz.inferiorhumanorgans.com/greenbook/
blarf is offline   Reply With Quote
Old 09-03-2006, 04:51 AM   #13
shaved240
shaved240's Avatar
isnt that a new turbo? I dont understand why a new gt30 turbo should have blown seals..check to make sure your breather box isnt clogged or anything along those lines.
or check headgasket. Compression test #'s would really narrow this down.
1988 244: b230f+t, M46:PARTED
1995 960: SOLD
1994 945: SOLD
Old 09-03-2006, 11:32 AM   #14
JohnLane
Doug if the turbo seals failed on the exhaust side you will have no oil on your plugs.
Pulled the plugs for a look-see? If oil is on one plug you got motor issues.
Is your intake a really nasty oily mess? Now the question is turbo or blown up engine?
I've seen whiteblocks with big ring-ridges and worn valve guides.
I'm hoping for a turbo.
Old 09-04-2006, 12:10 AM   #15
Hank Scorpio
on the autometer of the boost controller. MAP sensor says 18psi, autometer says 20
There IS water in the gate housing, its all at the bottom of the gate.
John, brand new motor, but will be checking plugs first tomorrow. Decided to help Gary MS his 144 instead today.
It goes under the category of **** happens. Actually I have a feeling I know why, but the plugs that I litterally had just taken out read perfect across every single one. I doubt I had a HG failure while idling in my shop... but I think the seal has been going for a little bit now and Im just now noticing. Breather isn't clogged... every single part on this motor is brand new. I wouldn't do it any other way when I was building it.
Old 09-04-2006, 12:48 AM   #16
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
Forgive my ignorance of your build if you would please, but Is the turbo a Garrett or a mitsu?
By mentioning ATP, I ASSume it is a rather nice costly Garrett, and not a silly mitsu.
Garretts usually use seals that increase sealing pressure with additional shaft speed/pressure. They usually show signs of failure at very low load and start to seep out the exhaust some and just pull oil through into the exhaust.
Mitsus on the other hand seem to actually throw more oil around under heavier load due to seal design.
I much prefer the garrett mode of failure, since you usually get some warning when the car isn't moving with it running that the turbo is failing instead of oil haze sneakily disappearing out the exhaust as you put the car under load at speed and finding out when the car is stressed that the turbo just vanished the oil for your motor.
Anyway, it is a bummer if it is the new turbo or new motor/HG for that matter. How thick is this haze? If it is a little whisp every now and again at idle, it probably won't fail for a while, but still isn't good. Does it smell oily or coolanty? They are usually pretty dramatically different to me.
Best of luck narrowing it down.
How PSI a stock can support?
Old 09-04-2006, 12:50 AM   #17
Hank Scorpio
James that sounds exactly like whats going on as well. Im 99.999% its the seals, if it was a blown HG there would be no way the motor would run how it does.
Im sure ATP will take care of me (it is indeed a GT3071 Garrett). **** happens just gotta move on. Glad I didn't go on the road trip I had planned for yesterday.
Old 09-04-2006, 01:44 AM   #18
ovlov760
ovlov760's Avatar
A blown turbo seal can produce absolutely massive amounts of smoke. When my eBay turbos seal failed on me, there was so much smoke that I couldn't even see the color of the stoplights at intersections. The looks on other drivers faces were priceless though.
2009 XC70 T6
2011 XC90 R-design
1998 V70 AWD
1966 M-B 230
2006 V70R GT
2011 C30 T5M
2006 XC70
1997 850 T5
1988 760 Turbo
Old 09-04-2006, 01:50 AM   #19
rallyvovo
you checked the intake plumbing around turbo in hole?
also, could be the turbo DRAIN line or some seal/ring/gasket along it. id check that.
:::: 9 series pimpin' ::::
rallyvovo is offline   Reply With Quote
Old 09-04-2006, 02:49 AM   #20
Hank Scorpio
Yes. Bone dry compressor side, oil return line (for the 5th time this thread) is completely unobstructed.
Old 09-04-2006, 12:15 PM   #21
rallyvovo
i usually check mine 6-7 times so youre almos there then
Old 09-05-2006, 12:58 PM   #22
Hank Scorpio
turbo's off. IT IS THE TURBO for sure. Exhaust manifold was bone dry, exhaust housing full of water/oil.
Calling ATP in 10 minutes.
Old 09-05-2006, 01:22 PM   #23
The Aspirator
It's a girl!
How much of a beotch is it to remove the turbo from the 850's? Looks tight back there, not dead simple like 240's eh?
Old 09-05-2006, 06:17 PM   #24
Mesoam
Mesoam's Avatar
do it once and you'll curse...do it a second time and "hey that wasn't so bad"
08 XC90 R-Sport
Mesoam is offline   Reply With Quote
