Gregerivn
- Feb 20, 2006
- Cottage Grove, OR
My name is Greg and I am building a 1990 740 turbo volvo. So far most of the small stuff is done. Since i am starting this thread about 7 months into the build i will post pics of what has been done so far.
These are of when I bought the car in Feb of 06
The first thing to go was the original air box and in its place a cone filter. With that one mod I took it to the local track and ran a 15.959
After the track i lowered to car 2in and had a turbo cam from Ipd installed and put on a manual boost controller set at 12psi
Since then thru the guidance of the fine folks at turbobricks.com i sourced an intercooler from an NPR box truck and installed it along with 4 injectors off of mid 80s ford 302 mustang engine and installed a afpr. Next to go on was a 3in down pipe with a 3in cutout back to a 2.5 mandral bent exaust and muffler sourced from TME out of sweeden. For safty I had a innovate wideband O2 sensor installed and to make sure the afrs are safe at wot in went custom performance fuel and ignition chips from sweeden. To cool the intercooler and radiator between runs at the track I installed an efan with manual switch the clearance was super tight and infact more work is needed to fit it in safely. Here are some pics of the engine bay as is before the turbo upgrade.
Here are the pics of the new turbo and wastegate
