Old 09-20-2006, 08:47 PM   #1
Wolfman
Wolfman's Avatar
Default Where to get carpet dye?
I want to spruce up my black carpets with some carpet dye. I removed them to clean them and figure that I might as well dye them why I have the out. Have you guys tried the carpet dye in the spray cans? If so, how is it and where can I get some? In addition, is this type of dye as good as the liquid kind? Where can I get some liquid carpet dye? If you have any suggestions regarding how to dye carpets please include them!
Wolfman is offline   Reply With Quote
Old 09-20-2006, 09:56 PM   #2
smosit
smosit's Avatar
i dyed the carpets in my ES with Rit dye, available at "hobby" stores (like Michaels and Hobby Lobby) or at fabric stores. you'll have to check your machismo at the door. the dye was in a powdered form that i dilluted per the instructions in a windex-like bottle. after cleaning the carpets at the car wash, i sprayed on the dye. it was pretty easy. it's lasted about 5 years now without fading (i keep the car covered a lot, tho')
good luck,
ryan
'67 1800S [B230FT--LH 2.4]
'73 1800ES
'83 245GLT [B230FT--LH 2.2]
smosit is offline   Reply With Quote
Old 09-20-2006, 10:12 PM   #3
bag3lbit3s
You can buy Rit dye at the grocery store...I used it to dye some delrin parts a while back.
bag3lbit3s is offline   Reply With Quote
Old 09-20-2006, 10:32 PM   #4
Wolfman
Wolfman's Avatar
Thanks for the tip! I will go out and get some.
Old 09-20-2006, 11:50 PM   #5
stylngle2003
stylngle2003's Avatar
SEM also has carpet paint
check out www.sem.ws
-Billy
1993 945ti "titebox" (DD)
1985 744GLE (perpetual +t project)
1996 Chevrolet Tahoe Vortec 2WD
1990 Mazda Miata track toy
Old 09-21-2006, 01:38 AM   #6
Wolfman
Wolfman's Avatar
I did my front carpets so far. The dye really works very well. I thought that most of the black would wash out when I removed the excess dye. Although it stayed very black. I'm very impressed. It only cost like 2 bucks a box. I don't know if this stuff would work to convert one extreme color to another, although to spruce up black, it works great.
Old 09-21-2006, 11:41 PM   #7
Wolfman
Wolfman's Avatar
Update: I tried the Rit dye on some really stained tan floor mats that I had in my trunk for some time. After washing them, I dyed them black. Tip: make sure the carpet or whatever you are dying is dry between applications because the material sucks up the dye better. After the first application, the color was not right. The mats had a kind of red tent to them and I could still make out the tan color a little. Although after a second application, with a little more concentrated mixture, the color came out great.
Old 09-21-2006, 11:59 PM   #8
Wren
Porkchop Sandwiches
Wren's Avatar
Any ideas about refurbishing the beige carpet that is found in these cars??
Originally Posted by MAVAWRECK View Post
i think you guys ignore me sometimes cause i dont have a turbo or a black primered hood. I make cool engine noises with my mouth when i drive though.
Originally Posted by ElPiloto View Post
The best in-car (mouse)trap is a snake. If you use a rattlesnake, be sure to remove it before you drive the car.
'83 242
'84 242 GLT
'90 765T
'92 965
'93 245
'97 965
'72 International Harvester 1210 pickup
'85 VW Vanagon
Old 09-22-2006, 12:24 AM   #9
derosa
The Rev
derosa's Avatar
There is usually a decent new replacement available on ebay for around 125.00, if I don't find something at the scrapyard by spring time I'll do that.
98 v70xc running, needs an m66 and full stage 0.
98 v70 5spd- RIP
91 240 +T - RIP, it was fun while it lasted.
79 262c, still currently under construction, but now actually under active construction.
Cuius testiculos habes, habeas cardia et cerebellum.
derosa is offline   Reply With Quote
Old 12-27-2008, 05:45 PM   #10
Gor1la
How does the RIT Dye hold up over time? anything else to this thread?
Gor1la is offline   Reply With Quote
