Yayayaya, hohohooo!!!
Hey all,
I was trying to research the details of this upgrade before the board went buh-bye. I have found some good information that I wanted to share, and I figured we may as well put all the related info in this thread so it's all in one place in case others are searching for the info as well. I work at Volvo so I started out by researching some part numbers. So far, here's what I know as far as AMM part numbers: 1992-1994 960 Volvo 3517569, supercedes to 8602793 Bosch 0 280 213 012 1995 960 Volvo 1271861, supercedes to 8602794 Bosch 0 986 280 014; 0 280 213 025 1996-1997 960; 1996-1998 S90 Volvo 9146483 Bosch 0 280 517 511 Now...from what I've gathered, the only one that works as a direct replacement for the 740/940 series cars is the early (1992-1994) 960 AMM, Bosch number ending in 012. What I'm trying to find out and add to this thread are: 1) Are we sure that's the only one out of the series that works? 2) What's different about this AMM compared to the stock 740/940, and compared to the later year AMM on the 960's? Any info is appreciated. I want to take all of the guesswork out of this. Thanks! |
unbalanced chemical
![]() Join Date: Jun 2002
025 works for some, it worked for me for about 36 hours and then i changed injectors and it stopped working .. never worked again.
otherwise most here have 012's running just fine $$$$$$$$$$$$$ haha
![]() Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
$$$ = Friday. ;)
Is it a direct swap, no modifications necessary? Also, what's different about it anyway? Why is it an upgrade? |
#4 |
unbalanced chemical
well larger than stock means more air flow .. so less restriction, and it throws off the timing and fuel maps, so you need @ least 38-42lb injectors for it to work even close to right i think. main point of it is that is rasies the fuel cutout point a little, along with having the larger 3" in/out allows for more flow than the stock 2.5 one
| Thread Tools | |
| Display Modes | |
