Is it ok if I use Dawn dish soap to put the injectors in the rail?
88 764T R.I.P. 2002 V70 (mom's) |
unbalanced chemical
![]() Join Date: Jun 2002
you do not need to .. if you get new orings(even with old oring) they fit in w/o any issues. i've never had to use ANY kind of lube ever to install injectors and i've prob installed and removed 300+ injectors. if the orings are swollen that bad that you need lube to install them i would not run them as ther eis a good chance they could leak
![]() Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
I got em in, although the soap may not have helped. The whole injector thing has been a pain ever since I lost a retaining clip.
#4 |
Traitor
i use vaseline.
'92 944 Turbo:13.400@99.68. Sold. '90 744 16 Valve. 16.317@85.55. Sold '92 244 http://pbase.com/740weapon |
#5 |
one car, two bicycles
clips dont really matter
#6 |
Yayayaya, hohohooo!!!
Hehe...I either use spit, or fuel. It doesn't take much, they should go in easy. If they don't, your O-rings are old or swollen and should be replaced.
Sean Williams '94 850 Turbo Wagon (daily) :: 14.0 @ 98.5 B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend '75 244GL (project) :: 8.4 @ 85.6 B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar) CLICK HERE for the 244 BUILD THREAD! BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details! |
| Thread Tools | |
| Display Modes | |
