Old 12-07-2006, 03:17 PM   #1
ElPiloto
Default What Are The Differences, B21, B23, B230?
Are the rod and crank measurements different? Does the B23 have the thick cylinder walls like the B21? Which is best for high turbo pressure?
Thanks for answering.
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 12-07-2006, 03:36 PM   #2
ray b
last B230F "L" block with oil squirters at pistons and the hard to get [in the USA]
531 head off the euro E in fact a late model euro B230E is mostlikely the best overall motor
[but good luck finding one] or a boat motor [penta]
B21 is smaller 2.1 L 398 head
B23 has better rods and maybe a better crank 398 head
early B230Fs K block up to 89 have smaller rods 530 head
mid B230 90 to sometime [93?] have bigger rods
last B230 L gets the squirters + is newer { both turbo and normal have the squirters]
ray b is offline   Reply With Quote
Old 12-07-2006, 03:46 PM   #3
ElPiloto
I have an engine out of an 85 245 NA, how can I tell which engine it has?
Old 12-07-2006, 03:52 PM   #4
suterman
suterman's Avatar
theres are numbers cast into it low doen on the exhaust side. the big letters are the block type, the first two numbers of the string near the oil filter hole are the year (i think)
1985 Bedford cf. B230e aw71L
1990 240 turbo. b230ft m47 chips
suterman is offline   Reply With Quote
Old 12-07-2006, 04:24 PM   #5
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Here's something i wrote in the temporary TB:
Volvo Redblocks!
Volvo B18 and B20 Over Head Valve engines.
These are found in Volvo Amazon, Volvo PV, Volvo Duett, Volvo 1800 "The Saint", Volvo 140 and Volvo 240.
Stroke: 80 mm (3.150 inches)
B18 bore: 84 mm (3.307 inches)
B20 bore: 88.9 mm (3,500 inches)
Con-rod length (c to c) 145 mm (5.709 inches)
Firing order: 1-3-4-2
weight approx: 155 kg
piston height, total: 71 mm (2.795 inches)
piston height, pin center to top: 46 mm (1.811 inches)
piston to wall clearance: 0.01-0.03mm
Crankshaft main journal diameter: 63.45 mm (2.498 inches)
Con-rod's bearing's journal diameter: 54 mm (2.126 inches)
Wrist pin diameter (up to 1973): 22 mm (0.866 inches)
Wrist pin diameter (from 1973 onwards): 24 mm (0.945 inches)
Year model 1974 has an 8-bolt crankshaft. Older style crankshaft has only 6 bolts for the flywheel. These engines have a forged steel crankshaft. Also the con-rods on the 6-bolt engines are forged, not sure about the 8-bolt ones though. The cam shaft is inside the cylinder block and valves are being operated by pushrods. Both the cylinder block and the cylinder head are made of cast iron. Exhaust and intake channels are on the same side of the cylinder head.
B30
Used in Volvo 164
Pretty much the same engine as B20, but has two extra cylinders. Same year to year changes apply. The transmission connecting pattern is different to any other Volvo engine. Intake and exhaust channels are in different order than in the B20 engine. All other parts are same, or with only minor changes. The pushrods of the B30 are also shorter than those in the B20.
Volvo B19, B21, B23 engines
These are found in Volvo 240, Volvo 300 and Volvo 740 series cars.
B19 bore: 88.9 mm (3,500 inches)
B21 bore: 92 mm (3.622 inches)
B23 bore: 96 mm (3.780 inches)
Con-rod length (c to c): 145 mm (5.709 inches)
Wrist pin diameter: 24 mm (0.945 inches)
Piston height:
B19A: 46 mm
B19E: (->1983) 46 mm
B19E: (1984->) 46.7 mm
B19ET: 46 mm
B19K: 46.7 mm
B21A Europe: 46.7 mm
B21A: 46 mm
B21E: 46 mm
B21ET: 46.5 mm
B23A: 46.4 mm
B23E: 46.4 mm
Weight: 155 kg
Weight, E-engines 165 kg
In 1975 Volvo introduced a new engine, which clearly is somewhat based on the B18/B20 pushrod engine. These engines still have a cast iron cylinder block, but the cylinder head is cast aluminum. The cam-shaft is on top of the valves inside the cylinder head and it is being driven with a toothed rubber belt. The intake and exhaust channels open to different sides of the cylinder head, so the cylinder head is of cross-flow design.
All these engines have the same crankshaft and same con-rods. Engines from 1975-1980 have weaker con-rods than the newer engines, difference being in the material. Some B23E -engines and all B19ET engines had forged pistons as well. B19ET pistons were made by Kolbenschmidt.
Crankshaft is a forged steel unit, as are the post 1980 con-rods. These are known to be very strong engines.
These engines are tilted approx 15 degrees to left. B23 blocks can be identified by water plugs on both sides of the block. The B19 and B21 blocks have them on one side only.
Early B200 and B230, years 1985 to 1988
Stroke: 80 mm
B200 bore: 88.9 mm
B230 Bore: 96 mm
Con-rod lenght (c to c): 152 mm
Crankshaft main journal diameter: 55 mm
Con-rod's bearing's journal diameter: 49 mm
Wrist pin diameter : 23 mm
Piston height: 39.7 to 41.9 mm
These are the so called weak redblocks. They have skinny con-rods, which are also known as 9mm rods. Not suitable for performance applications. The thrust bearing is also situated in the middle of the crankshaft. These too have a cast iron block and cast aluminum cylinder head. The cylinder heads are interchangeable with B19, B21 and B23 engines. Both turbo and NA version have the same crankshafts and connecting rods, only pistons are different.
There is also a boat engine version of this B230, known as Penta. That one has a forged crankshaft.
Late B200, B230 engines, K-block. Years 1989 to 1998.
These are found in Volvo 240, Volvo 300, Volvo 740 and Volvo 940 series cars.
Stroke: 80 mm
B200 bore: 88.9 mm
B230 Bore: 96 mm
Crankshaft main journal diameter: 63 mm
Wrist pin diameter: 23 mm
This is a revised version of the "low-friction" engine first shown in 1985. The crankshafts thrust bearing is again found at the end of the crankshaft, as in B19, B21 and B23 engines. The con-rods are stronger than in earlier B200 and B230 engines. Those are also known as 13mm con-rods. Same cylinder heads as with earlier B200 and B230 engines. Cylinder heads are also interchangeable with B19, B21 and B23 engines. Both turbo and NA version have the same crankshafts and connecting rods, only pistons are different.
There is also a boat engine version of this B230 too, known as Penta. That one has a forged crankshaft also.
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 12-07-2006, 04:40 PM   #6
ray b
you border guys
did mexico get any E or 531 cars
Old 12-07-2006, 05:13 PM   #7
ElPiloto
Thanks to all of you.
Old 12-07-2006, 06:34 PM   #8
igor
Derby Widow
igor's Avatar
Nice overview! Should it be stickied somewhere?
igor is offline   Reply With Quote
Old 12-07-2006, 08:42 PM   #9
towerymt
the real Towery
towerymt's Avatar
b230f. the worst one.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Old 08-10-2016, 10:12 PM   #10
bobxyz
bobxyz's Avatar
'85 245glt aw71 k-jet -> ms
