gielamonster
- Oct 28, 2005
- Hermosa Beach, CA
Hi everyone. First post here, I've only been reading threads since the forums came back up a few days ago. But my post activity should pick up, seeing as I'm the new half-owner of a 744ti. Black on tan, 5 speed, 200k+ miles. Its in surprisingly good shape. Almost blemish free body, no rust, even runs and drives nicely.
Came with bilstein coilovers, ipd front & rear sways, and the ipd lower chassis brace. Even clear corners and 760 tails.
A lot of the interior was missing, which helped our sale price a lot, but it still had a sparco steering wheel... score!
It's an '85, but someone swapped in the watercooled mitsu turbo somewhere along the line...
My teammate and I picked out this 740 to be our victim... er I mean entry in the $500 24 Hours of LeMons race this July...
http://24hoursoflemons.com/
We were both crew members on this past October's Black Iron Racing team, winners of the people's choice award.
Google Video Link
It was an absolute blast, and we both knew we'd have to field a car of our own in '07. We brainstormed some suitable platforms, and to be honest, the RWD turbo Volvos never made the list. We were thinking MR2/Fiero, maybe even a small FWD turbo hatch. But last week I decided to browse the craigslist "under $500" offerings and came across this Volvo. It didn't take much imagination to see it being competitive so we checked it out the next day at lunch and signed the paperwork after work. Under 24 hours from the first time we actually looked for any car to the time we were driving it home.
It didn't take us long to get things going with the build. This past weekend, we stripped the entire interior and pulled the engine/trans in two days. Our plan is to drop the car down to minimum race weight. Dry ice & chisels on the undercoating. Cutting off any unneeded brackets or panels. Full roll cage, race seat, 5 point harness. Under the hood, we'll keep it mostly stock. A thrice hand-me-downed original Megasquirt (v1.01 pcb) will handle fuel, spark, and boost control (MSnS-E). If we can find one of the cheap cam upgrades, we'll toss that in, and just up the boost & timing with race gas to get a decent amount of power for minimum (nearly zero) dollars in hardware.
Here are a couple shots from the demolition work...
The under-dash wiring harness weighed 30 lbs if it was an ounce.
We can definitely use this forum's advice, either powertrain or chassis, or whatever. After reading some of the threads on here, we haven't built much confidence in the stock manual transmission. Our Black Iron Racing buddies in the 535i had really good results using an ***automatic*** (gasp!) and we're actually considering the AW71 to be a very decent choice. 13 hours of racing, with at least 1 up/down shift every lap (30 second laps) equals about 3000 shifts at 10/10ths. A T5 swap seems like it would be up for the task, but our budget is nil so we have to be able to make an even trade for the parts. Finding an auto owner looking for a manual seems a lot more likely than finding a T5 swap owner looking to swap back to a stock setup.
I've megasquirted 2 different cars at this point, I have a pretty good grasp of whats going on there. We'll run just a standard MSnS-E setup, with a wheel decoder and external IGBTs firing junkyard coilpacks. I do have one question that my searches haven't answered yet. Is there a stock crank position sensor on the '85(+) B230F's? Also, what are the power limits of the stock air/fuel systems? How many hp can the stock fuel pump support? And does anyone have any base fuel/spark maps I can reference when I'm setting up the initial tune?
We absolutely must replace the stock open diff with a limiter of some kind. While welding the diff is certainly a cost-friendly option, I'd much prefer to have a solution that still allowed for the inner and outer wheels to turn at different speeds around some of the tight turns in the race. We'll also be looking for 2-3 sets of spare wheels to race on. We'll likely run one brand new set of r-compounds, and then the spares will be used r-comp takeoffs. Any suggestions for the best/cheapest wheels? Any 15x8's out there? 16x8's? 13x8's?
Let me know what you think of the project. Definitely feel free to toss up links to any road racing related threads, or any info you think might help. I look forward to joining this community, I'm already really impressed with the knowledge base you have built up here.
Google Video Link
