Old 01-08-2007, 08:33 PM   #1
kammer
BLK
kammer's Avatar
Default Shortshifter upgrade
I got my Dale shortshifter today in the mail. I have a couple of questions about the install. There is a lot of greyish grease around the bushings. Do I need to regrease upon reassembly? How is the chrome outer shafter(with the reverse lockout collar) removed from the old lever and installed on the new one? Lastly, I have 3 inches of play side2side when in gear and a throw of 6 inches from 1 to 2. Does that sound normal? Are there other parts that need replacing to relieve the slop? I also, got the bushing kit with the shifter.
Thanks
kammer is offline   Reply With Quote
Old 01-08-2007, 09:27 PM   #2
kammer
BLK
kammer's Avatar
Anyone? I want to put this back together in the next hour or so. Thanks
Old 01-08-2007, 09:44 PM   #3
245gti
Adapting Stuff
245gti's Avatar
There is a roll pin that Runs through the outer sleeve and the core. It's mounted in a rubber bushing. You need to drive that pin out. Then you pull the outer sleeve off the core. Mind your teeth during this exercise...
Re-grease everything before putting it all back together. The new bushings will look after the slop in the shifter. Your throw should go from 6" to 4" and the whole shifter will feel much more connected...
Dale
Old 01-08-2007, 09:52 PM   #4
kammer
BLK
kammer's Avatar
Thanks, Dale. Yes, you did include instructions, however us wankers sometimes need extra help. i did some searching and it sounds like I may eventually want to put a new dowel pin in at the top of the tranny where the intermediate fork connects.
Thanks again
Old 01-08-2007, 11:39 PM   #5
kammer
BLK
kammer's Avatar
Default Need help!
I can get the pin out of the bottom of the shifter. I have removed the set screw and let it soak in wd-40. It still won't slide out. It is difficult to get any tools or leverage up in the tunnel. Any thoughts?
Old 01-09-2007, 12:05 AM   #6
245gti
Adapting Stuff
245gti's Avatar
I think you mean you can't get the lower pin out?
I find some adjustable pliers will work to get it moving. You can usually get at it from the top and get enough leverage on one end to start it moving. Stick it in reverse to expose one end of the pin as much as possible...
Old 01-09-2007, 12:18 AM   #7
kammer
BLK
kammer's Avatar
Thanks for the tip. I did mean can't. I was concerned that the set screw would be rusted on, but it came out no problem. The car has 24?,??? miles on it and it is pretty crusty underneath. I'll try working on it from the top.
Old 01-09-2007, 12:36 AM   #8
kammer
BLK
kammer's Avatar
Dale,
Truly, you are !!!
I went up top. Using a door panel remover I was able to knock the pin out. There was enough of an angle to the tool to get some leverage. I am now inside the house, swapping over the parts to the new lever.
Old 01-09-2007, 02:14 PM   #9
kammer
BLK
kammer's Avatar
I got it all done last night! So far, I am loving the shortshifter. I am now planning to change my tranny fluid to redline or some synthetic.
Old 01-09-2007, 02:23 PM   #10
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
how much is a short shifter?
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 01-09-2007, 03:05 PM   #11
superboosted
You wish you had some..
superboosted's Avatar
Yeah.....I NEED one too,where do I sign?
Stormtrooper day off
Photobucket
Originally Posted by Jeh View Post
I can understand an accident if something happens at the last second with no time to react but 23 minutes of 911 calls. They should have hung up, let them crash and hopefully end their ability to reproduce and futher harm the gene pool.
superboosted is offline   Reply With Quote
Old 01-09-2007, 03:39 PM   #12
Can play the blues
Default short shifter
PM Dale(245gti). Get yourself an adjustable timing gear, too.
1982 242 turbo. MVP coilover front and rear suspension. Bilstein HD. IPD 25/25 bars. 3" MVP exhaust. Cosworth Sierra hot side T3 .48 with upgraded stock .42 compressor. Ported 90+.True Track diff. Flat hood 1979 front grill Ecode park/turn lights with H4 Hella. 321k miles. Had it since 1995.
1993 245 Classic, 340k miles, enem V15. Genuine Volvo stock over the axle exhaust.
Old 01-09-2007, 04:00 PM   #13
shaved240
body work hell
shaved240's Avatar
Dam I need one too..m46 shifter sucks balls
http://media.tumblr.com/tumblr_lizoavPjKZ1qexvtu.gif
242 turbo:b230f+16v, Holset HX40, Getrag
Old 01-09-2007, 05:45 PM   #14
Morley
Barbie Ken
Morley's Avatar
Something tells me Calgary's junkyards won't have any M4X shifters left...
Morley is offline   Reply With Quote
Old 01-09-2007, 06:21 PM   #15
245gti
Adapting Stuff
245gti's Avatar
No kidding...
PM me guys...
Old 01-09-2007, 06:26 PM   #16
Homer
Don't be me
Homer's Avatar
No kidding...
PM me guys...
PM sent, but not requesting a STS
Old 01-09-2007, 07:29 PM   #17
volvorod85
volvorod85's Avatar
Guess how you fix that....get a T5, no comparison....you should drive my wagon.
Mark
1995 855 Turbo Stock <--Daily Driver
1979 242dl B230FT AW 71 <--Wifey's ride
1959 Austin Healey Sprite <--something completely different
1974 Fiat X1/9 <--Moms little toy
"Driving the old 2 valve 740 is a bit like driving an IKEA wall unit, so leisurely is its acceleration, so angular its lines."
My former brick saved my life 6/25/03....Volvo for Life
New pic comin eventually.......
volvorod85 is offline   Reply With Quote
Old 01-10-2007, 04:55 PM   #18
The Aspirator
It's a girl!
The Aspirator's Avatar
I hope you are reffering to your OLD shifter in these descriptions, cause if Dale's shifter is doing that then you installed it wrong. But yes, that sounds about right for a stock shifter, 6" of throw. Although that 3" of slop in gear sounds hideous, most of it is probably in worn out pivot bushings. How much slop do you have now with new bushings and the short throw shifter?
John
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 01-10-2007, 08:28 PM   #19
kammer
BLK
kammer's Avatar
John
Yes, that is with the old shifter. I haven't measured with the new one yet. I can say this though, when shifting now, I keep thinking I have only gotten to neutral and I am actually in another gear. So roughly half the distance or less. The bushings also made a huge difference. My old one weren't cracked or broken, however the new ones were a much tighter fit. I also understand what people mean by a shifter feeling "notchy". I am planning to change the trans fluid to synthetic soon to help smooth out the feel. Overall a great upgrade.
