Old 01-08-2007, 10:26 PM   #1
vincentl
Default ATF mix with water ?
Hi last few days I got some problem with my auto gearbox, where it does not shift gear smoothly.
I've check with ATF level, and it seems that it indicated I have extra ATF inside (more than high level) I remembered I pour it just nice up to High indicator on the dip stick.
Besides that it smells weird...
Just wondering if water could leak into Automatic gearbox, if yes where would the culprit be?
KIndly help !
My Humble ride.
96' 940 LPT
Open Pod Air Intake
3" Blitz muffler
MBC ~ boosted turbo to 14 psi (stock 4psi)
vincentl is offline   Reply With Quote
Old 01-08-2007, 10:53 PM   #2
WheyDey
i fought the lawn
WheyDey's Avatar
could be from your radiator. afaik, the radiator also houses the trans cooler.
http://img.photobucket.com/albums/v312/JasonTomlins/Funny%20Pictures/1200267225490.gif
WheyDey is offline   Reply With Quote
Old 01-08-2007, 10:57 PM   #3
henry_sigourney
henry_sigourney's Avatar
If there is coolant in the ATF replace the radiator immediately, then flush the transmission. The coolant will kill the tranny really fast.
henry_sigourney is offline   Reply With Quote
Old 01-08-2007, 11:36 PM   #4
vincentl
you mean there might be leak in side radiator (cooling cylinder - where ATF pass thru) ?
Old 01-08-2007, 11:36 PM   #5
impulse922
only place water would come from me thinks
-Matt
'90 780 and '03 s60 T5M
impulse922 is offline   Reply With Quote
Old 01-08-2007, 11:38 PM   #6
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
its happened to both me and kenny in our cars.. the trans cooler inside the rad goes bad and coolant leaks into the rad and visa versa..
Sam
90 245GL Build thread 2JZ coming soon...
91 245GL Dumpin Doughnuts Battle Wagon Chumpcar
93 245GL Street Beater
Old 01-08-2007, 11:45 PM   #7
vincentl
Instead of changing radiator
would it be a cheaper alternative to change ATF cooling to Cooling coil type (air cooling type) ?
Old 01-08-2007, 11:54 PM   #8
WheyDey
i fought the lawn
WheyDey's Avatar
no.
also along with a coolant flush and radiator change, flush the tranny as well.
Old 01-09-2007, 12:02 AM   #9
vincentl
no.
I'll do the coolant flush and tranny flush.
But I don't understand why changing to Air cooling type ATF is not feasible ?
Old 01-09-2007, 12:09 AM   #10
thelostartof
unbalanced chemical
thelostartof's Avatar
because all turbo cars should alraedy have a factory a2a cooler for the trans fluid but also still go through the rad .. so you could just bypass the one that does into the rad and ONLY run the external trans cooler and call it a day ... or upgrade to a larger one and be better off
Old 01-09-2007, 12:10 AM   #11
WheyDey
i fought the lawn
WheyDey's Avatar
ohhh... no i thought you meant adding an external cooler to the exsisting setup.
Old 01-09-2007, 12:32 AM   #12
vincentl
my 940 LPT does not comes with an external trans cooler.
Where the only options it has is direct to radiator cooling.
Old 01-09-2007, 05:11 AM   #13
PWRPUFF
narf!
Mike's thinking the -91. 92+ had the radiator setup only.
-- Kane ... Volvo got cheap ... the cars were lasting too long!
 crankcase ventilation mod! -- 500dollar744ti
 Eh - you've still got three good rods, just up the boost a little more to compensate for the missing rod. -- JohnMc
PWRPUFF is offline   Reply With Quote
Old 01-09-2007, 05:47 AM   #14
Chumley360
Well water could also get into the tranny through the vent tube or a bad seal if it was driven through high water. Also what color is the fluid? Plain water will turn it a thick pink, like Pepto Bismal. A water-coolant mix turns it pink with silvery tones. Also maybe it's just overfull and needs a service?
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 01-11-2007, 05:14 PM   #15
vincentl
radiator tank replaced and ATF fully flushed .....
Running back normal
