Closed Thread
Old 10-17-2003, 11:44 PM   #1
Yea, Right
Malcontent
Yea, Right's Avatar
I thought I would pass on some information I came across that verified a suspicion I have had for a few years. The AW30-40 transmission found in Volvo 960's from 92-98 are actually the same automatic transmission found on twin turbo supras. Check out this link. http://www.transmissioncenter.net/Ve...ssionIndex.htm
Take a look at the supra and the 960. That's right baby!
I then did a search on A341E and came up with this article on a full buildup of this transmission. http://www.levelten.com/pdf/turbo.pdf Score!
I am finally ready to actually swap the motor on my 960, but first the tranny goes to our trans shop for a buildup. BooYaa.
Kenny- "This is what I was trying to explain before everyone got butthurt and started calling me names".
Yea, Right is offline
Old 10-17-2003, 11:58 PM   #2
bitjockey
Wow. Thats pretty interesting... are the trannies identical? Blows my mind that Volvo would put such a strong tranny behind a n/a whiteblock...
Originally Posted by isaac
Shame costs more than a 13 second Volvo.
bitjockey is offline
Old 10-18-2003, 12:24 AM   #3
the poi
Has been
the poi's Avatar
well i'll be god damn. jeebus, if a turbo 6 swap gets any easier (gee, did volvo maybe make a few hundred whiteblock thousand turbo manifolds and leave them ina warehouse somewhere?) im gonna sell my borther to malayasian slave labor camps and get started. how's the gearing on those trans? i spsoe they work for turbo supras theyll work for us eh
edit:// didnt they ahve an electronically controlled valve body? WIll the trans computer work without imputs from the ECU?
the poi is offline
Old 10-18-2003, 01:13 AM   #4
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
well, aw70-71 etc are also toyota trannies (or rather used by toyota). dunno what all they went in, but i snagged a book for mine so maybe it'll have some decent info along with the cool pics that'll allow me to put mine back together haha
Megasquirt Tuning!
linuxman51 is offline
Old 10-18-2003, 01:16 AM   #5
linuxman51
linuxman51's Avatar
hmm upon closer examination, it would appear that you misread-- the a340e thats in the 960 is found in the non turbo supra, the a341e thats in the turbo supra is something different, or so it would seem from that site.. do elaborate.. whats the difference between them..?
upon even closer examination it appears that the transmission in question is found in the 2.6L (L6?) 960s, im guessing thats some sorta euro spec 960 similar to what the whiteblock m90's are found in?
this however has piqued my interest as i'm thinking about snagging a 960 to serve as DD for a year or two and then move along into project car status(cause we all know how baddass an I6 dohc is with a big hairdryer ;) )
Old 10-18-2003, 02:20 AM   #6
tjts1
tjts1's Avatar
The differences are all internal. I found this out when i decided to change the fluid and filter in my 960s transmission. Volvo says these two items do not have to be changed for the lifetime of the car. I didnt buy it. Nobody stocked a Volvo 960 filter but in my search i found out this transmission was used on the Supra and Supra turbo, LS400 and the Previa minivan. I bought a filter for the LS which was a direct fit. This transmision could easily handle the HP from a T6 with the proper upgrades. There is a company in LA that specializes in beefing up these transmission for Supras.
tjts1 is offline
Old 10-20-2003, 12:41 AM   #7
linuxman51
linuxman51's Avatar
so an a340 and an a341 are the same thing?
Old 10-20-2003, 05:24 AM   #8
Angus242
Just to add some fuel to the fire:
Pretty sure the AW71 was used in Toyota Crowns, Cressedas etc. Knowing Toyota if these models were available in the US they were probably under a different name and you have no idea what I'm talking about, but they were medium/big '80's sedans/wagons with straight sixes of about 2.8L. For example a Previa is a Tarago here in Oz, and it's called something else in other markets.
The 2.6 you mention is (I think) just like the standard 3.0 960 motor (they are 3.0 right?) but with a different displacement, for lower spec models. Of course in places like the US and Australia all the 960's were top of the range, so we only ever see the 3.0 with auto trans. I have also heard that it was a 2.5 though, I'm not sure of the exact displacement in cc's.
'75 242GL, B23E, H cam, M46, 3.91 rear end, electric fan, custom intake, custom exhaust.
'74 164E under restoration/modification.
http://users.tpg.com.au/ajcw84/Volvo242.htm
Angus242 is offline
Old 10-20-2003, 08:21 AM   #9
Guest
Sounds like they me be like the AW70 - AW71, near twins...
Old 10-20-2003, 09:44 AM   #10
245turbobrick247
I do know that toyota uses the aw71 in a pickup truck. SOme one on this board got one becuase it had a ?better valve body? and more clutch plates then our version. He was trying to have it built up but for one reason or another it didnt work out for him. Cant remember why?
245turbobrick247 is offline
Old 10-20-2003, 09:50 AM   #11
bitjockey
AW71 was used in 3rd gen 4runners.
I've got a local shop here that beefed mine up for under $200, if any of you guys are interested... its holding up just peachy.
Old 10-20-2003, 05:10 PM   #12
Angus242
Can you fit an ex Toyota AW71 into a Volvo though? The ones I've seen on PRV6's have had bellhousings that are a single perminantly attached piece, cast as one with the main trans body, so I'm pretty sure they can't be fitted to anything other than a V6.
Angus242 is offline
Old 10-20-2003, 05:48 PM   #13
CHESH740R
lacking enthusiam
CHESH740R's Avatar
Location: England, that little island that everyone fled except me.
Indeed in the UK we got the option of 2.5 engined 960's They were either equipped with the M90 transmission or the AW30-40. The 3.0 litres only came with AW30-40's.
In fact my dad owns a top specification 960 with the 2.5 engine and the auto transmission.
CHESH740R is offline
Old 10-20-2003, 08:30 PM   #14
boosted
boosted's Avatar
my friend just got a driveline from an 87 supra and the tranny looks identical to mine, i will look at it more, but thats just a thought
-1998 V70r AWD
boosted is offline
Old 10-21-2003, 01:06 AM   #15
760T man
Phillip Mamouf-Wifarts
760T man's Avatar
Location: Bettendorf, IA, when I'm not EASTBOUND 'N DOOOOOWN LOADED UP 'N TRUCKIN'
I saw A341E by both Volvo 960 3.0 and Supra 3.0 Turbo.
a '90 765ti, an '84 244ti, and an '18 780
Turbocharge it, and instead of the typhoon, or syclone, we will call it the “light breeze” -mrsam740 referring to the Oldsmobile 4.3 diesel
760T man is offline
Old 10-21-2003, 07:33 AM   #16
Anonymous
Guest
Here in the US/CAN market the PRV v-6 bellhousing Volvo part# 1239687, and 1340134 w/crank pickup can be removed from the transmissions and interchange between AW70/71/71L/72L.
The automatic bellhousing is bolted from the inside at the pump, so tranny has to be removed to remove bellhousing.
Old 10-21-2003, 07:57 AM   #17
Angus242
Interesting, they don't look like they come apart but they would have to be the same as the US cars so I guess they do. Thanks for the info.
Angus242 is offline
Old 10-21-2003, 01:14 PM   #18
gecko
i work at a toyota dealer and i can add that the 3rd gen 4runners do in fact have the removable bellhousing just like the AW71.
neal
_____________________________
1991 780T... 0-60 curvy roads COMING SOON: 19T, proturbo header, 16v head, stroker crank, redesigned 3" exhaust
1988 240.... 0-60 curvy roads
daily driver TOTALED anybody selling a sweet car?
gecko is offline
Old 10-21-2003, 05:07 PM   #19
Angus242
OK so the bellhousings are removable on the AW71, any chance that a BW35 bellhousing would bolt on? The AW71 is a decendant of the BW35, but it's probably too much to hope.
I may be getting a 164, and it could really benefit from an overdrive gear.
Angus242 is offline
Old 10-22-2003, 01:09 AM   #20
linuxman51
linuxman51's Avatar
the 1998 one. I'm not trying to split hairs, cause if this is the same sorta bs as the aw-70/71 then yippie I'm just saying down at the bottom, it says 960 3.0 L4, a340. thats all..
Old 10-22-2003, 03:53 AM   #21
isaac
F*ck the police
isaac's Avatar
Man, now you guys are convincing me to pull the AW71 out of my 244ti and put it in my 245 so that I can get rid of that pesky slipping clutch problem. Good idea? Hmm. If for $200 I could get an AW built to withstand 300hp, I think I'd be in the hizouse. This 7.5psi boost I'm running right now is pretty much killing me seeing as I could walk a frickin Z28 2 months ago and now I can barely spank a stock Integra LS.
"If you, the citizen, deliberately vote for someone who won't give you health care over someone who will, you need to have your head examined, except you can't afford to have your head examined." - Bill Maher
1998 Volvo V70T5
1989 Volvo 244DL
1990 BMW 52(3)5i
and Matt Dionne still rides with me
isaac is offline
Old 10-22-2003, 06:07 AM   #22
Anonymous
Guest
It may the same!
Old 10-27-2003, 01:51 PM   #23
mike nz
That was me... tried a toyota clutch pack (more clutch plates) in the machined 2nd gear drum. The whole drum collapsed on the way to the drags 2 days later.
Replaced with OE unit, valve body mod done at same time.
I`m a bit suspicious that the work of the trans builder wasn`t up to scratch but wasn`t able to prove it or afford to try again.
Trans currently feels great, car on the dyno 2 weeks ago made 188.5 rwhp, drags start again in 3 weeks, can`t wait !!
Cheers Mike
1989 Volvo 740 turbo intercooler .. 93 block .. TD05 16g turbo ..430cc injectors .. adjustable FPR .. 3" AMM.. NPR intercooler .. IPDUSA turbo cam and adj gear + 2 degrees .. K + N with cold air box .. 3 inch exhaust to axle 1 resonator ! .. water/meth injection .. HKS EVC .. Blaster 2 coil .. 8mm wires .. trans valve body mod .. Eaton G80 locker 4.1 rear .. line locks .. 235/45/17 front 255/40/17 rear Federal SS 595`s on Performance alloys .. 253 rwhp .. 13.62 @ 101.77
mike nz is offline
Old 10-28-2003, 01:37 AM   #24
supratheonlyway2fly
Wow -ive got an auto out of my 1990 supra parts car in my garage and im about to pull out the tranny to the 90 740-wonder if i could.......
Kris Weldy
Destination BOOST
Arlington Texas
1989 supra turbo hdtp(RARE)na ceramic and molyibdeum coated pistons in a turbo block,walbro 255 hi flo fp,blitz dsbc,haltech f7c programmable efi,4.30 lsd,mustang cobra electric fan,volvo intercooler and custom piping(huge),modded ct26 to4e 50 trim turbo,modified clutch per american power and brake,o ringed block,arp head studs,jamex springs,gab struts.
1990 740 volvo turbo
1996 dodge avenger es-wifes *bling *bling daily driver.
supratheonlyway2fly is offline
Old 10-28-2003, 09:20 PM   #25
Anonymous
Guest
the site list the ZF5HP in both the C70 and 960 - can that be correct ?
I didnt know Volvo used ZF autos that late
Closed Thread
