Old 01-23-2007, 11:25 PM   #1
LAW_760WT
Exclamation 760 turbo wagon with S60 R wheels 18"
Help what do i need? do i need spacers please help
tire size 235/40/18 z thanks
LAW_760WT is offline   Reply With Quote
Old 01-23-2007, 11:34 PM   #2
`pr0digy
You need spacers with the correct bolt pattern, try a SEARCH.
92 944T - 15g/15psi/Browntops/3" cat back/TLAO Chips
`pr0digy is offline   Reply With Quote
Old 01-23-2007, 11:44 PM   #3
gattigang
put you on ICE
gattigang's Avatar
235-40-18's sound almost the same size I'm tucking on my 745t. I plan on using 20mm on 35et wheels, tires are 245-35-18's. I tried 25mm on the front and they seem to look fine but I believe the 20mm adaptor will be on the money. As for the rear, 25mm on a 35et wheel will work but will need to roll the fenders a bit but I plan on doing 20mm adaptors on all fours.
g@ttigang
1988 Paul Newman 745GLE Volvo Grand National GNVOVO
PTE TA-49 turbo & ,adj. wastegate,adj. 3" Hi-flow cat, ultraflow muff.9" k&n filter, 60/65 lb.mototron injectors, heads pocket-ported 3 angle valve job, LT1 valve springs, 340 walbro fp. plenum spacer, 160 therm. 93 turbotweak chip, 3" LT1 Maf w/translato
ttp://i10.photobucket.com/albums/a138/gattigang/bouncing2os.gif
gattigang is offline   Reply With Quote
Old 01-24-2007, 03:27 AM   #4
LAW_760WT
So do you rec any in particular and thanks for the help guys
I work for a dealer ship and one of my customers gave me his with tires. how lucky am I.
I also have a set of 17" R's kind of beat up tho. but yah if you guys have a name or a place
I can buy from i would like that very much hanks for da help.
