creative mastermind
By: Adam Smith
Description: The objective of the modifcation is to compress the engine mounts before they are installed. To do this 4 screws will be inserted and fastened through the two metal plates which sandwich the rubber inner part of the engine mount. http://www.turbobricks.com/mods.php?content=art0015 Last edited by boostdemon; 06-27-2005 at 02:35 PM.. |
Exklusiv Zubehör Klub
![]() Join Date: Sep 2002
I still think slipping a peice of pipe- provided you can find some close to the diameter of the mount- would be a better compromise.
1)less work 2)Safer, as the mounts should still be able to shear in an accident, the pipe just keeps them from being compressed or deforming too much. Unfortunately this won't keep them from tearing right apart, but if they aren't allowed to deflect as much it may help... I haven't tried this, but I just remembered it now so I thought I'd leave a note. |
ARRRRHARHAR
![]() Join Date: Dec 2002
ratchet straps. 'nuff said. keeps the motor from torquing over nearly as much under load, thusly preserving damage to said motor mounts. In a wreck it might make for an interesting post wreck engine location, but I think in any kind of wreck were that sort of force would be generated, it wouldnt have any problems ripping the traps loose...
"They bum rushed them in their own crib, they drank all their beer, they partied with their ladies and they left with the trophy" Megasquirt Tuning! Plug and play LH 2.4 Megasquirt, now with stealth mode! ported volvo heads |
#4 |
Guest
Why don you use the motormounts from a 240 diesel they are an bolt on modefikation and are much stiffer
Morten |
#5 |
Guest
I used 164 mounts on my solid-mount 700. Direct bolt in. Much stiffer.
#6 |
Chubfest 2009 Survivor
![]() Join Date: Nov 2002
Solid transmission mount hhaaha havoc on the mounts but that motor doesn't rock so much
Will trade guitars/guitar parts for go fast goodies or stuff I need. Just PM. www.kauerguitars.com the second best way to upset neighbors and alienate people. History: Car 1 | Car 2 | Car 3 |
#7 |
My setup on a volvo 240 With an b230 et engine and a m46 gearbox.
Engine mounts from an 240 diesel gearbox mount. engine mount from a volvo 164. its a bolt on, no modefikations, and a lot less engine rock. Morten |
| Thread Tools | |
| Display Modes | |
