Snorting coca cola
I have been searching and have found, as power capacity the following ratings
Getrag 262: Unknown Getrag 265: Unknown V8-T5: 300 lb/ft torque m90: 260 lb/ft torque Now i have done some research, about 5 hours worth to try and see if any of these could stand a 400 hp setup and have come to the conclusion that if the getrag cant do it then a modified (race edition T5 would be necessary) I would like this thread to weigh the pros and cons of the various tranny swaps available to us volvo guys . Feel free to include the supra W55 in the discussion.
"Some drink from the fountain of knowledge, others just gargle"
Can't have my internet
![]() Join Date: Jan 2006
4cylnder torque does not equal v8 toruqe
A tranny breaks when you drop that cluch, where v8s are putting all their torque down. A 4 banger is putting half it down, till the turbo kicks in. Any v8 t-5 will handle the power just fine. No one on this board has broken one yet (i dont think) hell, one of the v8 guys has his turbo 302 with a stock t-5 putting out 500 v8 torques
1978 244dl - Runs - Now with b230f+t/MSIIe/IPDsprings/BillyHDs/25/25sways/adjustable torque rods and panhard bar/holset/T5. And hydras 1986 760 Turbo - Now with 299k and M46 87 245DL - M47 206k, stock and beat. 87 245DL - M47 130k, stock and less beat but still beat. |
Guest
#4 |
volvoholic
The T5 is the only transmission on this list that you can expect to rebuild in your garage.
1983 Volvo 245T with too many mods to list 1975 Volvo 242DL PARTING OUT pm me for parts! |
#5 | |
Snorting coca cola
You say youre not a big fan of the ratios in your 265? Too short, too long, which ratios would you be looking for in the T5? About getrags being broken and T5's not, i think the ratio of getrag swaps vs. T5 swaps on tbricks might justify the discrepancy |
#6 |
volvoholic
One of the 330lb/ft T5s should take 400hp as long as you aren't launching too hard.
#7 |
#8 |
Snorting coca cola
And should it fail, simply rebuild it I guess. The beauty of the getrag is i live net door to a place called euro parts in Aylmer. They are a JY carrying an infinite amount of volvo/bmw/merc parts for cheap (I know the owner)
#9 | |
Chubfest 2009 Survivor
![]() Join Date: Nov 2002
I never seemed to phase my WC T5 and I threw all kinds of silly juvenile behavior towards it.
off |
#10 | |
Snorting coca cola
Yeah putting that much instant torque to the ground would be a challenge but very doable with a good diff/tire/ chassis stiffness and suspension setup. |
#11 | |
Plus they are plentiful, seeing we are in the north american continent |
#12 |
Guest
#13 |
Snorting coca cola
Mike, i would just want to know what you 65mph cruising rpm is like with the getrag.
About the T5, it is looking more and more appealing, aside from the fact i hear v-performance are not the quickest at supplying the kits. Has anyone here attempted the hyd throut out bearing swap for the T5? Im going with a better clutch regardless of what swap i get and will prolly end up buying a more powerful pp. I hear disengaging with the cable can be a real challenge on aftermarket pp's with the T5 |
#14 |
Guest
Try 450-500NM (330-370lb/ft).
Everyone that I know who is using the M90 in a powerful car, have over 450NM (330lb/ft). The first M90 (M90L) from early '95 is strong but it will not stand up to much more than a M46 will though, but the '96-'98 gearboxes will handle a lot more. The M90L2 from '98 is the strongest of them, and I know one guy who has well over 500NM (370lb/ft) that is running one. All the M90 gearboxes have a fragile 3rd gear though, and you will have to weld the stop-ring if you want to be able to shift into 3rd fast. The M90L2 doesn´t have very big problems with that, but it can happen on those as well. |
#15 | |
Snorting coca cola
What about rotating mass and power efficiency, are any of these better/worse at chewing up torque? |
#16 | ||
I think you might find the Bowel Movement Wonders had like a 3.08 or even a 2.85 axle ratio. That might be the easiest thing, if they are available: just slap in a ring and pinion. But while discussing strength, that in all these trannies the first consideration is the distance between the two shafts; bigger is stronger.. The second and more critical thing is that strength in any given box is directly related to the ratio between what is here labeled "Main drive gear" and the cluster gear. This is some old Chev 3 speed but the illustration will do. ![]() REMEMBER! Gears are merely levers arrayed in a circle and when you have a "BIG" gear reduction like say 4:1, that is to say if you have slowed down speed by a ratio of 4 to 1, then you have multiplied the torque coming out the other end by 4 to 1. So in a given box the first place reduction is done is from so called "main drive gear" or input shaft, down to the cluster gear. That ratio is the only difference between the yummy 2.95 gearset and the more mundane 3.35 in the Ford V8 T-5s and the differnce is seen in the following chart; there is a direct relationship between the "drop gear ratio" and the torque capacity of the otherwise same box. See chart TORQUE RATING IMMEDIATELY AFTER ENGINE SIZE Quote:
The real ones that Ford, Volvo and BMW all used for roadracing with 2.3 first gears had way more torque capapcity that the street ones with their horrid 3.97 firsts. An exceelent resource for T5 parts and service in the East is Hanlon Motorsports in Pennsylvania.
John Vanlandingham/JVAB Imports Sleezattle WA, USA --> CALL (206) 431-9696<---- www.rallyrace.net/jvab www.rallyanarchy.com Vive le Prole-le-ralliat "When a man tells you that he got rich through hard work, ask him: 'Whose?'" — Don Marquis Last edited by John V, outside agitator; 02-19-2007 at 01:35 PM.. |
#17 |
Guest
I don´t know how well the M90 stands up to other gearboxes like the T5´s and stuff, but it is pretty efficient I guess.
#18 | |
Guest
I think I saw the torque capacity demonstrated in action a few weeks ago on "MusclecarTV"... where Louis Santiago showed a 4.88 ring and pinion side by side with a 3.31 ring and pinion and I didn't realize how much more massive the 3.31 gears were. I'm guessing it's the same size-strength relationship between the 3.97/3.35/2.95 gears, correct? I did some searching today and found a great T5 rebuild article on www.fordmuscle.com http://www.fordmuscle.com/archives/2...uild/index.php They used a "g-force" T5 street kit. http://www.gforcetransmissions.com/tran_gt-5.asp http://www.gforcetransmissions.com/pdfs/PricingT-5.pdf Looks like $1000 gets you something that'll handle 500ft-lbs... with the 2.95 first gear. I guess I was under the faulty impression that you could get any gear ratio you wanted to build a cluster... but it looks like they all have the same 2.95 1.94 1.34 1.00 0.63 pattern. Is this pattern recommended/suitable for something like a 200-400hp redblock with a 3000rpm torque peak? what about a 4000rpm torque peak? I imagine the same/similar parts are/may be available for the getrags but I have no clue as to where in the stratosphere they'd land. |
#19 |
Really? I LOVED my WC T5 (mustang) with 3.91 rear. Great rpm for cruising down the freeway and I never ever felt like any gear spacing was to big or to narrow. This was a solid 4-7k rpm powerband car as well.
#20 |
Guest
eh... it may be the 255 50 15 tires... just feels like it's not in the right gear... cruising at 70 is 3500rpm...
I may get used to it, but it just doesn't feel right at the moment... however... and this is where the turbobricker content comes to play... it hasn't had a working tach or speedometer since megasquirted it... so it may just be a mental thing. I fixed that this weekend... imagine... a working tach and speedometer... |
#21 |
faster than you think
![]() Join Date: Mar 2003
I may have a somewhat different perspective because of where I live. But I feel the BMW 265 first gear, 3.8ish ratio, is not a bad thing to have. I'm running a 3.73 manual trans Volvo rear axle. And it works out just fine. Turbo volvos, especially 16v ones are just so dang doggy off boost that I would be stalling the motor, and having trouble getting up steep driveways without slipping the hell out of the clutch without somewhat of a "granny" first gear. Furthermore, If I launch the car like Kenny Bernstein from a light, 1st gear carries me to about 35-40mph when I shift at about 6500rpm. That seems OK to me. I shift to second and drop down to about 3500 rpm, and even my laggy high altitude motor makes boost there. Turbo motors have nice fat torque bands if the turbo isn't absolutely HUGE. They can pull those long spaces between gears just fine in a street car, and I'd really hate to be without something like a tractor 1st gear in a 4 cylinder motor on the street. Just my opinion. I personally like the Getrag for its strength and nice shifting. The thing I don't like about mine is that it is a noisy SOB. I'll probably have one rebuilt and tightened up someday. But for now its just working fine. The T5 isn't a bad option though.
-Ken Car #1: 1988 740 Turbo Wagon "Irene". 2.5 liter stroker B23, 16v head, 62mm turbo, VEMS, dyno 500hp, 12.21@123mph. Trying to reach the 11s in 2010. Car #2 1988 740 Turbo Sedan with tricks. |
#22 |
Devoid of Luxury
The M90 is sort of an accident really. It uses many of the pieces of the M56H. The 3 shaft layout is mostly desired for FWD cars where you want the box to be short of packaging and turning radius reasons. Such a design isn't really popular in RWD land unless you already have the parts pile lying about. Such said, the M56H ratios are pretty decent on N/A 850s. Expensive though and the M90L has ****ty ratios and is kinda weak. If you feel like spending $1100 for a still somewhat weak gearbox with questionable ratios, no aftermarket for your 700 before you even buy a clutch, fine. It is bolt in, early 850 NAs have pretty nice ratios.
The getrag shifts beautifully if it has been rebuilt ever. That is the one thing I love about it, and the shift linkage/driveshaft works out very very well for a 700 series that I have it in. Otherwise, the ratios are garbage and the idle rattle is really irritating, even if there is nothing "wrong" with the gearbox. It works well in my DD 945T with 3.31 gears. The T5 is cheap and if you have a 240 in the USA, unless you want more power or some such I can't see why you wouldn't use it. Shift quality is subjective, but I hate the way most T5s shift. To me, buttery feels right in your DD and mechanical+grouchy+direct feels right for a mullet machine. T5s are commonly available with common parts. With the 2.95-.73 ratio spread and a 4.10 rear end with shortish tires I think it would be lovely in a 240. 1st works about the same with a 4.10 gearset as my getrag 3.8:1 1st and my 3.31 axle. |
#23 |
Wants u 2 use your brain.
The ratios may be ok, but the final drive gearing is waaaaaaaaaay too tall. Those things feel like bigger dogs than they are because the gearing's so tall.
#24 |
Devoid of Luxury
True, but in the land of RWD such things are fairly easy to change to a nice 3.73-4.56 final drive as found on 240s. Or 3.73-4.10 as very commonly found on 700s. I wasn't really considering the 850/transaxle casing into the equation as anything but a donor.
#25 | |
Snorting coca cola
Is there an article on the getrag swap, ive seen the one for the supra w55, the T5 but only semi threads on the getrag. About the 1st gear being long, i would have to agree with qwkswede that it can be handy on a dd, especially when riding a 4 puck ceramic race clutch, not easy to do |
| Thread Tools | |
| Display Modes | |
