Old 02-23-2007, 12:20 PM   #1
JE Jr
JE Jr's Avatar
Default Bilstein strut won't fit! (240)
Hi!
A friend has a 240 and he tries to install Bilstein HD's in the front struts. The problem is that the diameter of them are too big!
I remember that I've heard of some of you having the same problem. How did you solve it?
I didn't find anything through search, or maybe I just wrote the wrong sentence...
Black car: --142 ´68--
Yellow car: --142 GL ´72-- 70's rally-car wannabe
White car: --744 GLE ´88-- Polishing object
Blue car: --S70 GLT ´00-- Daily driver
JE Jr is offline   Reply With Quote
Old 02-23-2007, 12:22 PM   #2
thelostartof
unbalanced chemical
thelostartof's Avatar
does his car have ABS?
Chip Feedback Thread / PM Current Chip Prices / PM for DownPipe & Exhaust Price / Silicone Cooling Hose Sets 2/7/9
Old 02-23-2007, 12:26 PM   #3
Can play the blues
Default bilstein
The only problem I know of is they are too long to fit without the spacer at the bottom removed. The stock struts need the spacer removed at the bottom. With the ABS cars the spacer seems to be welded or by some other method is stuck in there. I wasn't able to remove the spacer on the ABS struts I have.
1982 242 turbo. MVP coilover front and rear suspension. Bilstein HD. IPD 25/25 bars. 3" MVP exhaust. Cosworth Sierra hot side T3 .48 with upgraded stock .42 compressor. Ported 90+.True Track diff. Flat hood 1979 front grill Ecode park/turn lights with H4 Hella. 321k miles. Had it since 1995.
1993 245 Classic, 340k miles, enem V15. Genuine Volvo stock over the axle exhaust.
Old 02-23-2007, 12:30 PM   #4
JE Jr
JE Jr's Avatar
Hm, don't think it has ABS.
Update, Not sure it was Bilstein, but he says they are 46mm outer diameter (1.81")
The strut has inner dia 45mm (1.77")
Old 02-23-2007, 12:59 PM   #5
thats no bilstein,,,, its a monsta
Old 02-23-2007, 01:09 PM   #6
benflynn
bigpimpin740t@yahoo.com
benflynn's Avatar
is it the tube or the nut on the top, the ring nut for bills has a much bigger hole, i had to order a pair for my bills
think you got shorted? belive me, we have piles of turbos and ms units, email me w/what ever the hell you think we have of yours and when i am not on a river ill dig it out and send it to ya for shipping, one shotbigpimpin740t@yahoo.com
one down, whose next?
benflynn is offline   Reply With Quote
Old 02-23-2007, 01:10 PM   #7
242Fast
i don't remember if i got my struts off an abs car or not, but i had to sand a bit of the paint off the strut to fit mine in. I think i also used a hone to get some of the crud off the strut walls...
83' 242: turbonetics t3/t4 50trim 48ar, 3", 550cc, msns-e, msd 6a, ipdturbocam, npr
242Fast is offline   Reply With Quote
Old 02-23-2007, 02:13 PM   #8
towerymt
the real Towery
towerymt's Avatar
They're a tight fit. The stickers almost always catch on the tube inside and get ripped off. It's that close of a fit. Clean out the strut tube really well and use a hone if necessary (a brake hone would work well). Sand the paint off the strut. It should slide in with light pressure. If they're so tight that he has to hammer it in, I wouldn't do it.
I have a '90 240 without ABS, and it had strut tubes with a built in spacer at the bottom. I tried to install orange DeCarbon struts from a GT (same as Bilstein/R-sport in size) and they were too long. I had to change the strut tubes to ones w/o the spacer.
1987 244 | Project Thread | The 87 | Now with 74 mods and counting
1992 244 | The 92
244s are drop dead ugly and suck.
Originally Posted by amargill19? View Post
I've always wanted to work in a potato salad factory!
Old 02-23-2007, 02:34 PM   #9
sabelström
Hello! i am the one with the problem, i am from sweden so my english may not be so good.
My car is a 244DL 86. The orginal struts where 43,5mm.
It is bilstein for 240 in swe the part number is P36-0081 and it is yellow with blue dust protection.
And a have spoken to the company i boght it from and the say it suppost to be 46mm, and its no no stickers in the way, maybe only the colur, but i dont know if i dare to take the yellow colur of if i need too send it back to the company.
sabelström is offline   Reply With Quote
Old 02-23-2007, 03:21 PM   #10
Yea, Right
Malcontent
Yea, Right's Avatar
The part number is correct. Does the strut insert part way and then bind? The only time I have had that problem was with a slightly bent strut housing...
Kenny- "This is what I was trying to explain before everyone got butthurt and started calling me names".
Yea, Right is offline   Reply With Quote
Old 02-23-2007, 03:52 PM   #11
JohnMc
JohnMc's Avatar
I put Bilstein HD's in my '93 240 with abs. It was a *very* sniug fit. I actually had to peel off all the stickers on the strut to get them to go in. And then thump them into place with a hammer and chunk of wood.
And then I ran into the situation where that spacer thing was welded in place in the bottom end of the strut tube, couldn't get it out, but the strut retaining nuts threaded in about half way, so in my estimation that was enough threads to hold so I loctited it. And it's been fine for 6 months, 7500 miles so far. Every once in a while I'll pull up the dust shield and check, but they haven't budged.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-23-2007, 04:08 PM   #12
Crazychopstick
(/// _ - )
Crazychopstick's Avatar
Location: Receiving Transmission from David Bowie nipple antenna
Hmmm.
I have HDs in my '82 and did the same thing, there was a nut thing at the bottom of the strut tube (which I thought was actually part of the balljoint). The gland nut on my struts were threaded in enough that I didn't worry about it.
Crazychopstick is offline   Reply With Quote
Old 02-23-2007, 07:44 PM   #13
towerymt
the real Towery
towerymt's Avatar
If it doesn't fit, get strut tubes from another 240. But '86 should be OK. Mine is an '87 and they fit.
Old 02-23-2007, 08:13 PM   #14
244ti
244ti's Avatar
Default my HD's
i installed billstiens HD's in my 85 240 turbo.
the struts wouldnt go in, peeled the labels off and still no go, tried a little grease and no go. called billstien and talked to tech who confirmed part#.
then tech told me to sand off paint which was very thick coat.
after sanding the strut fit tightly.
that was two years ago.
maybe give them a call.
thats my experience.
good luck
244ti is offline   Reply With Quote
Old 02-24-2007, 03:20 AM   #15
sabelström
Ok, so i can get it to fit if i take away the paint? or get some other struts? is that the sum of all of it?
