Go Back   Turbobricks Forums > Symposium > article composition
Old 07-07-2012, 05:19 PM   #476
wooble
Whoo, finally got round to installing the M90 in my 245 this weekend. It's only been sitting in the shed for 2 years. The box itself fits fine in the tunnel, no hammering required. I used the standard dog-dish flywheel and diesel clutch setup. LuK 623224000 has all the parts in one box, and they're actually Sachs branded parts in an LuK box.
The clutch pivot was spaced out 4mm with washers. The clutch bite is about 30% of the pedal's travel off the floor, which is just where I like it. It's a very light and smooth action, definitely an improvement over the M47, but that could just be due to everything being taken apart, cleaned and greased for the first time in 20 years and 150k miles. I'm using the standard 240 clutch hydraulics, all the way from the pedal to the slave cylinder. The 240 slave works perfectly with the M90.
The shift linkage and the arm that holds the shifter were shortened 100mm and welded, and a short shift kit from Craving Boost was installed. The top arm that holds the shifter also had to have the rear locating pin cut down to fit in the tunnel, and the bracket it locates in was cut down and re-drilled to be bolted to the existing captive nuts in the 240 tunnel. Shift feel is good, but there's a bit more side-to-side slop in the shifter than I'd like, it's actually got the same amount of slop as the 150k M47 I pulled out. I'm not sure what I can do about that as it appears to be in the actual box rather than the linkage, but we'll see.
The rear mount was custom-made for me by Peter of www.retroturbo.com (goes by 'silveruser' on here) in the same style as the Captain Bondo rear mount seen previously in this thread, it uses a standard M47 rubber mount and crossmember. He also made me a custom driveshaft spacer which lets the M47 driveshaft bolt up to the M90, and modified the M90 shifter to accept a standard M10 threaded gearknob as I didn't like the M90 knob.
The only other modification required was the bracket for the front exhaust hanger which is held on by the bellhousing bolts. It doesn't fit the M90 as is, 10 minutes love with hacksaw and file had it fitting fine.
Now I am going to crack a beer and wonder when I am going to stop hurting from wrestling the damn box up into the car while laying flat on my back on a brick driveway.
wooble is offline   Reply With Quote
Old 07-10-2012, 12:31 AM   #477
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Originally Posted by luyopadre View Post
thx, could you give me any more details, how to weld it, and if possible pictures, I'm not so familiar with swedish .
Have a look at the picture that says "svetsanvisning" under it. You tack weld the ring to the top of each gear tooth, exactly at the point the white pen is pointing at in that picture. That's all there is to it.
-Kenny
Old 11-07-2012, 10:00 AM   #478
Ben960
Question
Hi, I am currently trying to save my 960 as the dual mass flywheel has failed & Volvo are not making replacements anymore. I have been trying to find detailed instructions for fitting an 850 T5 flywheel & clutch to my 1996 960 with a whiteblock 6 cylinder engine & found this forum thread, has anyone here done this conversion?
Will I need to put washers behind the pivot ball & extend clutch slave rod?
Do I need to use the release bearing from the 850 T5 clutch or the one from the 960?
Is there anything else I should know before I give it a try?
Any help on this will be most appreciated.
Ben960 is offline   Reply With Quote
Old 11-07-2012, 04:44 PM   #479
Captain Bondo
Use the 850 release bearing. You may need to rig up a spacer for the slave pushrod/fork but that's a minor detail overall.
Other than that it'll work fine. The only other thing to confirm is that the single mass flywheel does note require shorter bolts than the dual mass (for attachment to the crankshaft).
Also you may need to swap the wires on the crank sensor if you get a flywheel with "dimples" instead of "teeth".
Old 11-07-2012, 05:28 PM   #480
Ben960
Thanks for the advice, I have a flywheel already I may have imagined it but I think it has two rows of teeth around the outside, would the inner row be the trigger for the crankshaft if not where exactly should I look?
Old 11-17-2012, 07:33 AM   #481
RoadZombie
Hello from germany
can anyone say me wich type of m90 i have when 10236508 is stamped on it?
I have found that it will be a m90h, is that correct?
And who can say me which clutch setup i can choose for 350-400hp?
Thanks alot!!
RoadZombie is offline   Reply With Quote
Old 11-30-2012, 04:00 PM   #482
MCRAZER
Hello,
I got a whiteblock b6304fs (from a 960 '94 with auto tranny) that I want to put in my 244. Now I want to use the M90 on the block but it uses the motronic 1.8. So I'm not sure of the 850/S70/V70 flat flywheel will work. Any solutions on that plz.
Grtz Mathew
MCRAZER is offline   Reply With Quote
Old 01-04-2013, 05:46 AM   #483
RoadZombie
No one has an idea which clutch setup?
Things has changend i need a clutch setup for 500hp now(16VT build soon).
Greetings
Old 01-04-2013, 05:05 PM   #484
Captain Bondo
I used a sachs 707 and a southbend heavy duty organic disc. It held 540whp and 470wtq. It had a progressive engagement which was quite good but it did chatter.
I would buy and 850r clutch kit just for the disc and install it in a 707 pressure plate. I think for 500hp and 450ftlb it'd do the job and drive almost like stock.
Not sure how many responses you'll get, I'm not aware of any other folks who post here with any regularity other than myself who have done 500+hp m90 setups.
Old 01-08-2013, 08:41 PM   #485
RoadZombie
That helps alot! Thank's alot!
Is there any machine work to do on the flywheel to fit the 850R+707 clutch combo?
Greetings from germany
Old 01-08-2013, 09:21 PM   #486
DennisvdB
DennisvdB's Avatar
I have a TTV lightened flywheel specially made for use of a 850R clutch.
http://www.ttvracing.com/Volvoflywheel.html
Partnumber 1090
Volvo '76 244 wizz B19A
Comin' right up: B230FT '96 squirterblock - Nathan's 8V shorty header - Holset HY35W - TTV flywheel with 850R clutch - 480cc injectors - 3" JT exhaust - Iveco IC - M90 - Buchka Wasted Spark - BlaBla Chips - RSI Stage 1 Turbo Cam - 3" MAF - full Super Pro urethane - Koni Yellow
DennisvdB is offline   Reply With Quote
Old 01-16-2013, 01:52 PM   #487
RoadZombie
okay good infos! Thanks!
can anyone show me which modifications i can do on the 3rd gear?
i have read that some people weld it on the shaft for more strength or anything like that.
Has anyone pictures of that?
Greetings
Old 01-16-2013, 03:11 PM   #488
mark244turbo
Take a look at this: http://www.pukema.com/bilsport/container13-3.html
And this: http://forums.turbobricks.com/showpost.php?p=1048135
And this: http://forums.turbobricks.com/showpo...3&postcount=10
mark244turbo is offline   Reply With Quote
Old 02-01-2013, 04:27 PM   #489
RoadZombie
My clutch blowed up yesterday:(
My M90 will go in my 740 in a few weeks and i only must know if the 707 pressure plate bolts right up on my flywheel.
@Captain Bondo
can you say me if that pressure plate is plug and play?
What i have read is that it is from an audi so it is not p&p?
What must i modify?
Thanks and Greetings!
Old 02-05-2013, 06:15 PM   #490
enrgy
I have a quick question that i can't find answer through search. I think I know the answer but just want to double check. Is M90 diesel gearbox interchangeable with older diesel gearboxes? The main thing I want to know if diesel bell housing to engine bolt pattern is the same in 240/740/940/960 regardless of the gearbox?
Thanks.
enrgy is online now   Reply With Quote
Old 05-05-2013, 07:57 AM   #491
Fivehundred
Fivehundred's Avatar
Thanks.
There are 3 versions of the M90, diesel, whiteblock and redblock. A Diesel M90 will bolt onto a D24 that previously had an older gearbox.
Fivehundred is offline   Reply With Quote
Old 06-15-2013, 08:51 AM   #492
enrgy
Should I stay away from M90 if car will be mostly used for drifting, meaning it would get much more abuse than usual? Planned power is about 300-350hp(not whp). I'm from Europe so finding M90 is possible, but I am not sure if it will hold up the abuse.
