has anyone ever swapped a newer style b21, or b23/b230 into a 140 series car? i have a very solid 74 144, but the old b20 is totally done,and the old bw35 just wont cut it anymore. any information or publications on this swap?
thanks. |
What are you planning for a gearbox? Are you going with a stick or keeping it an auto?
Turbo, what?
Of course they have.
Do a search. Here, and most importantly, on the Brickboard.
Kyle - NLMGG: '91 244 NA DD/Track - General Leif: '71 142 b230 Chumpcar - Oregon Volvo Tuners? - For Sale? |
#4 |
Yeah there are many. I recall (GtJordan can correct me) that someone once even sold some mounts pre-made. Only problem I can see is wanting an overdrive tranny in a non-remote shift car but you shouldn't have that problem considering the year of yours. Give 'er
Sometimes I consider letting my car burn.... The tires off the rims. |
#5 |
creative mastermind
Theres some, i know there was a project build someone did once (most likely before we had a forum just for that). I dont recall exactly but i believe everything was straight forward however the firewall needed to be cut to fit the head mounted distributor? simple fix would be to use a block mounted one
#6 |
i would perfer to use a manual.either a m46, or perhaps even a borg warner t-5 from a 5.0 litre mustang. i see there is a company on the east coast that makes a adapter plate to do this.
#7 |
#8 |
Turbo, what?
In the search section...
#9 |
#10 |
I can get you motor mounts/brackets to mount a b21/23/230 into a 142 so it will bolt up to the stock tranny.
Jonathan
in quasi-retirement... |
#11 |
Turbo, what?
#12 |
#13 |
If you mount the b21/23/230 upright you can use the b20 bellhousing and use an m40/41, or get an adapter plate and use a T5.
(\_/) (O.o) (> <)This is Bunny. Copy Bunny into your signature to help him on his way to world domination |
#14 |
thats what i wanna do with my 71 144
#15 |
I'm told, by someone who did it, that if you put an OHC redblock in place of an OHV one, you not only change the mounts but you change the oil-pan & oil-pump (the OHV ones are a bolt-in fit to the OHC engine). Then you just use the original OHV gearbox - assuming it's strong enough, if you're turbocharging you may need to go more customised than that.
When I'm cruisin' in overdrive ... Don't have to listen to no run-of-the-mill talk jive. Shatner: The Colonel is breakdancing ... gimme a break!! Rollins: Credit terms raised! Shatner: I can't get behind any of that! Shatner: I can't get behind so-called singers that can't carry a tune, get paid for talking, how easy is that? Well, maybe I could get behind that ... Rollins: Well, I can't!! |
| Thread Tools | |
| Display Modes | |
