Old 04-11-2007, 09:29 PM   #1
yama
Default Modified clutch fork for Getrag
I modified an older forged Volvo hydraulic clutch fork to work with a Getrag conversion. The fork on the left is a standard stamped steel Volvo hydraulic fork from a 740 turbo. The center fork is an older unmodified forged hydraulic one from maybe a 544 or 122. The fork on the right is modfied to work with the Getrag. I added several beads of weld to the ends to lengthen it by around 3/8" and a few on the sides. The welds on the sides were added to compensate for the fact that the opening on the stock Volvo fork needs to be widened to fit the BMW throw out bearing. After adding the welds I spent several minutes grinding and polishing.
yama is offline   Reply With Quote
Old 04-12-2007, 06:11 AM   #2
v-speed
hey that exactly what i need to do,Do you think it will be strong enough to pust a race clutch setup?
I use a 122 bellhousing to put the getrag(M51) behind my B20
v-speed is offline   Reply With Quote
Old 04-12-2007, 07:32 AM   #3
yama
I would say that the forged clutch fork is alot stronger then the stamped one. It has a better pivot ball setup and alot more metal were the slave cylinder rod fits into the fork.
Old 05-31-2007, 11:53 AM   #4
Ruben
Ruben's Avatar
would you maken some for the tbrickers?
A dirty mind is a joy forever
Drove:
'87 Escort 1.3:'90 mini Jumbo:'87 360GLT:'87 744T:'92 240 Polar:'84 744T:'95 854T5:'90 744GLE 16v:'87 340 1.7:'79 343DL :'84 340L:'91 240DL lpg:'89 360 GL:'94 944TDIC M90:'85 360 GL:'90 745 GL:'89 744 GL:'86 745 TIC:'94 Nissan Sunny 2.0D:'92 Peugeot 205D:'88 360:'85 340GL:'86 360GL:'84 242TIC: '85 244 TI:'89 Dai racer:'95 460: '85 360GLS:'83 340 DL: '97 944IC: '91 AX Cup:'93 Diehatsu:'98 Polo D:'87 360GL
Drive:
Citroen C15D
Ruben is offline   Reply With Quote
Old 05-31-2007, 05:53 PM   #5
turbobrick211
turbobrick211's Avatar
One thing that you might consider, is having that fork heat treated. Welding forged steel will damage the grain structure, and considerably weaken the piece near the welds. You should be able to get some of that strength back by having it annealed and re-heat treated. Looks very nice! Nice polishing/finish work. You can't even tell that it was welded on!
E
RSI Fab guru
'89 245, full suspension mods, E-codes, 12:1 CR, Rally cam, RSI cam gear & 14.5lb flywheel, RSI header, 2.5" pipes.
'83 242 sniper II - 372hp-334lb/ft
Shaved b23f block, bmw squirters, stroker crank, RSI rods, pistons & stage 2 head, 10.8:1 Static CR, RSI header, hybrid GT35R, 3" SS exhaust, Getrag, MS3X Full Sequential, coilovers, etc.
'66 122 wagon
'97 VW TDI motor and instruments, Supra trans, 240 rear axle, Subaru seats, custom this and that...
turbobrick211 is offline   Reply With Quote
Old 05-31-2007, 06:24 PM   #6
yama
First problem would be to locate one of the older Volvo forged clutch fork. Their not all that easy to find.
Old 06-01-2007, 12:59 AM   #7
daijoubanai
waste of skin and blood
daijoubanai's Avatar
I'd buy one.
daijoubanai is offline   Reply With Quote
Old 06-01-2007, 03:16 AM   #8
Ruben
Ruben's Avatar
dependig on what my tranny will be (getrag or m90) +1
Old 06-01-2007, 03:24 AM   #9
v-speed
ive got several clutch forks,i would want one modified
Old 06-01-2007, 09:19 AM   #10
PRVersion
regretting name change
PRVersion's Avatar
+1
PRVersion wins.
accelerate til the last possible moment, then accelerate more...
PRVersion is offline   Reply With Quote
