Jack
junkman
- Jul 7, 2011
- The Ass Cheek Of History
finally you noticedMuffler looks great
with how well things went with my 220 yesterday I got motivated enough to try and fix this car....
I been having weird detonation issues between 40-100%throttle. The car would just fall on its face and engine ran like shit. In all other conditions it ran fine, like really well. Idle, power etc all were fine
I initially thought it might be my Mallory distributor so I got a 123 one. Installed 123, adjusted valves, tuned carbs, I even washed it.... Nothing helped. During valve adjustment Jimmy saw #3 exhaust valve lifter not going up and down much. Well I have a K cam so I got nothing to lose by swapping that in...
Jimmy and I pulled the head... what we found was SHOCKING
#3 cylinder head gasket was slightly out of shape, looks to have been like that for a while
Lobe for #3 cylinder cam was almost flat (this is where a lobe should be)
but the craziest of all was #4 exhaust valve was smoked!!
One head bolts broke in the block. Block looks to be a recent rebuild, engine inside is super clean and pistons are all +.40
I tried to weld out the broken piece but no bueno... the block has to come out and it will go to a machine shop
but this is a good time to swap in a B20 with an efi head that came with my 220
(that's my 1890s copper clad bathtub. Someone did a poor restoration on, I got it for a steal and are in the process of stripping paint, and fixing the copper. This one came out of a Pullman rail car back in the day. https://www.worthpoint.com/worthopedia/antique-copper-lined-bathtub-bath-tub-404920113)
B18 on the ground, B20 turned over to put in a K cam and clean things up. Best of all this too looks like a really recent rebuild. New mains, new fiber timing, really clean inside. But Im going to swap in the steel penta gears out of the B18
