adamdrives
- Aug 9, 2010
- San Jose
Hey y'all, I recently picked up a 78 k-jet 242 that had been sitting for 15 years. I've gone through the car and addressed most of the issues. The car now runs and drives just fine, but the temperature gauge always reads hot (as high in the white as it can) after a few minutes of driving, sometimes dropping down a little. I found the radiator was clogged (cool to the touch except at the top and bottom) so I replaced it, but the gauge acts the same. I have already replaced the water pump and thermostat and flushed the cooling system when I got the car. I tested the compensator by grounding the sender wire, gauge goes full hot. I replaced the old looking sender because I had a new one laying around, no change. When I drain the coolant it doesn't come out quite as fast as I'm used to, but it came out clean with no rust after a BG cooling system additive and flush. Prior to radiator replacement the t-stat outlet read as high as 200 or so via infrared thermometer.
I'm wondering if:
Any advice on what to look at next? My plan was to find a used temp gauge as I had heard those can be wonky. The fact that little to no rust came out during the flush using BG coolant flush makes me think the insides are ok, but the slow drain makes me think maybe there is some restriction in there that is just solidified.
I'm wondering if:
- the water jacket is clogged (like the radiator) from the car sitting for so long
- there is a problem with the temperature gauge itself
- its normal for these cars to have a gauge that doesn't read at 9 oclock all the time like the newer cars
- when I smogged the car the guy said it was running lean, maybe lean enough to make it run hot?
