miguels244
I can automate that.
- Nov 11, 2003
- Denver CO
I've got a project in mind, looking for some input and (paid) help if it moves forward.
so for the top bit minus the transmission control, you're looking at an ms3pro of some flavor to do all of those things, and some creative table setup to accomplish it, but that's all natively implemented already.
on the transmission control, that'd likely be a separate controller, and the answer there will depend. I'm not all that familiar with that particular transmission, so I don't know exactly what is involved with getting it to work.
Hmmm...that one has the most io.
basic laptops are fine, the surface running 10 should be fine as well.
as far as tuning and datalogging, megalogviewer and tunerstudio (it comes with a TS license IIRC but not the log viewer software). The log viewer will work unlicensed, but it limits the length of datalogs you can open. If you buy both from efianalytics I think it's around $100.
the micro trans controller project *may* work with that transmission, but I don't know for sure
not that I'm aware of, but that doesn't mean you couldn't I reckon. There has been talk about integrating trans control into the pro box, but I'm not sure if that's gone anywhere
The original MegaSquirt I firmware was written in assembly, but all the newer MSextra firmware is C code. In the past, the source code was released, but they may not be releasing it anymore due to unauthorized use on pirated hardware. See some of the stickied topics at: https://www.msextra.com/forums/viewforum.php?f=125
What do you want to customize? MS supports using some simple equations for programmable output ports (see the tunerstudio docs).
