Turbobricks Forums
-   performance & modifications (https://forums.turbobricks.com/forumdisplay.php?f=13)
-   -   Ballast Resistor? (https://forums.turbobricks.com/showthread.php?t=359866)
itlksez 04-09-2021 01:05 PM
Ballast Resistor?
1987 740, B230f, LH-Jetronic 2.2
Quick question: I swapped this engine into an old Jeep. I had an issue with power to the coil during the swap, so I ran 12v directly to the coil (through a diode so I could shut it off) from the ignition switch. If Iím bypassing wherever the coil power came from before, do I need an external ballast resistor in this power source? Two different coils for the same application on rockauto; one says it needs external resistor, one says not required.
I just donít want to fry anything by not running one if the prior setup had one built in.
Thanks!
dl242gt 04-09-2021 02:20 PM
That setup should be using the 124 ignition amp with a 117EZK box. No, that setup doesn't use a ballast resistor if you are using the stock coil.
itlksez 04-09-2021 02:50 PM
Awesome. Thank you so much.
