Turbobricks Forums
-   the vault (https://forums.turbobricks.com/forumdisplay.php?f=17)
-   -   Limited Slip/Locker Options for the 200/700 Series (https://forums.turbobricks.com/showthread.php?t=135)
boostdemon 11-28-2003 10:39 AM
By: Stu Spencer
Description: So you want to spin both tires, huh? Tired of that open differential letting one tire spin itself into a slick? If your car was not lucky enough to come from the factory with an "anti-spin" differential, you have 2 basic differential options to allow you to better distribute power to both tires (short of welding the spider gears); limited slip or locking
http://www.turbobricks.com/mods.php?content=art0014
dl242gt 01-29-2004 08:20 PM
My feedback of the Tru Trac Trac Tec differential is on Stu Spencers page.
One of the best mods you can make to your brick for traction.
http://www.geocities.com/MotorCity/Garage/6776/LSD.html
Anonymous 02-25-2004 06:10 PM
I have a 1976 242DL I want to install a spool in the rear end, so both tires always spin. :freak: I plan on using this car off road only.
Hank Scorpio 02-25-2004 08:15 PM
IIRC I did a pretty good write up on installing a Powertrax and my views on it too :-P
Fred Gwynne 10-03-2019 05:38 PM
Do you have a newer link to that page? The current one isn't working for me. Thanks very much.
R-Pow3R3d 10-03-2019 10:26 PM
https://media1.giphy.com/media/5JXGVWEvcMUUM/giphy.gif
dl242gt 10-04-2019 01:32 PM
Sorry I haven't looked for a newer link to Stus page. I do still have the tru track in my 82 turbo. It's got 90k miles on it now. Still works but it's worn. If you get one it's best to get the newer version with preload which is setup better for rwd. I would get another one.
Fred Gwynne 10-07-2019 08:17 AM
Thanks very much. I appreciate your comments.
84B23F 02-22-2020 01:35 PM
Just surfing around, and noticed this seller has a number of locking Dana 30 units for 27/30 splined shafts.
History Tidit - AMC-15 rear-end was installed on Ramblers in 1962, and in 1985 Dana Holding Corporation bought American Motors (AMC) axle tooling equipment and renamed it to Dana 35. "Dana upgraded the axle, and made IFS and Twin Traction Beam front axle variations, as well."
