OK, I'll bite...
I found a fan (forget from what... Ford?) 17" and fits near perfect in the existing shroud provided for the stock fan (760 b230 etc.). But it only just interferes with waterpump studs. Anyone have a source for short waterpump studs or P/N? Anyone have a single pulley setup? I'm about >1/4" away from having it fit. With Dremel I've taken about as much material away from the Ford? housing as I am comfortable with... ...OK and so I followed the link in the last post and what do you know? I think thats the same fan! I'm in the same boat.. except that instead of the 5+ inches of clearance I have an intercooler and am right up against the water pump studs with the same setup. Hmmmm. |
I'll let you know how it turns out. |
Might be a week or so... before I get to it to put it in, more pressing projects at hand. I'll try with bolts instead of studs and check for clearance. Hope it works because the fan fits the stock shroud so nice, and its dual speed.
sweet write up..im thinking about doign this within the next fw weeks..maby months..
^^ im planning on it soon prolly in a couple weeks ;)
Im doing my fan this friday.. hopefully
I did a E-fan on my 244 6 or so months ago and have put on 6000 miles on it with no problem. I just redid the the wiring today just cause I was board and wanted it to look pretty :-P. For the water pump studs, I just flip them around and it works just fine. I can takes pictures if anyone would like.
Later, Adam |
what would the cons be if you just had the fan going at all times? i have the fan in the article and i have a crazy old man who knows cars. so all i can see is that sitting in traffic you would get annoyed with the sound?
Basically I wouldn't worry about it until you start getting amps. I noticed my headlights would VERY SLIGHTLY dim when the bass really hit, at idle. I got a 1 farad capacitor and it's no longer an issue. You'll be okay, as long as your battery is in decent shape. |
just curious, what models of cars are you all ganking the fans from?
I got mine from a inline 6 960. I think the same fan is in the s40 but not sure.
got mine from a 940...wiring harness and all but here ya go
http://www.turbobricks.com/mods.php?content=art0008 |
i used a chrysler lebaron fan... looks great on the car, almost like factory and fits even with 3 inch thick intercooler...
http://xs215.xs.to/xs215/07224/IM003667.jpg |
just grabbed one from a dodge spirit/plymouth acclaim, very similar fan, but trim an inch off the large side of the shroud, and actually pressure fits in no problemo. should be good when i get it wired up!
well, the mounting tabs are different, yours from the lebaron interchanges with the minivans (voyager/caravan) where as the sundance, acclaim and spirit have a slightly different one (that works just as well.
nice, I grabbed a fan from a 92 acclaim or something. Only the V6's had to seem a useable fan, all the 4-cyl and turbos had fans with super skinny/long fan motors. I'm all excited to get it installed, I alreayd have the relay and wires all wired up.
Too bad I just got pulled over for being too low. He said my exhaust was lower than the lowest rim. I went out and measured and the exhaust is like an inch taller...so lame. Now I have to get an inspection....great. I'm going to have to find on non-cut springs :( But back on topic, the fan looks like it will fit nicely. |
I'm thinking of instaLLING a 3000 CFM fan from summitracing.com, what can it hurt? any input? going to remove my mechanical fan and upgrade to this fan with a manual override switch in the cockit. only! I will control when it will come on. BTW, I hae already removed the auxiliary fan for condensor, will the condesor fan power outlet work for a new fan or will i have to hot-wire new wiring????
