Old 12-07-2014, 08:23 PM   #1
OldGrandpaTune
The Road Warrior
OldGrandpaTune's Avatar
Default Main bearings do not fit
Are we supposed to trim these to fit? I worked all day, and maybe something really stupid on my part is going on.
Here are the bearings:
And this is the label on the box:
Perry
"Every man...should periodically be compelled to listen to opinions which are infuriating to him. To hear nothing but what is pleasing to one is to make a pillow of the mind."
St. John Ervine
OldGrandpaTune is offline   Reply With Quote
Old 12-07-2014, 08:34 PM   #2
lummert
lummert's Avatar
Part number on the box appears to be correct. Was the box open when you received it?
Old 12-07-2014, 08:55 PM   #3
The Librarian
Your block is a center thrust with 55mm journals. The bearings you have are for a rear thrust with 63mm journals. You need part# 271236 std main bearing set and part# 270471 thrust bearing set.
Old 12-07-2014, 09:02 PM   #4
OldGrandpaTune
The Road Warrior
Awesome glad i just screwed up. Got different year motor.
Old 12-07-2014, 09:11 PM   #5
OldGrandpaTune
The Road Warrior
Anyone who wants the wrong set let me know. I'll send them over.
Old 12-08-2014, 08:07 PM   #6
John V, outside agitator
Your bearings are fine.
It's your block and crank that are wrong.
See? Its all a matter of perspective.
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 12-08-2014, 09:36 PM   #7
OldGrandpaTune
The Road Warrior
Okay now I am tripping. Johnny V is looking at the sunny side of life.
Rookie mistake, but we have to suck up our stupid stuff along with the wins. Hopefully this thread will help someone some day double check despite what an expert writes in a paint pen on the motor. When you order main bearings MEASURE THE CRANK JOURNALS.
Had some way more expensive lessons in life than 70 bucks though, usually involving a woman.
Old 12-08-2014, 10:48 PM   #8
turbotankshane
Yeah but usually the tbricks problems can be solved by switching to the newest, youngest specimen available...
whereas these problems with women usually start because of switching to the newest youngest specimen available
turbotankshane is offline   Reply With Quote
Old 12-08-2014, 10:49 PM   #9
theknave
theknave's Avatar
Helped me out, so there's one.
This.
'86 240 DL, M46 - Primer grey, yellow, silver and flat black.
'90 240 DL, AW70 - Rotting, with its guts out, on the cadaver table... the AW70 is nice tho, with a recent full fluid flush via tt 500, and an all new Yukon set of bearings (Timken) and seals at the rearend, new SKF bearings and seals at the axles.
theknave is offline   Reply With Quote
Old 12-08-2014, 11:20 PM   #10
I always look at the sunny side of life...
Old 12-09-2014, 02:27 AM   #11
gtlover
One Weird Old Trick
gtlover's Avatar
If it has tits, tires; floats, or flies, you'll have problems.
My wife wants an amphibious airplane.
If you smoke after sex,
use more lubricant.
00 V70R "Tusenårsfalken"
09 Volvo C70 T5 "Old Blue"
11 Honda Odyssey Touring "Penelope"
85 Volkswagen Westfalia "Scout"
80 Dnepr MT-10/36 "Jenny"
09 Genuine Buddy 150 Blackjack "Jack"
78 Honda CB750F Supersport
volvo_bass@hotmail.com
gtlover is offline   Reply With Quote
Old 12-08-2014, 01:12 PM   #12
quillc
yv1a.com
quillc's Avatar
I'm interested. Located in 98367.
Chris
www.yv1a.com
Old 12-08-2014, 07:21 PM   #13
OldGrandpaTune
The Road Warrior
PM me your address. This is a brand new standard main and thrust bearing set that is for 89 and later. I'll get them packed up and mailed to you this weekend. This one is on the house.
Old 12-08-2014, 01:24 PM   #14
theknave
theknave's Avatar
Is this a B230 block? Is there more than one type of B230 block?
Old 12-08-2014, 07:19 PM   #15
OldGrandpaTune
The Road Warrior
This is a B230FT block. The older ones had smaller crank journals and main bearings, and the thrust bearing was in the middle. In 1989 they switched to larger bearings and moved the thrust bearing.
Old 12-08-2014, 08:09 PM   #16
And folks have determined that with a little lookin' and thinking a guy could use two sets of thrusts and have full 360 thrusts...
Old 12-08-2014, 08:24 PM   #17
iHateVolvoPeople
Johns right, you need to buy a <89 motor to suit your new bearings.
Feedback Thread
White liberals are the scum of the earth.
Old 12-08-2014, 10:52 PM   #18
iHateVolvoPeople
Were you 'shopping for my vehicle' on iPd with a >89 car but you have a <89 motor? Sorry for confusion
