Old 11-15-2020, 02:51 PM   #51
DavidSamuels
K-Jet-Free Zone
DavidSamuels's Avatar
Originally Posted by Cateran View Post
I swapped in a G80 to my '86 240, cut down the 48t ring to 12 and used the aluminum cover with speedo sensor that mounts with an allen bolt- problem is that sensor has two pickups. My speedo has been bouncing ever since and I'd like to correct it. I have the old steel diff cover and pickup if that is the only answer.
PM'd you.
DavidSamuels is offline   Reply With Quote
Old 11-15-2020, 03:08 PM   #52
sbabbs
sbabbs's Avatar
I'm not sure if the aluminum covers are any different but I know that there are two different versions of the pickup sensor, one is deeper and can hit the sensor ring. I spaced it out with a spacer behind the bolt that holds the sensor in the rear and then it didn't hit the ring and worked. Also didn't leak oil out the sensor hole. Other option if sensor hits is get the other shorter sensor.
Old 11-15-2020, 03:18 PM   #53
DavidSamuels
K-Jet-Free Zone
Good input, thanks. I just put the sensor in yesterday. Rotating it, could not hear any contact. Haven't gotten it on the road yet, so not sure about speed, but I did swap the leads per John's and Chase's input.
Spent another hour browsing around until I found the videos on the G80's operation so as to determine yes/no on the friction modifier. Looks like no clutches, so it's a no on that.
