Old 11-17-2015, 09:12 AM   #1
240 JAH
Savethevolvos.com
240 JAH's Avatar
Default Volvo OEM strut mounts .. early Failure?
About a year and a half ago I replaced all the suspension components on my 1986 245 GL . I replaced all the rubber with polyurethane except the Volvo OEM strut mounts , I replaced the them with Volvo OEM strut mounts again from Volvo , not aftermarket , based off many warnings from other volvo enthusiast about the failure of aftermarket strut mounts. It seems that the mounts are already tearing apart ...The other things to note are I installed Bilstien HD strut inserts and strut reinforcement plates. It's been a while and I torqued them properly but I will be checking them for that when I get home again.
Drivers side
passengers side which doesn't look too out of the ordinary. I know they will show cracking and such but the drivers side looks like its not going to do the job for too long.
I almost bought solid camber plates a few years back but decided against it . I think I should look into that route again .
any thoughts on these photos? so far there is no noticeable suspension problems.
82' F613 / 79' 242GT / 89' 244 Diesel / 70' 164 / 66' 122 4dr (Project RAT ROD) /67' 122s (P132441M) / 58 PV444 88' 244DL
/ 86' 245GL / 89' 245 Trailer
EBAY Handle: Guitarphotoman
Seller/Buyer feedback
1967 122s Restoration Thread
240 JAH is offline   Reply With Quote
Old 11-17-2015, 10:16 AM   #2
Kjets On a Plane
Kjets On a Plane's Avatar
You need the 15A style plates.
With those, as long as the bearing is any good and rubber isn't horrible, I no longer worry about those.
I'd rather have old mounts with 15A plates.
Old 11-17-2015, 10:22 AM   #3
BradC
Wow, my 30 year old original mounts looked better than those!
BradC is offline   Reply With Quote
Old 11-17-2015, 10:31 AM   #4
240 JAH
Savethevolvos.com
240 JAH's Avatar
Is this like the strut reinforcement plates from IPD because I installed those as well when I installed the mounts . I'm assuming you saw that I have the reinforcement plates and I think the only thing they do is reinforce the sheet metal.
So where do I find 15A plates ?
Old 11-17-2015, 11:20 AM   #5
Råda
Volvoretard/Partshoarder
Råda's Avatar
http://forums.turbobricks.com/showthread.php?t=315334
Jonas
Old 11-17-2015, 12:39 PM   #6
240 JAH
Savethevolvos.com
240 JAH's Avatar
EDIT: the more I think about this the more it looks to me like the metal sleeve in the center is detaching from the rubber all together . thoughts?
Originally Posted by Råda View Post
thank you .
It sucks that I went to the trouble of installing the IPD reinforcement plates and that they do nothing for the rubber.
this photo that 15A posted shows the mounts to look perfectly intact even after 15k with no rips or tears . But mine have about the same and WTF they look mangled compared to this pic.
do you guys think these reinforcement plates will keep these things alive ? I am getting them regardless but I don't know why the volvo OEM ones failed, or seem to be failing, so quick.
here is photos of my mounts . They aren't blown out and like I said before I had IPD reinforcement plates which are similar to the 15A ones so I am not sure if the 15A ones will help me with this one.
Here is the IPD reinforcement plates also made out of 1/82 steel . It looks to me that the 15A one has a slightly tighter hole in the center than the ipd but thats just off looks .
Old 11-23-2015, 12:01 AM   #7
DavidSamuels
K-Jet-Free Zone
DavidSamuels's Avatar
No question the units from Volvo are not as good as they used to be. We are getting about 40k out of them. Used to get double that easy. Chris has the only solution.
DavidSamuels is offline   Reply With Quote
Old 11-23-2015, 12:15 AM   #8
ZoomSpeed
ZoomSpeed's Avatar
You aren't the only one with failing OE strut mounts. I paid good money for Volvo OE strut mounts 2 years ago when I put iPD springs in my car. I also put 15A's strut plates in. The rubber looks like above, all cracked and the pass front one makes a clicking sound when turning past a certain degree, bearings have gone bad I suspect.
I'm left with no options other than to replace them with more OE parts I guess.
I suspect the lowering springs may have had something to do with this, but the original ones lasted 20+ years, why can't the replacements last at least half as long
1989 Volvo 240 Wagon - +T, Cut iPd springs, Koni shocks, front dual sway bars, Short shifter, Truetrac. - The Autocross Champ and Winter Drift Machine
1989 Saab 900 Turbo - Aero wheels, Modded APC - The Summer Highway Blaster
My 240 Build Thread
ZoomSpeed is offline   Reply With Quote
Old 11-23-2015, 07:30 PM   #9
I'm going to try the aftermarket deutschparts (not sure about the spelling) mounts on ebay. I bought the plates from Chris on ebay as well. They are going in my 93 wagon after I do the clutch and swap the bad trans out.
Old 11-23-2015, 07:53 PM   #10
looks like its time for BNE mounts.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-19-2016, 04:36 PM   #11
kittysgreyvolvo
kittysgreyvolvo's Avatar
The GT style plates WON'T halt failure of the strut mount as imaged here. The various made in China Volvo 240 strut mounts fail like this. Sometimes the cheapie made in Chinese junk strut mounts (Meyle/URO/APA/Febi) also fail by the bushing material separating from the center bearing cup. Sometimes the bushing material separates from the exterior plate with the three studs on to secure to the inner fender.
The Volvo OEM strut mount, ON 1272455 WAS built by Boge in Germany. The center bearing 'cup' assembly, made by SKG and now FAG of Spain, has an open to the top ball bearing race you stuff some grease occasionally. Best to use NLGI-1 or 2 silicon grease like SuperLube as it won't eat / melt the carbon vulcanized rubber versus hydrocarbon grease.
This is an issue about as critical as a ball joint failure. With or without Chris' GT plates, the strut piston will eventually pass through the strut mount bushing materials, and serious dent the underside of the hood.
This is a HUGE safety issue.
The only other brand of strut mount that may be useful is SKF. Doubtful they make these in Germany anymore.
It may be useful to see if anyone can source the Made in Germany Boge strut mounts.
I bought several sets from Tasca Volvo up to 2013 for my three 240s. I replaced all three sets of two. They are all going strong and are solid, not domes, no cracks, no distortion.
Tasca Volvo sells the strut mounts for 74$ Yellow bag inside the Volvo blue box as I last bought a set in 2013.
http://www.tascaparts.com/oe-volvo/1272455
Yes these are Volvo OEM.
Tasca also sells the GT plates for 31$
http://www.tascaparts.com/oe-volvo/1247816
PLATE - Volvo (1247816)
What FCP Euro offer here may be Volvo OEM as they write here.
https://www.fcpeuro.com/products/vol...nt-240-1272455
The bearing assembly look right.
A cheap strut mount uses a sealed bearing assembly as Meyle does.
What iPd has here also looks OEM, yet the shiny appearance is new.
iPd sells only the Volvo OEM strut mount. Yet, in the images above, what does that matter, if they fail like this, like Meyle or URO made in Chinese junk.
https://www.ipdusa.com/products/9743...-mount-240-260
iPd also sells the GT strut reinforcing plates. (Volvo PN 1247816.) Yet these plates WON'T halt a failure as shown in the images earlier in this post!
FCP Euro also sells KYB brand, made in Taiwan. These use sealed bearings. The sealed bearings cannot take the lateral stress too well, what is the up and down motion as the front strut moves. The bearings usually fail first, then the bushing material. Same as Meyle and URO and Febi in appearance and certainly design.
https://www.fcpeuro.com/products/vol...265-240-sm5050
This is Meyle, sold by FCP Groton. See the sealed bearing crimped in at four points. Garbage.
Unless we have a quality solution, from Volvo OEM for PN 1272455, the best solution may be:
Kaplhenke 240 Offset Spherical Strut Mounts @ 185$ a piece.
http://www.kaplhenke.com/collections...t-strut-mounts
I'd rather continue with the Made in Germany Boge Volvo OEM strut mounts. But the North American auto parts wholesalers and distributuion networks make it very hard to buy Made in Europa any more.
Whaddya think?
Thanks,
MacDuffed.
Volvo "Buttermilk" MacDuff
I've owned only Volvo 240s since 1985.
RIP, yet beloved:
1975 244 DL (B20, M40)
1976 242 DL (B21, M46, Moonroof - an SRO?)
1979 245 DL (B21, M46)
1979 242 GT (B21, M46, Moonroof - an SRO? Grey Market from Holland)
Currently owned, beloved, operating, driven, if occasionally:
1990 240 (245) DL (B230, M47 II)
1991 240 (244) (B230, M47 II, Moonroof. Grey Market from Germany)
1992 240 (244) GL (B230, M47 II, L-jet 3.1, Moonroof)
kittysgreyvolvo is offline   Reply With Quote
Old 06-19-2016, 04:56 PM   #12
Tuff240
240 Ninja
Tuff240's Avatar
Whaddya think?
The current OEM Volvo mounts suck just as bad as all of the aftermarket suppliers. No metal supporting plate is going to keep the rubber from tearing away from the center bearing cup. It's just another ****ty Volvo design that will fail over and over again with today's poor quality parts. 15A's plates may prolong it, but I'm not wanting to replace $150 worth of mounts every 20-40k miles.
-Patrick
Old 06-19-2016, 05:22 PM   #13
Kjets On a Plane
I've just been skating by with used PNW rubber in good shape and 15A plates.
The 15A mounts solve it well enough for a boring DD and cool weather coastal PNW rubber.
I see it as:
Used cool weather rubber and 15A plate or Kaplan, no in-between really.
Old 06-19-2016, 05:34 PM   #14
MDVLN
Kapitän Klugscheißer
MDVLN's Avatar
Just a comment from the peanut gallery, the Kaplhenke strut mounts are $185 for the PAIR, not each (92.50 EA before shipping). Have been lurking threads like these as I'm possibly headed into a suspension overhaul and would rather not dig back into it all after 20K Miles so this is of great interest to me.
Old 07-03-2016, 01:11 PM   #15
kittysgreyvolvo
Yep, for the pair. Got the price wrong, yet with everything, it totals up a bit more for the set of two with the spring perches and such for $291.
Such bull****. How many Volvo 240 remain road worthy or maybe restored. Some 100,000 or 200,000 world wide?
Can we find out whether ZF-Boge of Germany makes these anymore?
Or would SKF still make them. I believe they made quality strut mounts for 240 and such RWD Volvo.
Maybe contact Volvo Cars of North America?
A failing strut mount can be sort of a dangerous thing, huh?
Globalism SUCKS!
Last edited by kittysgreyvolvo; 07-03-2016 at 01:13 PM.. Reason: Forgot to add a point or two.
Old 07-03-2016, 01:52 PM   #16
sim
Mere Drab Mob
sim's Avatar
The originals go at around thirty years here, in our climate.
New stuff is not worth the time.
Ben's parts are very nice, I suggest the luxe-steer as well, better than OEM.
I have a Volvo with some half-done, homemade crap in it.
http://forums.turbobricks.com/showthread.php?t=244534
sim is offline   Reply With Quote
Old 07-03-2016, 01:57 PM   #17
Kjets On a Plane
Eh, it's just that they don't manufacture them to OEM specs to last a 3year/36k mile warranty (or more for a chassis warranty) spec for 100k cars a year or however many they were pumping out in the day (~3million cars over 20ish years, 1986 USA models highest production year IIRC).
Brand name doesn't really mean anything, or not much anymore.
It becomes a low production volume B-string thing that doesn't have to be made to OEM (or better) specs.
Some bean counter notices that they are a low volume thing where stringent specs aren't important, they shove it on the B-strand, raw materials are cheapened and production is sent to wherever cheapest and something gets lost in translation on the design/build (which was never very good to begin with with this part), and here we are.
I've basically never replaced a single strut mount on a mid 90s camry or toyota of any kind. Almost never a ball joint or steering rack. They actually design them decently, what can I say? Euro trash cars, be prepared for vulcanized rubber parts that are just glued together no particular thoughts about shear strength that dry out/crack/wear out often.
Still, like I said, I've been doing fine with lower mile used PNW rubber with no cracks and 15A plates. Good enough for these cheap low level cars and their cheap owners. Better than anything you can buy new other than Kaplenke.
Kaplenke is nice stuff, the price is very fair considering he's willing to support the cars/products and work out bugs with decent quality all with super low volume and hit and miss sales volume. I'm amazed anyone bothers to make anything whatever that complicated/thin margins/low volume for Volvo guys...
Support Ben (Kaplenke), 15A and local wreckers like Roy (2manyturbos) with good used PNW rubber? They support you jokers more than any large companies do or ever will (current business trends being what they are and likely continuing into the future)..
Old 07-03-2016, 02:31 PM   #18
sim
Mere Drab Mob
sim's Avatar
Oh yeah, this. People who make (or even just resell) nice stuff for our small market deserve our business.
A 15A plate and good used rubber mounts are a good combo too. His rear cam seal retainer is holding my engine's seal in.
The race to the bottom leads to dents in the hood.
Old 07-13-2016, 07:46 PM   #19
kittysgreyvolvo
Finally caught up to the brickboard.com. In this scenario, the original poster purchased what he was told was OEM Volvo strut mounts from FCP Groton. Please see here:
FCPEURO OEM strut mount failure after only 10 months 200 1988
https://www.brickboard.com/RWD/volvo...10_months.html
I feel as if I bought the last Made by Boge. The last set I installed were marked Boge Germany and look like:
PN 1359110 must be the sub-assembly without the bearing assembly or the bushing material?
Still going strong. No problems.
Old 04-20-2017, 09:17 PM   #20
kittysgreyvolvo
Default Another disappointed Volvo 240 OEM strut customer
Brickboard Member joekidd writes here:
https://www.brickboard.com/RWD/volvo...ut_mounts.html
DO NOT USE OEM VOLVO MOUNTS. Replaced as PM as I was replacing struts and shocks, on my 88 original mounts rubber cracked a bit not bad bearings were fine. Within 2 months the rubber was separated from the inner bearing mount. COMPLETE GARBAGE.
As far as struts go Bilstein HDs will most likely outlast the car and provide the best overall durability, handling and stability on the road.
Would anyone, can anyone suggest, rubber strut mount replacements other then the two Kaplhenke 240 strut mount camber plate options?
Thanks. Please consider this a bump.
Old 04-20-2017, 10:15 PM   #21
muppetman342
Having too much fun
muppetman342's Avatar
Why not go with Kaplhenke? I'm a wuss about NVH and I haven't been disappointed, if that's what you're worried about. I am dealing with some spring rub but I don't think that's a widespread problem.
muppetman342 is offline   Reply With Quote
Old 04-20-2017, 10:24 PM   #22
thismachine13
Recently replaced my strut mounts in my '89 245 with Gabriel brand. I'm curious to see how they hold up over the coming months. The strut mounts I took out were stock Volvo and looked great. Guess what I decided to stash away in a box? Yep....those original set of strut mounts, just in case.
Old 04-21-2017, 02:26 PM   #23
Kjets On a Plane
Good used OE and 15A plates works fine on a TB budget!
Old 05-07-2017, 12:39 PM   #24
DavidSamuels
K-Jet-Free Zone
Default 240 Strut Mounts
Does anyone have any solid input from actual, recent experience on any of the "better" stuff that's out there? I can add that Volvo OEM are giving me a little over two years on KYB Excels before beginning to show separation. Important to note that this doesn't mean they are trash, yet, but once they start to separate it's downhill from there. We all know the "old" OEM mounts lasted many years before showing any separation at all. Mine were installed in 2001! Didn't really get bad until I put Billies in, but by then they were 14 years old and had 120k on them.
I stopped using Meyle and such years ago, would never trust URO for an application like this. I've never tried Boge's. Who has input (real input) on Moog or other?
Ben's stuff is beautiful, and may be the answer for my car, which needs struts and mounts, but let's face it, most people cannot afford them and have no use for that level of quality/adjustability.
Old 05-07-2017, 12:40 PM   #25
muppetman342
Having too much fun
His cheaper option is the same price as new OE mounts last I checked. Part of why it was a no-brainer for me.
