Old 02-01-2016, 12:21 PM   #1
15A
World's Oldest Brewery
15A's Avatar
Default 7/9 Turbo Intank Pump Supplier
Anyone know who makes the OE intank pumps? I had heard it was either Valeo or Delphi. Want to get a new one for a build I'm doing. Airteks won their race to the bottom and are junk now. I'm leery of the no-name generics most box stores sell (IPD included).
I'll buy a $118 OE one if need be but was hoping to find the same pump in a cheaper box.
TIA
(IF YOU WANT ME TO LEAVE YOU FB AFTER THE FACT, JUST SAY)
Alcohol does not solve any problem, but then again, neither does milk
15A is offline   Reply With Quote
Old 02-01-2016, 05:04 PM   #2
Kestrel
Kestrel's Avatar
Walbro (now TI Automotive) replacement for the 850/S70 flows almost the same rate, and can be picked up for around $60 or so. Fits perfectly, and good quality - just requires you to cut and solder/crimp the existing connector.
Old 02-02-2016, 12:36 AM   #3
lummert
lummert's Avatar
Seem to remember removing a Delco pump. Delco would now be Delphi.
Old 02-02-2016, 12:38 AM   #4
lummert
lummert's Avatar
1992 Chevy S-10 intank pump (throttle body injection low pressure 12 psi).
Old 02-02-2016, 11:25 AM   #5
cleanflametrap
cleanflametrap's Avatar
Yes, during those years AC/Delco supplied Volvo's lift pumps. The world's oldest brewer of planned obsolescence.
-Art
Old 02-02-2016, 11:02 PM   #6
Wren
Porkchop Sandwiches
Wren's Avatar
I thought they were Bosch.
Old 02-04-2016, 03:41 PM   #7
vvpete
The Delco is the 740T pump. I put one in my 240 with a little massage of the holder. Also Carter branded pumps meet the same Delco specs and now are both the Delphi brand sold at NAPA for ~$80. Older lower presasure pumps are 3-5 psi and the Delco/Carter is 5-6 psi.
BTW the older pumps were made by VDO originally
vvpete is offline   Reply With Quote
Old 11-18-2018, 10:48 AM   #8
DavidSamuels
K-Jet-Free Zone
DavidSamuels's Avatar
Here I am resurrecting an old thread. I have been using the Delphi pump for a long time, in tank, with excellent results. However as of I don't know when, "our" app no longer comes with the screw terminals on top and I'm out shopping again. Looks like the Carter may be the only option now as even Delphi's catalogue doesn't show one that seems to be the same specs, and the proper electrical connections.
DavidSamuels is offline   Reply With Quote
Old 11-18-2018, 04:43 PM   #9
lummert
lummert's Avatar
I changed the connectors.
