Old 03-05-2010, 04:54 PM   #1
vegasbrick
vegasbrick's Avatar
Default small clock repair
Does anyone know of a write-up on repairing the small clock? This would be the dash mounted one that hooks to the tech on the cluster. I searched maintenance & nonperformance threads and did not find anything about repair.
Thanks in advance.
Feedback Thread:
http://forums.turbobricks.com/showthread.php?t=208751
Volvos owned:
87 244 - Sold
86 245 - Sold
79 244 - Sold
83 242 - Sold
90 245 - Sold
vegasbrick is offline   Reply With Quote
Old 03-05-2010, 05:03 PM   #2
cleanflametrap
cleanflametrap's Avatar
Don't saw the case like I did. Just peel the rolled rim carefully - the wrinkles will be hidden by the plastic bezel.
Get a couple radial lead 100 microfarad capacitors 16V or above (Radio Shack?)
Unsolder the old dried out caps and solder the new ones. It will run in the cold now!
I also tried to improve the lighting a bit: http://cleanflametrap.com/clock2.html
Even if you've never plugged in a soldering iron, this one's a shoe in.
Old 03-05-2010, 05:10 PM   #3
vlvman
vlvman's Avatar
Don't forget to pay attention to the polarity of the caps.
Robert
http://www.volvowiringdiagrams.com/
82 244DL, 2004 S60R AWD, 2008 S40 GF's
Had: 77 242 DL, 80 242 DL, 82 245 DL, 89 740 GL, 94 850T, 95 850 GL, and a 02 S60 2.4T
vlvman is offline   Reply With Quote
Old 03-05-2010, 08:28 PM   #4
vegasbrick
vegasbrick's Avatar
Thanks guys. Nice site there cleanflametrap.
Old 03-05-2010, 11:44 PM   #5
dbarton
Dejected by Volvo Corp.
dbarton's Avatar
That's a great repair write up. I have a couple dead clocks I'm gonna try this on.
Dave
'84 242ti, fourth owner, mine since 2003. Garaged since new. Old-school rounds because. B21FT, EMS: SDS EFI & IGN, TD04HL-15G turbo, T5Z trans with 0.73 OD, 3.91 diff, unmodified G80.
Volvo's Ambivalence of Volvo Enthusiast Community: prancingmoose.com/#novolvo
Old 03-06-2010, 12:14 AM   #6
volvo245kit
FWIW, I repaired 5 dead clocks with caps that I got from a local electronics guy and the new caps didn't have any polarity markings on them. I asked the guy and he said that it didn't matter. So I went ahead and soldered them all in and put them back together and they all worked. Go figure.
volvo245kit is offline   Reply With Quote
Old 03-06-2010, 12:29 AM   #7
vlvman
vlvman's Avatar
Non polarized caps, some are some aren't.
Old 03-06-2010, 12:36 AM   #8
Volvox_240
Volvox_240's Avatar
My clock only keeps time when the car is on. Is this the case for all 240s, or is mine wearing out? I saw this thread and had to ask! Thanks for the info
Volvox_240 is offline   Reply With Quote
Old 03-06-2010, 03:39 AM   #9
dbarton
dbarton's Avatar
If you're clock is getting voltage when the key is off like it should, you might check your battery flat voltage... do this with car off after it has been sitting for 4 or 5 hours. A good battery at 100% should read about 12.6v. If it's 12.2v or lower, your battery is dying and it putting out less than 25% of normal capacity. Just a guess, but possibly that could shut off a voltage sensitive clock.
Old 06-06-2022, 11:03 PM   #10
the_hairy_baboon
Thread bump, just got my clock open (scraped with utility blade and pick until could get under the bezel and then small flatheads to lever it up. Unsoldered the ground connection from the copper {\phi} and got the circuit board and mechanicals out.
Questions:
1. Inside white matte paint is kinda thin. I could pull the bulb, mask off, and spray the inside with a brighter matter (I assume not glossy since that would be less even). Is there anything to look for in a spray paint to do this?
2. Would I gain benefit from also painting the backside of the front glass holding cone? Not worth the tape masking effort?
3. Anyone need any pictures of the insides or schematics? Can't see the main chip but can trace what all is connected to it.
4. Bulb replacement - current bulb is working, but it's been over a decade since cleanflametrap's LED experiment. I'm thinking there's more variety to be found that's potentially brighter too. Has anyone experimented with this?
the_hairy_baboon is offline   Reply With Quote
Old 06-07-2022, 07:35 AM   #11
dbarton
dbarton's Avatar
I wrote an article about this here when I did this: https://www.240turbo.com/240gaugewiring.html#LED
and here: https://www.240turbo.com/240gaugewir...ml#clockrepair
Dave
Old 06-07-2022, 06:09 PM   #12
the_hairy_baboon
Dave
ah, excellent links. I think I browsed them months ago but forgot the details.
Any thoughts on the repainting of the insides? http://cleanflametrap.com/clock2.html mentions white matte finish for light dispersal, but nothing of redoing it.
Old 06-15-2022, 10:34 PM   #13
the_hairy_baboon
Alright, excellent advice here.
1. Replaced the two 100uF capacitors (even after checking polarity accidentally put one in backwards, so had to switch orientation)
2. Got the yellow version of the LEDs in dbarton's link (https://www.amazon.com/dp/B0798Q4RRC), provides much better surround lighting without being blinding white like a white LED might be.
Any good suggestions for ways to roll the black bezel rim back on enough so it won't rattle? Just press it in a few spots so it won't move? I loathe electrical tape for it since it'll become sticky pretty fast.
Old 06-16-2022, 11:57 AM   #14
philski o'flood
philski o'flood's Avatar
follow the 914 link from DBs site. The guy crimped the bezel back great. I use a wide short blade screw driver and keep pressing and rotating
philski o'flood is offline   Reply With Quote
