Old 03-29-2022, 05:19 AM   #1
hessam69
Default Pinging, dieseling, lacks power, runs like ****e
I have a 1990 240 with 125,000 original miles, 100% stock one owner prior to myself
It pings badly, sometimes diesels (half-runs) after shutting down (especially on warm days), runs rough, idles okay but under load it hesitates and is generally unhappy.
I thought it had some carbon on the top of the pistons so I got a water bottle and fed some through the inlet manifold until about 2 quarts was used up, could not get any smoke from the exhaust, confused
The fuel consumption is great, around 300-350 miles from a tank. I'm using 91 octane Australian fuel (not sure but I believe that equates to 87 octane American)
It never misfires, but it feels like its underpowered, must be something to do with it pinging
Not sure what to look at next
Thanks in advance for any ideas
Old 03-29-2022, 06:30 AM   #2
Otto Mattik
board member
Otto Mattik's Avatar
Hello down under !
My experience with pinging was a LH 2.2 car not timed correct/running lean.
Here is a link that may give clues:
https://www.matthewsvolvosite.com/volvo-240-dieseling/
Old 03-29-2022, 08:55 AM   #3
Cwazywazy
Single jingle
Cwazywazy's Avatar
Dieseling on an injected car? Might be some wiring problems.
I don't know what I have
Old 03-29-2022, 11:16 AM   #4
shoestring
shoestring's Avatar
If it's pinging, it's reducing ignition advance, hence your lack of power feeling. Simplest thing to do would be put your 95 or 98 RON in it and see if that alleviates your problem. If it does, I'd try a different 91 RON from what you've been using. If it doesn't, then I'd say you have to go further. Does it start ok when it's cold? By cold I mean first thing in the morning, or if it's cool/cold outside and it's been sitting all day, or something like that.
Old 03-29-2022, 11:42 AM   #5
I.M. Weasel
Leaky injectors for the dieseling?
Living life one day at a time. Stopping to smell the oil slick beneath my Volvos.
Old 03-29-2022, 01:58 PM   #6
Mr. V
Mr. V's Avatar
Knock sensor might be bad or not torqued to correct spec.; that can lead to pinging and poor running.
Old 03-29-2022, 04:10 PM   #7
hessam69
Thanks for the replies
It starts well cold and hot, though some starts take longer than others. Someone mentioned possible leaking injectors. I was going to service them anyway or replace them with the pink ones the seller on this forum supplies. I can swap a known good knock sensor to try.
Old 03-30-2022, 09:42 AM   #8
shoestring
shoestring's Avatar
Leaking injectors would add fuel, heavy knock would be more symptomatic of not enough fuel. You could look at fuel pressure regulator for this.
Kinda sounds like a restricted cat converter.
Old 03-30-2022, 01:02 PM   #9
culberro
culberro's Avatar
Also check the cam and dizzy timing. Mine was off a tooth from the PO and behaved like you described.
Or you could have a valve that's getting hot and/or already burned.
Head work: https://forums.turbobricks.com/showthread.php?t=349975
Temp Sender Adapters: https://forums.turbobricks.com/showthread.php?t=348169
Old 03-30-2022, 02:38 PM   #10
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Another vote for checking the timing here.
Any oil consumption?
I sell chips for LH 2.4!
If you live in the Northeast US, I'll drive to you and tune your LH 2.4 car!
Old 03-30-2022, 03:12 PM   #11
hessam69
Zero oil consumption, very good fuel consumption, it's strange when I bought the car five years ago, I never noticed the poor running and pinging but it seems to have gotten worse every year, I don't drive the car much, will check cam timing and change all the belts and seals.
How would you check distributor timing? Being LH 2.4, would the ECU and EZK know the difference if the distributor was out? Even though there is nothing inside it and the timing is not adjustable, and I don't see any reason why someone would ever need to remove it
Old 03-30-2022, 03:20 PM   #12
redblockpowered
Oops, missed that it was not a 2.2 car.
Old 03-30-2022, 03:51 PM   #13
culberro
culberro's Avatar
Actually verify the cam timing is correct. Sometimes the cam gear will loosen and shear the pin. Cam will still be "timed" by the parks, but the cam will be many degrees off.
For dizzy, TDC and remove the cap. Check rotor position. I've had people do hack work on cars where the plug wires were out of sequence due to the dizzy not being set in correctly. Then you get a ton of arcing from the rotor to the cap.
Otherwise it's the basics:
Fuel pressure
Check the coolant temp sensor
Check the MAF
Pull intake and check for leaking fuel injectors
Old 03-30-2022, 07:01 PM   #14
philski o'flood
philski o'flood's Avatar
this
philski o'flood is offline   Reply With Quote
Old 06-20-2022, 05:48 PM   #15
hessam69
It was a bad air mass meter.
I always thought air mass meters would either work or fail completely, but I've since learned that they can present different failures which still allow to car to be driveable, although poorly. I suppose if one or more of the six pins in the connector become damaged or disconnected, that can happen. I was getting codes 121 and 232.
The engine still diesels for around half a second to a second after shut down sometimes, and there is still a slight ping at low rpm and high load conditions, but it runs 100% better than it did.
