Old 06-11-2022, 08:41 PM   #1
mike66
Default J-type Speedo drive?
Hello, I’m about to swap a J type overdrive/ iron case M46 into my 89 745T to replace a bad P Type. My questions are, can I just weld the end of the speedometer drive shut, and does the speedo gear need to be in there or can I just toss it. Thanks in advance.
mike66 is offline   Reply With Quote
Old 06-11-2022, 08:51 PM   #2
- Stock PSI Or Bust -
You should remove the gear and fashion a plug out of a speedometer end, a dime and a round of EPDM sheet rubber or a bicycle inner tube.
how psi stock cna sprout?
Old 06-11-2022, 08:53 PM   #3
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Remove the speedo drive housing and tap in a freeze plug.
1982 242Ti - black, B23FT/M46 combo.
@john242ti on IG
Old 06-11-2022, 08:59 PM   #4
planetman
planetman's Avatar
Volvo part for plugging the speedometer hole when a speedo cable isn't needed for a J O/D.
Costs about $20.00 and comes with a new o-ring.
Eric
Torrance, CA 90502
Old 06-11-2022, 09:19 PM   #5
mike66
Nice! But wouldn’t it serve the same purpose as the speedo drive plug being blocked off and of course a new o-ring? Do you sell these plugs? Or is it a dealer item?
Old 06-11-2022, 09:41 PM   #6
planetman
planetman's Avatar
We do sell them, but we don't stock them. Available from Volvo, part number 1220200.
You actually don't need to plug the original speedometer hole if you have and reseal the original speedometer housing and install a speedometer drive gear. The speedometer cable doesn't do anything when it comes to sealing this area.
