Old 06-12-2022, 10:23 PM   #1
vwblue1967
vwblue1967's Avatar
Default Turn signal issue
1993 240
Hazzard lights work fine, left turn signals work fine but I Intermittently have a problem with the right side (front and rear together).
Sometimes it clicks fast but doesn't light up, dash lights or outside. Then it starts to slow the clicking noise, dash indictator dimly starts working and eventually dash indicator is normal brightness and outside lenses flash.
I've replaced fuses, swapped relays and removed the connections to the switch and cleaned them up. Still happens. Can go a week with no problem then it comes back.
I would just buy another switch but mine has CC and it works well and those seem to be much more expensive. Anyone have any suggestions I could try before having to buy a new one?
85 245 - ipd sport springs and sway bars yoshifab torque rods, kaplhenke bne strut mounts and TAB's. Poly bushings Bilstein tourings. B cam +4. 2.25 exhaust.
93 244 stockish.
vwblue1967 is offline   Reply With Quote
Old 06-13-2022, 11:06 AM   #2
Old and boxy but good.
The very fast clicking means there is a bad connection in the circuit. I would clean all the ground connections and take a good look at the bulbs in the sockets. They may need some cleaning up as well.
