![]() i took my car to work the other day and it started fine and normal. I've been driving the car with no issue but last time it wouldn't start at work and i waiting 10 min to try again then it started and then i drove it home but again now it won't start it just cranks and cranks. i don't want to just buy parts for the car yet. i i think it might be the starter or the fuel pump but i haven't tested anything yet.
Old and boxy but good.
![]() It's time to check and clean the main system fuse on the left inner fender. It's the smaller large red wire off the battery. It goes to a blade fuse which gets corroded and causes intermittent no starts. Also fuse 12 or 13 in the fuse box can cause a no start.
Dave, 1982 242 turbo. 338k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration. 1993 245 Classic, 440k miles, enem V15. IPD bars and chassis braces. Simons sport exhaust from Scandix. sbabbs ezk chip. Been a good road warrior. Genuine Volvo rebuilt leaky M47. ![]() |
![]() i just tried to start the car again and it started but I'll look for that and hopefully i won't need a tow
#4 |
![]() The fuse holder near the battery is a problem piece. I replaced mine with a waterproof fuse holder after I had the same issue with my 89 240.
#5 |
![]() i checked the fuse on the inner fender and it looks fine and the fuse box all my fuses were fine, anything else i should check for. the car starts but im worried if i drive it and then its won't start. can you put a link of which one you bought.
#6 |
![]() My sig has a no start article
No Start Thread |
#7 | |
![]() Quote:
#8 |
![]() thanks, i bought and installed one from O'Rielly's!
#9 |
